查看: 2630|回復: 0
89c51紅外循跡代碼
ID:292397 發表于 2018-3-15 17:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
unsigned char zkb1=0 ;    //**左邊電機的占空比**//
unsigned char zkb2=0 ;    //**右邊電機的占空比**//
unsigned char t=0;        //**定時器中斷計數器**//
sbit LSEN1=P1^0;       // 右光對管1
sbit LSEN2=P1^1;       //右光對管2
sbit RSEN1=P1^2;        //左光對管1
sbit RSEN2=P1^3;        //左光對管2
sbit IN1=P0^0;
sbit IN2=P0^1;
sbit IN3=P0^2;
sbit IN4=P0^3;
sbit ENA=P0^4;
sbit ENB=P0^5;
//****************延時函數****************//
void delay(int z)
{   while (z--);  }
//**********初始化定時器,中斷***********//
void init()
{  TMOD=0x01;
   TH0=(65536-100)/256;
   TL0=(65536-100)%256;
   EA=1;
   ET0=1;
   TR0=1;
//***********中斷函數+脈寬調制***********//
void timer0() interrupt 1
  if(t<zkb1)
     ENA=1;
     ENA=0;
  if(t<zkb2)
      ENB=1;
      ENB=0;
        t++;
  if(t>=100)
    {t=0;}
//******************直行******************//
void qianjin()
{  IN1=1; //******給電機加電啟動******//
     IN2=0;
     IN3=1;
     IN4=0;
    zkb1=30;
    zkb2=30;
//***************左轉函數1***************//
void turn_left1()
     IN2=0;
     IN3=1;
     IN4=0;
    zkb1=0;
    zkb2=50;
//***************左轉函數2***************//
void turn_left2()
     IN2=0;
     IN3=1;
     IN4=0;
    zkb1=0;
    zkb2=60;
//***************右轉函數1***************//
void turn_right1()
     IN2=0;
     IN3=1;
     IN4=0;
zkb1=50;
    zkb2=0;
//***************右轉函數2***************//
void turn_right2()
     IN2=0;
     IN3=1;
     IN4=0;
zkb1=60;
    zkb2=0;
//***************stop***************//
void goback()
     IN1=0; //******給電機加電啟動******//
     IN2=1;
     IN3=0;
     IN4=1;
    zkb1=50;
    zkb2=50;
//***************循跡函數*****************//
void xunji()
{ uchar flag;
  if((RSEN1==0)&&(RSEN2==0)&&(LSEN1==0)&&(LSEN2==0))
    { flag=0; }//*******直行*******//
   else  if((RSEN1==1)&&(RSEN2==0)&&(LSEN1==0)&&(LSEN2==0))
    { flag=1;} //***左偏1,右轉1***//
   else  if(((RSEN1==1)&&(RSEN2==1)&&(LSEN1==0)&&(LSEN2==0))||((RSEN1==0)&&(RSEN2==1)&&(LSEN1==0)&&(LSEN2==0)))
    { flag=2;} //***左偏2,右轉2***//
   else if((RSEN1==0)&&(RSEN2==0)&&(LSEN1==0)&&(LSEN2==1))
    { flag=3; }//***右偏1,左轉1***//
  else if(((RSEN1==0)&&(RSEN2==0)&&(LSEN1==1)&&(LSEN2==1))||((RSEN1==0)&&(RSEN2==0)&&(LSEN1==1)&&(LSEN2==0)))
    { flag=4; }//***右偏2,左轉2***//
  else if((RSEN1==1)&&(RSEN2==1)&&(LSEN1==1)&&(LSEN2==1))
    { flag=5; }//***stop***//
switch (flag)
     {  case 0:qianjin();
              break;
        case 1:turn_right1();
              break;
        case 2:turn_right2();
              break;
        case 3:turn_left1();
              break;
        case 4:turn_left2();
              break;
     case 5:goback();
              break;
        default: break;
//****************主程序****************//
{ init();
  zkb1=30;
  zkb2=30;
     IN2=0;
     IN3=1;
     IN4=0;
     ENA=1;
     ENB=1;
     {  xunji(); //*********尋跡**********//
