只需一步,快速開(kāi)始
查看: 1791|回復(fù): 1
這是我們最近寫的單片機(jī)數(shù)碼管顯示測(cè)試程序
ID:291575 發(fā)表于 2018-3-13 23:57 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. ORG 0000H
  2. AJMP 0030H
  3. ORG 0030H
  4. START:CLR P1.0
  5.         CLR P2.1
  6.         CLR P2.2
  7.         CLR P2.4
  8.         CLR P2.5
  9.         MOV P1,#11111111B
  10.         MOV P2,#11111111B
  11.         CLR P1.1
  12.         CLR P2.0
  13.         CLR P2.1
  14.         CLR P2.2
  15.         CLR P2.3
  16.         MOV P1,#11111111B
  17.         MOV P2,#11111111B
  18.         CLR P1.2
  19.         CLR P2.0
  20.         CLR P2.2
  21.         CLR P2.3
  22.         CLR P2.4
  23.         CLR P2.5
  24.         MOV P1,#11111111B
  25.         MOV P2,#11111111B
  26.         CLR P1.3
  27.         CLR P2.1
  28.         CLR P2.2
  29.         CLR P2.4
  30.         CLR P2.5
  31.         MOV P1,#11111111B
  32.         MOV P2,#11111111B
  33.         CLR P1.4
  34.         CLR P2.1
  35.         CLR P2.5
  36.         MOV P1,#11111111B
  37.         MOV P2,#11111111B
  38.         CLR P1.5
  39.         CLR P2.3
  40.         CLR P2.4
  41.         CLR P2.5
  42.         MOV P1,#11111111B
  43.         MOV P2,#11111111B
  44.         CLR P1.6
  45.         CLR P2.1
  46.         CLR P2.2
  47.         CLR P2.3
  48.         CLR P2.4
  49.         CLR P2.5
  50.         MOV P1,#11111111B
  51.         MOV P2,#11111111B
  52.         AJMP START
  53.         PUSH PSW
  54.    L:MOV R4,#2
  55.   L3:MOV R2,#00H
  56.   L1:MOV R3,#00H
  57.   L2:DJNZ R3,L2
  58.         DJNZ R2,L1
  59.         DJNZ R4,L3
  60.         POP PSW
  61.         RET
  62.         END
  63. ORG 0000H
  64. AJMP 0030H
  65. ORG 0030H
  66. START:CLR P2.0
  67.         CLR P1.1
  68.         CLR P1.2
  69.         MOV P1,#11111111B
  70.         MOV P2,#11111111B
  71.         CLR P2.1
  72.         CLR P1.0
  73.         CLR P1.1
  74.         CLR P1.3
  75.         CLR P1.4
  76.         CLR P1.6
  77.         MOV P1,#11111111B
  78.         MOV P2,#11111111B
  79.         CLR P2.2
  80.         CLR P1.0
  81.         CLR P1.1
  82.         CLR P1.2
  83.         CLR P1.3
  84.         CLR P1.6
  85.         MOV P1,#11111111B
  86.         MOV P2,#11111111B
  87.         CLR P2.3
  88.         CLR P1.1
  89.         CLR P1.2
  90.         CLR P1.5
  91.         CLR P1.6
  92.         MOV P1,#11111111B
  93.         MOV P2,#11111111B
  94.         CLR P2.4
  95.         CLR P1.0
  96.         CLR P1.2
  97.         CLR P1.3
  98.         CLR P1.5
  99.         CLR P1.6
  100.         MOV P1,#11111111B
  101.         MOV P2,#11111111B
  102.         CLR P2.5
  103.         CLR P1.0
  104.         CLR P1.2
  105.         CLR P1.3
  106.         CLR P1.4
  107.         CLR P1.5
  108.         CLR P1.6
  109.         MOV P1,#11111111B
  110.         MOV P2,#11111111B
  111.         AJMP START
  112.         PUSH PSW
  113.      MOV R4,#2
  114.   L3:MOV R2,#00H
  115.   L1:MOV R3,#00H
  116.   L2:DJNZ R3,L2
  117.         DJNZ R2,L1
  118.         DJNZ R4,L3
  119.         POP PSW
  120.         RET
ID:291575 發(fā)表于 2018-3-13 23:58 | 只看該作者
這個(gè)是共陽(yáng)極的六位動(dòng)態(tài)顯示數(shù)碼管
