查看: 2013|回復(fù): 2
函數(shù)信號(hào)發(fā)生器的小代碼···如有雷同···我們都是聰明人
ID:209836 發(fā)表于 2018-3-10 15:29 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include<absacc.h>
#define uint  unsigned int
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
sbit s4=P1^3;
sbit s5=P1^4;
sbit s6=P1^5;
sbit s7=P1^6;
sbit s8=P1^7;
uint d1,d2;
uint s,p;
uint n;
uchar code sintab[256]=
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,
0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,
0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,
0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,
0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,
0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,
0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,
0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,
0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,
0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,
0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,
0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,
0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,
0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,
0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,
0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,
0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,
0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80
uchar code jctab[128]=
0x00,0x02,0x04,0x06,0x08,0x0a,0x0c,0x0e,
0x10,0x12,0x14,0x16,0x18,0x1a,0x1c,0x1e,
0x20,0x22,0x24,0x26,0x28,0x2a,0x2c,0x2e,
0x30,0x32,0x34,0x36,0x38,0x3a,0x3c,0x3e,
0x40,0x42,0x44,0x46,0x48,0x4a,0x4c,0x4e,
0x50,0x52,0x54,0x56,0x58,0x5a,0x5c,0x5e,
0x60,0x62,0x64,0x66,0x68,0x6a,0x6c,0x6e,
0x70,0x72,0x74,0x76,0x78,0x7a,0x7c,0x7e,
0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e,
0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e,
0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xae,
0xb0,0xb2,0xb4,0xb6,0xb8,0xba,0xbc,0xbe,
0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcc,0xce,
0xd0,0xd2,0xd4,0xd6,0xd8,0xda,0xdc,0xde,
0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xee,
0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,0xfe
uchar code sjtab[256]=
0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,0xfe,
0xfe,0xfc,0xfa,0xf8,0xf6,0xf4,0xf2,0xf0,
0xee,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,
0xde,0xdc,0xda,0xd8,0xd6,0xd4,0xd2,0xd0,
0xce,0xcc,0xca,0xc8,0xc6,0xc4,0xc2,0xc0,
0xbe,0xbc,0xba,0xb8,0xb6,0xb4,0xb2,0xb0,
0xae,0xac,0xaa,0xa8,0xa6,0xa4,0xa2,0xa0,
0x9e,0x9c,0x9a,0x98,0x96,0x94,0x92,0x90,
0x8e,0x8c,0x8a,0x88,0x86,0x84,0x82,0x80,
0x7e,0x7c,0x7a,0x78,0x76,0x74,0x72,0x70,
0x6e,0x6c,0x6a,0x68,0x66,0x64,0x62,0x60,
0x5e,0x5c,0x5a,0x58,0x56,0x54,0x52,0x50,
0x4e,0x4c,0x4a,0x48,0x46,0x44,0x42,0x40,
0x3e,0x3c,0x3a,0x38,0x36,0x34,0x32,0x30,
0x2e,0x2c,0x2a,0x28,0x26,0x24,0x22,0x20,
0x1e,0x1c,0x1a,0x18,0x16,0x14,0x12,0x10,
0x0e,0x0c,0x0a,0x08,0x06,0x04,0x02,0x00
void delay (uchar k)
  uchar j;
  while((k--)!=0)
    for(j=0;j<125;j++);
void zhengxian()
   P2=sintab[n];
    n=n+p;
    if(n>=256)n=0;
void fangbo()
    P2=0xff;//??
    delay(d1-p);
    P2=0;
    delay(d2-p);
void juchi()
    P2=jctab[n];
    n=n+p;
    if(n>=127)n=0;
void sanjiao()
   P2=sjtab[n];
    n=n+p;
    if(n>=255)n=0;
void boxingkey()
    if(s1==0)
        P0=0xF9;
        s=1;
        n=0;p=4;
    else if(s2==0)
        P0=0xA4;
        s=2;
        n=0;p=4;
    else if(s3==0)
        P0=0xB0;
        s=3;
        n=0;p=4;
    else if(s4==0)
        P0=0x99;
        s=4;
                n=0;p=4;
    else if(s5==0) //?????
        delay(10);//????
        if(s5==0)
        d1--;
        d2++;
                while(!s5);//????,?s5=1(??)?????
                delay(10);//??
                while(!s5);//?????
    else if(s6==0)//?????
        delay(10);//????
        if(s6==0)
        d1++;
        d2--;
                while(!s6);//????,?P1_0=1(??)?????
                delay(10);//??
                while(!s6);//?????
    else if(s7==0)
        delay(10);
        if(s7==0)
            p=p+1;
                while(!s7);
delay(10);
                while(!s7);
    else if(s8==0)
        delay(10);
        if(s8==0)
            p=p-1;
            if(p<=0)p=0;
                while(!s8);
                delay(10);
                while(!s8);
    d1=10;
    d2=10;
    n=0;
    p=4;
    P0=0xff;
    P1=0xff;
        boxingkey();
        switch(s)
        case 1:zhengxian();break;
        case 2:fangbo();break;
        case 3:juchi();break;
        case 4:sanjiao();break;
ID:209836 發(fā)表于 2018-3-10 15:30 | 只看該作者
還可以吧···
ID:209836 發(fā)表于 2018-4-23 22:02 | 只看該作者
哈哈哈哈 我主要不是做C的 我是做Python的,
