查看: 2867|回復(fù): 0
50個(gè)51單片機(jī)常用功能仿真與匯編語言源碼
源程序是匯編語言寫的:
目錄:
01_CLR_RAM
02_BCD_Conv
03_ASCII_Conv
04_Prog_JMP
05_Move_RAM
06_Data_Sorting
07_BCD_NEG
08_BCD_Add
09_BCD_Sub
10_BCD_Shift
11_Port1_1
12_Port1_2
13_Flash_Lamp
14_Switch_Lamp
15_Ad_Lamp
16_Ad_Lamp_Table
17_multi_Switch
18_74LS245
19_74LS273
20_82551
21_82552
22_LED
23_Dyn_Scan_LED
24_Dyn_Display
25_8x8_LED
26_Serial_LED_Disp
27_Audio
28_Key_Recg
29_Key_Function
30_Key_Board
31_4X4_KeyBoard_1
32_4X4_KeyBoard_2
33_Timer_Soft
34_Counter_4_bit
35_Counter_0-99
36_Timer
37_Timer&Counter1
38_Timer&Counter2
39_99s_Clock
40_Di-Di_Alarm
41_Door_Bell
42_Alarm
43_Counter_Design
44_External_Interrupt
45_Numb_LED
46_Graph_LED
47_LED_Display
48_Cymometer
49_Serial_to_Parallel
50_Parallel_to_Serial
51_Serial_Communication
52_8X8_Matrix_LED
53_ADC0808_Basic
54_Digital_Voltmeter
55_Temperatuer_Monitor
56_AD_Convert
57_Electronic_Organ
58_Turn_Lamp
59_Trafic_Lamp
60_PWM
61_Digital_Clock_1
62_Digital_Clock_2
63_Number_Input
64_Calculator
65_Key_Lock_1
66_Key_Lock_2
67_EEPROM
68_I2C
69_DC_Motor
70_Step_Motor
全部資料51hei下載地址(共50個(gè)仿真工程與單片機(jī)源碼):
51Proteus仿真例程.rar (2.74 MB, 下載次數(shù): 33)
