查看: 2717|回復(fù): 2
小白求解單片機(jī)DS12C887電子鐘問題 傳輸?shù)臅r(shí)間是錯(cuò)誤的
我最近在做用單片機(jī)和DS12C887做一個(gè)電子鐘,想將電子鐘的間通過串口調(diào)試助手傳輸?shù)诫娔X上,但是傳輸過程中遇到了點(diǎn)問題,如圖:
傳輸?shù)臅r(shí)間是錯(cuò)誤的,請(qǐng)問這是哪里出錯(cuò)了?
我剛學(xué)單片機(jī)一個(gè)月,不太明白,希望各位可以指點(diǎn)一二
ID:289819 發(fā)表于 2018-3-9 21:04 | 只看該作者
程序代碼如下:
#include<reg52.h>
#include<stdio.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit s1=P3^0;//功能鍵
sbit s2=P3^1;//增加鍵
sbit s3=P3^2;//減小鍵
sbit s4=P3^6;//鬧鐘查看鍵
sbit rd=P3^7;
sbit beep=P2^3;//蜂鳴器
sbit dscs=P1^4;
sbit dsas=P1^5;
sbit dsrw=P1^6;
sbit dsds=P1^7;
sbit dsirq=P3^3;
unsigned char flag_ser,flag_a,b,c;//串口中斷標(biāo)志
unsigned char a;//串口中斷中讀取SBUF的值
bit flag1,flag_ri;//定義兩個(gè)位變量
uchar count,s1num,flag,t0_num;//其它變量定義
char miao,shi,fen,year,month,day,week,amiao,afen,ashi;
uchar code table[]=" 20  -  -      ";//液晶固定顯示內(nèi)容
uchar code table1[]="      :  :  ";
void write_ds(uchar,uchar);//寫ds12C887函數(shù)
void set_alarm(uchar,uchar,uchar);
void read_alarm();//讀取ds12C887鬧鐘值
void delay(uint z);//延時(shí)函數(shù)
void di();//蜂鳴器報(bào)警聲音
void write_com(uchar com);//寫液晶命令函數(shù)
void write_date(uchar date);//寫液晶數(shù)據(jù)函數(shù)
void init();//初始化函數(shù)
uchar read_ds(uchar);//讀ds12C887函數(shù)
void set_time();//設(shè)置上電默認(rèn)時(shí)間函數(shù)
void write_sfm(uchar add,char date);//寫時(shí)分秒數(shù)據(jù)函數(shù)
void write_nyr(uchar add,char date);//寫年月日數(shù)據(jù)函數(shù)
void write_week(char we);//寫液晶星期顯示函數(shù)
void keyscan();//鍵盤掃描函數(shù)
void main()//主函數(shù)
        init();//調(diào)用初始化函數(shù)
                keyscan();//按鍵掃描
                if(flag_ri==1)//當(dāng)鬧鐘中斷時(shí)進(jìn)入這里
                        di();
                        delay(100);
                        di();
                        delay(500);
                if(flag==0&&flag1==0)//正常工作時(shí)進(jìn)入這里
                        keyscan();//按鍵掃描
                        year=read_ds(9);//讀取12C887數(shù)據(jù)
                        month=read_ds(8);
                        day=read_ds(7);
                        week=read_ds(6);
                        shi=read_ds(4);
                        fen=read_ds(2);
                        miao=read_ds(0);
                        write_sfm(10,miao);//送液晶顯示
                        write_sfm(7,fen);
                        write_sfm(4,shi);
                        write_week(week);
                        write_nyr(3,year);
                        write_nyr(6,month);
                        write_nyr(9,day);
                        while(flag_ser==1)
                        {        flag_ser=0;
                                ES=0;
                                TI=1;
                                switch(flag_a)
                                        case 0:a=shi;
                                                        printf("THE hour IS %d\n",a);
                                                        break;
                                        case 1:a=fen;
                                                        printf("THE minute IS %d\n",a);
                                                        break;
                                        case 2:a=miao;
                                                        printf("THE second IS %d\n",a);
                                                        break;
                                while(!TI);
                                TI=0;
                                ES=1;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void di()
        beep=0;
        delay(100);
        beep=1;
        rs=0;
        lcden=0;
        P0=com;
        delay(3);
        lcden=1;
        delay(3);
        lcden=0;
        rs=1;
        lcden=0;
        P0=date;
        delay(3);
        lcden=1;
        delay(3);
        lcden=0;
void init()
        uchar num;
        TMOD=0X20;//定時(shí)器1工作方式2
        TH1=0XFD;//波特率9600時(shí)所裝初值
        TL1=0XFD;
        ES=1;
//        SM0=0;
//        SM1=1;
//        REN=1;
        TR1=1;
        SCON=0X50;
        EA=1;//打開總中斷
        EX1=1;//開外部中斷1
        IT1=1;//設(shè)置負(fù)跳變沿觸發(fā)中斷
        flag1=0;//變量初始化
        t0_num=0;
        s1num=0;
        week=1;
        dula=0;//關(guān)閉數(shù)碼管顯示
        wela=0;
        lcden=0;
        rd=0;
/*以下幾行在首次設(shè)置DS12C887時(shí)使用,以后不必再寫入*/
//        write_ds(0x0A,0x20);//打開振蕩器
//        write_ds(0x0B,0x26);//設(shè)置24小時(shí)模式,數(shù)據(jù)二進(jìn)制格式
                                                //開啟鬧鈴中斷
//        set_time();//設(shè)置上電默認(rèn)時(shí)間
        write_com(0x38);//1602液晶初始化
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)//寫入液晶固定部分顯示
                        write_date(table[num]);
                        delay(1);
        write_com(0x80+0x40);
        for(num=0;num<11;num++)
                        write_date(table1[num]);
                        delay(1);
{//1602液晶刷新時(shí)分秒函數(shù)4為時(shí),7為分,10為秒
        char shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
{//1602液晶刷新年月日函數(shù)3為年,6為分,9為秒
        char shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+add);
        write_com(0x80+12);
        switch(we)
                case 1:        write_date('M');delay(5);
                                write_date('O');delay(5);
                                write_date('N');
                                break;
                case 2:        write_date('T');delay(5);
                                write_date('U');delay(5);
                                write_date('E');
                                break;
                case 3:        write_date('W');delay(5);
                                write_date('E');delay(5);
                                write_date('D');
                                break;
                case 4:        write_date('T');delay(5);
                                write_date('H');delay(5);
                                write_date('U');
                                break;
                case 5:        write_date('F');delay(5);
                                write_date('R');delay(5);
                                write_date('I');
                                break;
                case 6:        write_date('S');delay(5);
                                write_date('A');delay(5);
                                write_date('T');
                                break;
                case 7:        write_date('S');delay(5);
                                write_date('N');
                                break;
void keyscan()
        if(flag_ri==1)
        {//這里用來取消鬧鐘報(bào)警,任一鍵取消報(bào)警
                if((s1==0)||(s2==0)||(s3==0)||(s4==0))
                        delay(5);
                                while(!(s1&&s2&&s3&&s4));
              //  di();
                                flag_ri=0;//清除報(bào)警標(biāo)志
        if(s1==0)//檢測(cè)S1
                delay(5);
                if(s1==0)
                        s1num++;//記錄按下次數(shù)
                        if(flag1==1)
                                if(s1num==4)
                                        s1num=1;
                        flag=1;
                        while(!s1);//di();
                        switch(s1num)
                        {//光標(biāo)閃爍點(diǎn)定位
                                case 1: write_com(0x80+0x40+10);
                                            write_com(0x0f);
                                                break;
                                case 2: write_com(0x80+0x40+7);
                                                break;
                                case 3: write_com(0x80+0x40+4);
                                                break;
                                case 4: write_com(0x80+12);
                                                break;
                                case 5: write_com(0x80+9);
                                                break;
                                case 6: write_com(0x80+6);
                                                break;
                                case 7: write_com(0x80+3);
                                                break;
                                case 8: s1num=0;
                                                write_com(0x0c);
                                                flag=0;
                                                write_ds(0,miao);
                                                write_ds(2,fen);
                                                write_ds(4,shi);
                                                write_ds(6,week);
                                                write_ds(7,day);
                                                write_ds(8,month);
                                                write_ds(9,year);
                                                break;
        if(s1num!=0)//只有當(dāng)S1按下后,才檢測(cè)S2和S3
                if(s2==0)
                        delay(1);
                        if(s2==0)
                                while(!s2);//di();
                                switch(s1num)
                                {//根據(jù)功能鍵次數(shù)調(diào)節(jié)相應(yīng)數(shù)值
                                        case 1:        miao++;
                                                        if(miao==60)
        miao=0;
                                                        write_sfm(10,miao);
                                                        break;
                                        case 2:        fen++;
                                                        if(fen==60)
        fen=0;
                                                        write_sfm(7,fen);
                                                        break;
                                        case 3:        shi++;
                                                        if(shi==24)
        shi=0;
                                                        write_sfm(4,shi);
                                                        break;
                                        case 4:        week++;
                                                        if(week==8)
        week=1;
                                                        write_week(week);
                                                        write_com(0x80+12);
                                                        break;
                                        case 5:        day++;
                                                        if(day==32)
        day=1;
                                                        write_nyr(9,day);
                                                        write_com(0x80+9);
                                                        break;
                                        case 6:        month++;
                                                        if(month==13)
        month=1;
                                                        write_nyr(6,month);
                                                        write_com(0x80+6);
                                                        break;
                                        case 7:        year++;
                                                        if(year==100)
        year=0;
                                                        write_nyr(3,year);
                                                        write_com(0x80+3);
                                                        break;
                if(s3==0)
                        delay(1);
                        if(s3==0)
                                while(!s3);//di();
                                switch(s1num)
                                        case 1:        miao--;
                                                        if(miao==-1)
        miao=59;
                                                        write_sfm(10,miao);
                                                        break;
                                        case 2:        fen--;
                                                        if(fen==-1)
        fen=59;
                                                        write_sfm(7,fen);
                                                        break;
                                        case 3:        shi--;
                                                        if(shi==-1)
        shi=23;
                                                        write_sfm(4,shi);
                                                        break;
                                        case 4:        week--;
                                                        if(week==0)
        week=7;
                                                        write_week(week);
                                                        write_com(0x80+12);
                                                        break;
                                        case 5:        day--;
                                                        if(day==0)
        day=31;
                                                        write_nyr(9,day);
                                                        write_com(0x80+9);
                                                        break;
                                        case 6:        month--;
                                                        if(month==0)
        month=12;
                                                        write_nyr(6,month);
                                                        write_com(0x80+6);
                                                        break;
                                        case 7:        year--;
                                                        if(year==-1)
        year=99;
                                                        write_nyr(3,year);
                                                        write_com(0x80+3);
                                                        break;
        if(s4==0)//檢測(cè)S4
                delay(5);
                if(s4==0)
                        flag1=~flag1;
                        while(!s4);//di();
                        if(flag1==0)
                        {//退出鬧鐘設(shè)置時(shí)保存數(shù)值
                                flag=0;
                                write_date(' ');
                                write_date(' ');
                                write_com(0x0c);
                                write_ds(1,miao);
                                write_ds(3,fen);
                                write_ds(5,shi);
                        {//進(jìn)入鬧鐘設(shè)置
                                read_alarm();//讀取原始數(shù)據(jù)
                                miao=amiao;//重新賦值用以按鍵調(diào)節(jié)
                                fen=afen;
                                shi=ashi;
                                write_date('N');//顯示鬧鐘標(biāo)志
                                write_date('Z');
                                write_com(0x80+0x40+3);
                                write_sfm(4,ashi);//送液晶顯示鬧鐘時(shí)間
                                write_sfm(7,afen);
                                write_sfm(10,amiao);
void write_ds(uchar add,uchar date)
        dscs=0;
        dsas=1;
        dsds=1;
        dsrw=1;
        P0=add;//先寫地址
        dsas=0;
        dsrw=0;
        P0=date;//再寫數(shù)據(jù)
        dsrw=1;
        dsas=1;
        dscs=1;
uchar read_ds(uchar add)
        uchar ds_date;
        dsas=1;
        dsds=1;
        dsrw=1;
        dscs=0;
        P0=add;//先寫地址
        dsas=0;
        dsds=0;
        P0=0xff;
        ds_date=P0;//再讀數(shù)據(jù)
        dsds=1;
        dsas=1;
        dscs=1;
        return ds_date;
/*---首次操作12C887時(shí)給予寄存器初始化---*/
void set_time()
        write_ds(0,0);
        write_ds(1,0);
        write_ds(2,0);
        write_ds(3,0);
        write_ds(4,0);
        write_ds(5,0);
        write_ds(6,0);
        write_ds(7,0);
        write_ds(8,0);
        write_ds(9,0);
void read_alarm()
        amiao=read_ds(1);
        afen=read_ds(3);
        ashi=read_ds(5);
void exter() interrupt 2//外部中斷1服務(wù)程序
{        uchar c; //進(jìn)入中斷表示鬧鐘時(shí)間到,
        flag_ri=1; //設(shè)置標(biāo)志位,用以大程序中報(bào)警提示
        c=read_ds(0x0c);//讀取12C887的C寄存器表示響應(yīng)了中斷
void ser() interrupt 4 //串口中斷
        RI=0;
        a=SBUF;
        flag_ser=1;
        if(a==1)
        flag_a=0;
        else if(a==2)
        flag_a=1;
        flag_a=2;
ID:289819 發(fā)表于 2018-3-9 21:06 | 只看該作者
開發(fā)板是用的郭天祥的TX-1C,單片機(jī)顯示的時(shí)間正確無誤
