查看: 2342|回復(fù): 0
lcd液晶時(shí)鐘,附帶鬧鐘,日歷
ID:289354 發(fā)表于 2018-3-8 19:53 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uchar shi=0,fen=0,miao=0,ri=7,yue=1,Z=1,Y=1,i,K1num;
uint nian=2015;
uchar count_10ms,K1num;
sbit rs=P2^4;
sbit rw=P2^5;
sbit lcden=P2^6;
sbit    K1=P1^1;
sbit    K2=P1^2;
sbit    K3=P1^3;
sbit    K4=P1^4;
sbit  BEEP=P3^7;
void delay(uint x)  //????
    uint a,b;
    for(a=x;a>0;a--)
        for(b=10;b>0;b--);
void  bi(uint t)//????
    int c,n;
    for(c=0;c<t;c++)
    for(n=0;n<50;n++);
    BEEP=~BEEP;
//return(t);
void write_com(uchar com)//    1602????
    P0=com;
    rs=0;
    rw=0;
    lcden=0;
    delay(10);
    lcden=1;
    delay(10);
    lcden=0;
void write_date(uchar date)//1602?????
    P0=date;
    rs=1;
    rw=0;
    lcden=0;
    delay(10);
    lcden=1;
    delay(10);
    lcden=0;
void beep()//??
  BEEP=0;
  delay(100);
  BEEP=1;
  delay(100);
void naozhong()//??
  if((Z==shi)&(Y==fen)&(miao<20))
  {  bi(90);
     bi(120); }
void shijian(uint t,add )
if (t>100)
  uchar a,b,c,d;
  a=t/1000+0x30;
  b=t/100%10+0x30;
  c=t/10%10+0x30;
  d=t%10+0x30;
  write_com(add);
  write_date( a);
  write_date( b);
  write_date( c);
  write_date( d);
  uchar m=0,n=0;
    m=t/10+0x30;
    n=t%10+0x30;
    write_com(add);
    write_date( m);
    write_date( n);
void LCD_disp()
    shijian(shi,0x80+0 );
    write_com(0x80+2);
    write_date(0x3a);
    shijian(fen,0x80+3 );
    write_date(0x3a);
    shijian(miao,0x80+6 );
    write_date( 0x2d);
    write_date( 0x2d);
    write_date( 0x2d);
    shijian(Z,0x80+11 );
    write_date(0x3a);
    shijian(Y,0x80+14 );
    shijian(nian,0xc0+0 );
    write_date( 0x2d);
    shijian(yue,0xc0+5 );
    write_date( 0x2d);
    shijian(ri,0xc0+8 );
void init()// 1602?????
    write_com(0x38);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
void timer1_init()//?????
  TMOD=0x01;
  TH0=0x4c;TL0=0x00;
  EA=1;ET0=1;
  TR0=1;
void timer0() interrupt 1 using 0// ??
  TH0=0x4c;TL0=0x00;
  count_10ms++;
  if (count_10ms==20 )
    count_10ms=0;
    miao++;
      if ( miao==60)
          miao=0;
        fen++;
        if ( fen==60)
          fen=0;
          shi++;
          if (shi==24)
              shi=0;
              if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
                { ri++;if (ri==32)  {ri=1;yue++;if ( yue==13) { nian++;yue=1;}} }
              else if(yue==4||yue==6||yue==9||yue==11)
                { ri++;if (ri==31)  {ri=1;yue++; if ( yue==13) { nian++;yue=1;}} }
              else if(yue==2)
                  if((!(nian%4)&&(nian%100))|| !(nian%400))
                      { ri++;if (ri==30)  {ri=1; yue++; if ( yue==13) { nian++;yue=1;}} }
                      { ri++;if (ri==29)  {ri=1; yue++; if ( yue==13) { nian++;yue=1;}} }
void keycan()//????
if( K1==0    )  //?????
    K1num++; delay(1);
    if( K1==0 )
          while(!K1);
          bi(200);
          if( K1num==1 ) {TR0=0; write_com(0x80+0); write_com(0x0f);}
          if( K1num==2 ) {write_com(0x80+3); write_com(0x0f);  }
          if( K1num==3 ) {write_com(0x80+6); write_com(0x0f);  }
          if( K1num==4 ) {write_com(0x80+11); write_com(0x0f);  }
          if( K1num==5 ) {write_com(0x80+14); write_com(0x0f);  }
          if( K1num==6 ) {write_com(0xc0+3); write_com(0x0f);  }
          if( K1num==7 ) {write_com(0xc0+6); write_com(0x0f);  }
          if( K1num==8 ) {write_com(0xc0+9); write_com(0x0f);  }
          if( K1num==9 ) { K1num=0; write_com(0x0c); TR0=1; }
  if( K1num!=0 )       //????
      if( K2==0    )
        delay(1);
        if( K2==0)
            while(!K2);
            bi(200);
            if( K1num==1 ) { shi++;  if(  shi==24 )  shi=0;shijian(shi,0x80+0 ); write_com(0x80);  }
            if( K1num==2 ) { fen++;    if(  fen==60 )  fen=0; shijian(fen,0x80+3 );write_com(0x80+3);  }
            if( K1num==3 ) { miao++;    if( miao==60 )  miao=0;shijian(miao,0x80+6 );write_com(0x80+6);    }
            if( K1num==4 ) {  Z++;    if(    Z==24 )    Z=0;shijian(Z,0x80+11 ); write_com(0x80+11);  }
            if( K1num==5 ) {  Y++;    if(    Y==60 )    Y=0;shijian(Y,0x80+14);  write_com(0x80+14);  }
            if( K1num==6 ) { nian++;    if( nian==2999 )  nian=2015; shijian(nian,0xc0+0 );write_com(0xc0+0);  }
            if( K1num==7 ) {  yue++;    if(    yue==13 )    yue=1; shijian(yue,0xc0+5 ); write_com(0xc0+5);  }
            if( K1num==8 ) {  ri++;
                                { if (ri==32)  {ri=1;} }
                                { if (ri==31)  {ri=1;} }
                              else if(yue==2)
                                      { if (ri==30)  {ri=1; } }
                                      { if (ri==29)  {ri=1;} }
                                shijian(ri,0xc0+8);  write_com(0xc0+8);
    if(K1num!=0)        // ????
      if(K3==0  )
        delay(1);
        if(K3==0  )
            while(!K3);
            bi(200);
            if( K1num==1 ) {shi--;    if(  shi==-1 )  shi=23;shijian(shi,0x80+0 );write_com(0x80);  }
            if( K1num==2 ) { fen--;    if(  fen==-1 )  fen=59; shijian(fen,0x80+3 );write_com(0x80+3);  }
            if( K1num==3 ) { miao--;  if( miao==-1 )  miao=59;  shijian(miao,0x80+6 );write_com(0x80+6);  }
            if( K1num==4 ) {  Z--;  if(    Z==-1 )    Z=23; shijian(Z,0x80+11 );write_com(0x80+11);  }
            if( K1num==5 ) {  Y--;      if(    Y==-1 )    Y=59;shijian(Y,0x80+14);write_com(0x80+14);  }
            if( K1num==6 ) { nian--;  if( nian==1000 )  nian=2015;shijian(nian,0xc0+0 );write_com(0xc0+0);    }
            if( K1num==7 ) {  yue--;    if(    yue==0 )    yue=12; shijian(yue,0xc0+5 ); write_com(0xc0+5);  }
            if( K1num==8 ) {  ri--;
                                { if (ri==0)  {ri=31;} }
                                { if (ri==0)  {ri=30;} }
                              else if(yue==2)
                                      { if (ri==0)  {ri=29; } }
                                      { if (ri==0)  {ri=28;} }
                        if(K4==0)
                                delay(20);
                                 if(K4==0)
                                                K1num=0; TR0=1;
                        if(K1num==0)
                         LCD_disp();
void main ()
  init();
  timer1_init();
  keycan();
  naozhong();
