- #include <msp430x14x.h>
- #include "BoardConfig.h"
- #include "UART.h"
- #include "I2C.h"
- #include "AD7148.h"
- /*********************主函數(shù)模塊***********************************
- * 名稱(chēng):main
- * 功能:串口設(shè)置->7148設(shè)置->引發(fā)中斷
- int main( void )
- //unsigned char j,i,aaa[]="\nHello World!";
- // Stop watchdog timer to prevent time out reset
- WDTCTL = WDTPW + WDTHOLD;
- Sys_Ini();
- ini_uart();
- _EINT(); //打開(kāi)串口
- starti2c();
- //第一步設(shè)置
- SETUP_7148_a(0x00,0x80,0x00,0x02);
- SETUP_7148_a(0x00,0x81,0x10,0x00);
- SETUP_7148_a(0x00,0x82,0x01,0x00);
- SETUP_7148_a(0x00,0x83,0x18,0x18);
- SETUP_7148_a(0x00,0x84,0x00,0x00);
- SETUP_7148_a(0x00,0x85,0xff,0xff);
- SETUP_7148_a(0x00,0x86,0xff,0xff);
- SETUP_7148_a(0x00,0x87,0x00,0x00);
- //Stage1
- SETUP_7148_a(0x00,0x88,0x00,0x08);
- SETUP_7148_a(0x00,0x89,0x10,0x00);
- SETUP_7148_a(0x00,0x8a,0x01,0x00);
- SETUP_7148_a(0x00,0x8b,0x18,0x18);
- SETUP_7148_a(0x00,0x8c,0x00,0x00);
- SETUP_7148_a(0x00,0x8d,0xff,0xff);
- SETUP_7148_a(0x00,0x8e,0xff,0xff);
- SETUP_7148_a(0x00,0x8f,0x00,0x00);
- //Stage2
- SETUP_7148_a(0x00,0x90,0x00,0x20);
- SETUP_7148_a(0x00,0x91,0x10,0x00);
- SETUP_7148_a(0x00,0x92,0x01,0x00);
- SETUP_7148_a(0x00,0x93,0x18,0x18);
- SETUP_7148_a(0x00,0x94,0x00,0x00);
- SETUP_7148_a(0x00,0x95,0xff,0xff);
- SETUP_7148_a(0x00,0x96,0xff,0xff);
- SETUP_7148_a(0x00,0x97,0x00,0x00);
- //Stage3
- SETUP_7148_a(0x00,0x98,0x00,0x80);
- SETUP_7148_a(0x00,0x99,0x10,0x00);
- SETUP_7148_a(0x00,0x9a,0x02,0x01);
- SETUP_7148_a(0x00,0x9b,0x18,0x18);
- SETUP_7148_a(0x00,0x9c,0x00,0x00);
- SETUP_7148_a(0x00,0x9d,0xff,0xff);
- SETUP_7148_a(0x00,0x9e,0xff,0xff);
- SETUP_7148_a(0x00,0x9f,0x00,0x00);
- //Stage4
- SETUP_7148_a(0x00,0xa0,0x02,0x00);
- SETUP_7148_a(0x00,0xa1,0x10,0x00);
- SETUP_7148_a(0x00,0xa2,0x01,0x00);
- SETUP_7148_a(0x00,0xa3,0x18,0x18);
- SETUP_7148_a(0x00,0xa4,0x00,0x00);
- SETUP_7148_a(0x00,0xa5,0xff,0xff);
- SETUP_7148_a(0x00,0xa6,0xff,0xff);
- SETUP_7148_a(0x00,0xa7,0x00,0x00);
- //Stage5
- SETUP_7148_a(0x00,0xa8,0x08,0x00);
- SETUP_7148_a(0x00,0xa9,0x10,0x00);
- SETUP_7148_a(0x00,0xaa,0x01,0x00);
- SETUP_7148_a(0x00,0xab,0x18,0x18);
- SETUP_7148_a(0x00,0xac,0x00,0x00);
- SETUP_7148_a(0x00,0xad,0xff,0xff);
- SETUP_7148_a(0x00,0xae,0xff,0xff);
- SETUP_7148_a(0x00,0xaf,0x00,0x00);
- //Stage6
- SETUP_7148_a(0x00,0xb0,0x20,0x00);
- SETUP_7148_a(0x00,0xb1,0x10,0x00);
- SETUP_7148_a(0x00,0xb2,0x01,0x00);
- SETUP_7148_a(0x00,0xb3,0x18,0x18);
- SETUP_7148_a(0x00,0xb4,0x00,0x00);
- SETUP_7148_a(0x00,0xb5,0xff,0xff);
- SETUP_7148_a(0x00,0xb6,0xff,0xff);
- SETUP_7148_a(0x00,0xb7,0x00,0x00);
- //Stage7
- SETUP_7148_a(0x00,0xb8,0x00,0x00);
- SETUP_7148_a(0x00,0xb9,0x10,0x02);
- SETUP_7148_a(0x00,0xba,0x02,0x00);
- SETUP_7148_a(0x00,0xbb,0x18,0x18);
- SETUP_7148_a(0x00,0xbc,0x00,0x00);
- SETUP_7148_a(0x00,0xbd,0xff,0xff);
- SETUP_7148_a(0x00,0xbe,0xff,0xff);
- SETUP_7148_a(0x00,0xbf,0x00,0x00);
- //第二步設(shè)置
- SETUP_7148_a(0x00,0x00,0x00,0x72);
- SETUP_7148_a(0x00,0x01,0x00,0x00);
- SETUP_7148_a(0x00,0x02,0x32,0x30);
- SETUP_7148_a(0x00,0x03,0x04,0x19);
- SETUP_7148_a(0x00,0x04,0x08,0x32);
- SETUP_7148_a(0x00,0x05,0x00,0x00);
- SETUP_7148_a(0x00,0x06,0x00,0x00);
- SETUP_7148_a(0x00,0x07,0x00,0xff);
- //第三步設(shè)置
- SETUP_7148_a(0x00,0x01,0x00,0xff);
- key_init();
- __enable_interrupt(); //開(kāi)啟總中斷,這一步?jīng)]有的話(huà),所有的中斷都不能觸發(fā)
- while(1)
- dat[0] =0;
- dat[1] =0;
- sendbyte_uart(0xa1);
- sendbyte_uart(0xa5);
- get7148value(&MRD[1],&MRD[0],0x00,0x0b);
- get7148value(&MRD[1],&MRD[0],0x00,0x0c);
- get7148value(&MRD[1],&MRD[0],0x00,0x0d);
- get7148value(&MRD[1],&MRD[0],0x00,0x0e);
- get7148value(&MRD[1],&MRD[0],0x00,0x0f);
- get7148value(&MRD[1],&MRD[0],0x00,0x10);
- get7148value(&MRD[1],&MRD[0],0x00,0x11);
- get7148value(&MRD[1],&MRD[0],0x00,0x12);
- sendbyte_uart(dat[0]);
- sendbyte_uart(dat[1]);
- delay(1);
