網(wǎng)上找來的,大家共享!MAX7219級聯(lián)程序和驅(qū)動程序
- //單片機晶振12M
- //顯示0-9中國
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define count 20 //級聯(lián)個數(shù)
- //定義Max7219端口
- sbit Max7219_pinCLK = P2^2;
- sbit Max7219_pinCS = P2^1;
- sbit Max7219_pinDIN = P2^0;
- uchar code disp1[20][8]=
- {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
- {0x10,0x30,0x50,0x10,0x10,0x10,0x10,0x38},//1
- {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
- {0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
- {0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x00},//4
- {0x0,0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C},//5
- {0x0,0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C},//6
- {0x0,0x3E,0x22,0x4, 0x8, 0x8, 0x8, 0x8},//7
- {0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
- {0x3E,0x22,0x22,0x3E,0x2,0x2,0x3E,0x00},//9
- {0x0,0x8,0x14,0x22,0x3E,0x22,0x22,0x22},//A
- {0x0,0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C},//B
- {0x0,0x3C,0x40,0x40,0x40,0x40,0x40,0x3C},//C
- {0x0,0x7C,0x42,0x42,0x42,0x42,0x42,0x7C},//D
- {0x7C,0x40,0x40,0x7C,0x40,0x40,0x7c,0x00},//E
- {0x00,0x7C,0x40,0x40,0x7C,0x40,0x40,0x40},//F
- {0x00,0x3C,0x40,0x40,0x40,0x44,0x44,0x3C},//G
- {0x00,0x44,0x44,0x44,0x7C,0x44,0x44,0x44},//H
- {0x00,0x10,0xFE,0x92,0x92,0xFE,0x10,0x10},//中
- {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//國
- void Delay_xms(uint x);
- void Write_Max7219_byte(uchar DATA);//寫入一字節(jié)
- void Write_Max7219(uchar address1,uchar dat1,uchar address2,uchar dat2);
- void Init_MAX7219(void);
- // 鎖存進(jìn)相應(yīng)寄存器
- void main(void)
- uchar i,j;
- Delay_xms(50);
- Init_MAX7219();
- while(1)
- // for(i=1;i<9;i++)
- // Write_Max7219(i,disp1[1][i-1],i,disp1[0][i-1]);
- for(i=1;i<9;i++)
- Max7219_pinCS=0;
- for(j=0;j<count;j++)
- Write_Max7219_byte(i); //寫入地址,即數(shù)碼管編號
- Write_Max7219_byte(disp1[count-1-j][i-1]); //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
- _nop_();
- Max7219_pinCS=1;
- Delay_xms(1000);
- /* Write_Max7219(0x09, 0x00,0x09, 0x00); //譯碼方式:BCD碼
- Write_Max7219(0x0a, 0x03,0x0a, 0x03); //亮度
- Write_Max7219(0x0b, 0x07,0x0b, 0x07); //掃描界限;8個數(shù)碼管顯示
- Write_Max7219(0x0c, 0x01,0x0c, 0x01); //掉電模式:0,普通模式:1
- Write_Max7219(0x0f, 0x00,0x0f, 0x00); //顯示測試:1;測試結(jié)束,正常顯示:0
- uchar i;
- Max7219_pinCS=0;
- for(i=0;i<count;i++)
- Write_Max7219_byte(0x09); //譯碼方式:BCD碼
- Write_Max7219_byte(0x00);
- Max7219_pinCS=1;
- _nop_();
- Max7219_pinCS=0;
- Write_Max7219_byte(0x0a); //亮度
- Write_Max7219_byte(0x03);
- Max7219_pinCS=1;
- _nop_();
- Max7219_pinCS=0;
- Write_Max7219_byte(0x0b); // //掃描界限;8個數(shù)碼管顯示
- Write_Max7219_byte(0x07);
- Max7219_pinCS=1;
- _nop_();
- Max7219_pinCS=0;
- Write_Max7219_byte(0x0c); // //掉電模式:0,普通模式:1
- Write_Max7219_byte(0x01);
- Max7219_pinCS=1;
- Max7219_pinCS=0;
- Write_Max7219_byte(0x0f); //顯示測試:1;測試結(jié)束,正常顯示:0
- Max7219_pinCS=1;
- _nop_();
- uchar i;
- Max7219_pinCS=0;
- Write_Max7219_byte(address1); //寫入地址,即數(shù)碼管編號
- Write_Max7219_byte(dat1); //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
- Write_Max7219_byte(address2); //寫入地址,即數(shù)碼管編號
- Write_Max7219_byte(dat2); //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
- _nop_();
- Max7219_pinCS=1;
- //功能:向MAX7219(U3)寫入字節(jié)
- //入口參數(shù):DATA
- //出口參數(shù):無
- //說明:
- uchar i;
- for(i=8;i>=1;i--)
- Max7219_pinCLK=0;
- Max7219_pinDIN=DATA&0x80;
- DATA=DATA<<1;
- Max7219_pinCLK=1;
- uint i,j;
- for(i=0;i<x;i++)
- for(j=0;j<112;j++);
級聯(lián)程序和MAX7219驅(qū)動程序.zip
(58.27 KB, 下載次數(shù): 66)
2018-2-21 14:24 上傳
