密碼鎖的實物圖如下:
照片 1538.jpg (1.82 MB, 下載次數: 88)
2018-2-11 19:02 上傳
2018-2-11 19:01 上傳
電子密碼鎖元件清單 1) 9*15萬用板 2) 17個小按鍵 3) 1602液晶 4) 16p插針 5) 16p單排母座 6) 光敏電阻 7) 104可調電阻 8) 2.2k電阻*2 9) 1k電阻 10) 10k電阻*4 11) 1.5k電阻 12) 103排阻 13) 9012*2 14) 9013 15) 接線端子3p 16) 有源蜂鳴器 17) 40腳座 18) stc89c51單片機 19) 10uf電容 20) 30pf電容*2 21) 自鎖開關 22) 8腳座 23) 24c02芯片 24) 12m晶振 25) Led(5MM紅色) 26) 繼電器 27) DC電源接口 28) 導線若干 29) 焊錫若干 usb電源線(電池盒+DC插頭)
用繼電器輸出可以帶動任意負載
- //包含頭文件
- #include <REG51.h>
- #include<intrins.h>
- //宏定義
- #define LCM_Data P0 //將P0口定義為LCM_Data
- #define uchar unsigned char
- #define uint unsigned int
- //1602的控制腳
- sbit lcd1602_rs=P2^7;
- sbit lcd1602_rw=P2^6;
- sbit lcd1602_en=P2^5;
- sbit Scl=P3^4; //24C02串行時鐘
- sbit Sda=P3^5; //24C02串行數據
- sbit ALAM = P2^3; //報警
- sbit KEY = P3^6; //開鎖
- bit pass=0; //密碼正確標志
- bit ReInputEn=0; //重置輸入允許標志
- bit s3_keydown=0; //3秒按鍵標志位
- bit key_disable=0; //鎖定鍵盤標志
- unsigned char countt0,second; //t0中斷計數器,秒計數器
- void Delay5Ms(void); //聲明延時函數
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
- //液晶顯示數據數組
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
- unsigned char code Correct[] = {" correct "}; //輸入正確
- unsigned char code Error[] = {" error "}; //輸入錯誤
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- unsigned char code SetNew[] = {"SetNewWordEnable"};
- unsigned char code Input[] = {"input: "}; //INPUT
- unsigned char code ResetOK[] = {"ResetPasswordOK "};
- unsigned char code initword[] = {"Init password..."};
- unsigned char code Er_try[] = {"error,try again!"};
- unsigned char code again[] = {"input again "};
- unsigned char InputData[6]; //輸入密碼暫存區(qū)
- unsigned char CurrentPassword[6]={1,3,1,4,2,0}; //管理員密碼(只可在程序中修改)
- unsigned char TempPassword[6];
- unsigned char N=0; //密碼輸入位數記數
- unsigned char ErrorCont; //錯誤次數計數
- unsigned char CorrectCont; //正確輸入計數
- unsigned char ReInputCont; //重新輸入計數
- unsigned char code initpassword[6]={0,0,0,0,0,0}; //輸入管理員密碼后將密碼初始為000000
- //=====================5ms延時==============================
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延時==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //================================24C02========================================================
- void mDelay(uint t) //延時
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- void Nop(void) //空操作
- _nop_(); //僅作延時用一條語句大約1us
- _nop_();
- _nop_();
- _nop_();
- /*****24c02程序參照24c02時序圖*****/
- /*起始條件*/
- void Start(void)
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- /*停止條件*/
- void Stop(void)
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- /*應答位*/
- void Ack(void)
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*反向應答位*/
- void NoAck(void)
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*發(fā)送數據子程序,Data為要求發(fā)送的數據*/
- void Send(uchar Data)
- uchar BitCounter=8;
- uchar temp;
- do
- temp=Data; //將待發(fā)送數據暫存temp
- Scl=0;
- Nop();
- if((temp&0x80)==0x80) //將讀到的數據&0x80
- Sda=1;
- else
- Sda=0;
- Scl=1;
- temp=Data<<1; //數據左移
- Data=temp; //數據左移后重新賦值Data
- BitCounter--; //該變量減到0時,數據也就傳送完成了
- while(BitCounter); //判斷是否傳送完成
- Scl=0;
- /*讀一字節(jié)的數據,并返回該字節(jié)值*/
- uchar Read(void)
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda) //數據位是否為1
- temp=temp|0x01; //為1 temp的最低位為1(|0x01,就是將最低位變?yōu)?)
- else //如果為0
- temp=temp&0xfe; //temp最低位為0(&0xfe(11111110)最低位就是0)
- if(BitCounter-1) //BitCounter減1后是否為真
- temp1=temp<<1; //temp左移
- temp=temp1;
- BitCounter--; //BitCounter減到0時,數據就接收完了
- while(BitCounter); //判斷是否接收完成
- return(temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- //=======================================LCD1602====================================================
- #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
- #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
- //----------------延時函數,后面經常調用----------------------
- void delay(uint xms)//延時函數,有參函數
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- //--------------------------寫指令---------------------------
- void write_1602com(uchar com)//****液晶寫入指令函數****
- lcd1602_rs=0;//數據/指令選擇置為指令
- lcd1602_rw=0; //讀寫選擇置為寫
- P0=com;//送入數據
- delay(1);
- lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
- delay(1);
- lcd1602_en=0;//en由高變低,產生下降沿,液晶執(zhí)行命令
- //-------------------------寫數據-----------------------------
- void write_1602dat(uchar dat)//***液晶寫入數據函數****
- lcd1602_rs=1;//數據/指令選擇置為數據
- P0=dat;//送入數據
- delay(1);
- lcd1602_en=1; //en置高電平,為制造下降沿做準備
- delay(1);
- lcd1602_en=0; //en由高變低,產生下降沿,液晶執(zhí)行命令
- //-------------------------初始化-------------------------
- void lcd_init(void)
- write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
- write_1602com(0x0c);//開顯示不顯示光標
- write_1602com(0x06);//整屏不移動,光標自動右移
- write_1602com(0x01);//清顯示
- //==============將按鍵值編碼為數值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- case (0x11): k=1;break;
- case (0x21): k=2;break;
- case (0x41): k=3;break;
- case (0x81): k='A';break;
- case (0x12): k=4;break;
- case (0x22): k=5;break;
- case (0x42): k=6;break;
- case (0x82): k='B';break;
- case (0x14): k=7;break;
- case (0x24): k=8;break;
- case (0x44): k=9;break;
- case (0x84): k='C';break;
- case (0x18): k='*';break;
- case (0x28): k=0;break;
- case (0x48): k='#';break;
- case (0x88): k='D';break;
- return(k);
- //=====================按鍵檢測并返回按鍵值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0; //確定行線
- i=0;
- P1=a[i]; //精確定位
- while(i<4)
- col=~(P1&0xff); //確定列線
- break; //已定位后提前退出
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0);
- return (row|col); //行線與列線組合后返回
- else return 0; //無鍵按下時返回0
- //=======================一聲提示音,表示有效輸入========================
- void OneAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================二聲提示音,表示操作成功========================
- void TwoAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================三聲提示音,表示錯誤========================
- void ThreeAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //=======================顯示提示輸入=========================
- void DisplayChar(void)
- unsigned char i;
- if(pass==1)
- //DisplayListChar(0,1,LockOpen);
- write_1602com(er); //在二行開始顯示
- for(i=0;i<16;i++)
- write_1602dat(LockOpen[i]); //顯示open 開鎖成功
- else
- if(N==0)
- //DisplayListChar(0,1,Error);
- for(i=0;i<16;i++)
- write_1602dat(Error[i]); //顯示錯誤
- else
- //DisplayListChar(0,1,start_line);
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//顯示開始輸入
- //========================重置密碼==================================================
- void ResetPassword(void)
- unsigned char i;
- unsigned char j;
- if(pass==0)
- pass=0;
- DisplayChar(); //顯示錯誤
- ThreeAlam(); //沒開鎖時按下重置密碼報警3聲
- else //開鎖狀態(tài)下才能進行密碼重置程序
- if(ReInputEn==1) //開鎖狀態(tài)下,ReInputEn置1,重置密碼允許
- if(N==6) //輸入6位密碼
- ReInputCont++; //密碼次數計數
- if(ReInputCont==2) //輸入兩次密碼
- for(i=0;i<6;)
- if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
- i++;
- else //如果兩次的密碼不同
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //顯示錯誤Error
- ThreeAlam(); //錯誤提示
- pass=0; //關鎖
- ReInputEn=0; //關閉重置功能,
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- //DisplayListChar(0,1,ResetOK);
- for(j=0;j<16;j++)
- write_1602dat(ResetOK[j]); //密碼修改成功,顯示
- TwoAlam(); //操作成功提示
- WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else //輸入一次密碼時
- OneAlam();
- //DisplayListChar(0, 1, again); //顯示再次輸入一次
- for(j=0;j<16;j++)
- write_1602dat(again[j]); //顯示再輸入一次
- for(i=0;i<6;i++)
- TempPassword[i]=InputData[i]; //將第一次輸入的數據暫存起來
- N=0; //輸入數據位數計數器清零
- //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
- void Alam_KeyUnable(void)
- P1=0x00;
- ALAM=~ALAM; //蜂鳴器一直閃爍鳴響
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- unsigned char j;
- //DisplayListChar(0, 1, start_line);
- for(j=0;j<16;j++)
- write_1602dat(start_line[j]); //顯示開機輸入密碼界面
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0; //將輸入密碼清零
- KEY=1; //關閉鎖
- ALAM=1; //報警關
- pass=0; //密碼正確標志清零
- ReInputEn=0; //重置輸入充許標志清零
- ErrorCont=0; //密碼錯誤輸入次數清零
- CorrectCont=0; //密碼正確輸入次數清零
- ReInputCont=0; //重置密碼輸入次數清零
- s3_keydown=0;
- key_disable=0; //鎖定鍵盤標志清零
- N=0; //輸入位數計數器清零
- //==========================確認鍵,并通過相應標志位執(zhí)行相應功能===============================
- void Ensure(void)
- unsigned char i,j;
- RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲密碼
- if(N==6)
- if(ReInputEn==0) //重置密碼功能未開啟
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i]) //判斷輸入密碼和24c02中的密碼是否相同
- i++; //相同一位 i就+1
- else //如果有密碼不同
- ErrorCont++; //錯誤次數++
- if(ErrorCont==3) //錯誤輸入計數達三次時,報警并鎖定鍵盤
- for(i=0;i<16;i++)
- do
- Alam_KeyUnable();
- while(1);
- else //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
- TR0=1; //開啟定時
- key_disable=1; //鎖定鍵盤
- pass=0; //pass位清零
- break; //跳出
- if(i==6) //密碼輸入對時
- CorrectCont++; //輸入正確變量++
- if(CorrectCont==1) //正確輸入計數,當只有一次正確輸入時,開鎖
- for(j=0;j<16;j++)
- write_1602dat(LockOpen[j]); //顯示open開鎖畫面
- TwoAlam(); //操作成功提示音
- KEY=0; //開鎖
- pass=1; //置正確標志位
- TR0=1; //開啟定時
- for(j=0;j<6;j++) //將輸入清除
- InputData[i]=0; //開鎖后將輸入位清零
- else //當兩次正確輸入時,開啟重置密碼功能
- //DisplayListChar(0,1,SetNew);
- for(j=0;j<16;j++)
- write_1602dat(SetNew[j]); //顯示重置密碼界面
- ReInputEn=1; //允許重置密碼輸入
- CorrectCont=0; //正確計數器清零
- else //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
- if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
- WrToROM(initpassword,0,6); //強制將初始密碼寫入24C02存儲
- //DisplayListChar(0,1,initword); //顯示初始化密碼
- for(j=0;j<16;j++)
- write_1602dat(initword[j]); //顯示初始化密碼
- TwoAlam(); //成功提示音
- Delay400Ms(); //延時400ms
- N=0; //輸入位數計數器清零
- else //密碼輸入錯誤
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //顯示錯誤信息
- ThreeAlam(); //錯誤提示音
- pass=0;
- else //當已經開啟重置密碼功能時,而按下開鎖鍵,
- //DisplayListChar(0,1,Er_try);
- for(j=0;j<16;j++)
- write_1602dat(Er_try[j]); //錯誤,請重新輸入
- else //密碼沒有輸入到6位時,按下確認鍵時
- for(j=0;j<16;j++)
- pass=0;
- N=0; //將輸入數據計數器清零,為下一次輸入作準備
- //==============================主函數===============================
- void main(void)
- unsigned char KEY,NUM;
- P1=0xFF; //P1口復位
- TMOD=0x11; //定義工作方式
- TL0=0xB0;
- TH0=0x3C; //定時器賦初值
- EA=1; //打開中斷總開關
- ET0=1; //打開中斷允許開關
- TR0=0; //打開定時器開關
- Delay400Ms(); //啟動等待,等LCM講入工作狀態(tài)
- lcd_init(); //LCD初始化
- write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
- for(i=0;i<16;i++)
- write_1602dat(name[i]);//向液晶屏寫開機畫面
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//寫輸入密碼等待界面
- write_1602com(er+9); //設置光標位置
- write_1602com(0x0f); //設置光標為閃爍
- Delay5Ms(); //延時片刻(可不要)
- N=0; //初始化數據輸入位數
- while(1) //進入循環(huán)
- if(key_disable==1) //鎖定鍵盤標志為1時
- Alam_KeyUnable(); //報警鍵盤鎖
- else
- ALAM=1; //關報警
- KEY=keynum(); //讀按鍵的位置碼
- if(KEY!=0) //當有按鍵按下時
- second=0; //秒清零
- else //沒有鎖定鍵盤時
- NUM=coding(KEY); //根據按鍵的位置將其編碼,編碼值賦值給NUM
- switch(NUM) //判斷按鍵值
- case ('A'): ; break;
- case ('B'): ; break;
- case ('C'):
- for(i=0;i<16;i++)
- if(N>=1) N--; OneAlam(); //按鍵提示音
- //DisplayOneChar(6+N,1,'*');
- for(j=N;j<16;j++)
- write_1602com(er+6+j);
- write_1602dat(' ');
51-密碼鎖程序 注釋.zip
(143.94 KB, 下載次數: 195)
2018-2-11 19:01 上傳
下載積分: 黑幣 -5
原理圖.pdf
(46.31 KB, 下載次數: 139)
2018-2-11 19:01 上傳
下載積分: 黑幣 -5
