查看: 2513|回復: 2
stm32 壓力傳感器驅動
ID:283304 發表于 2018-2-9 13:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "stm32l1xx.h"
#include "pressure.h"
#include "string.h"
#define              SCK_HIGH            GPIO_WriteBit(GPIOB,GPIO_Pin_1,Bit_SET)
#define              SCK_LOW             GPIO_WriteBit(GPIOB,GPIO_Pin_1,Bit_RESET)
#define              DT                  GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0)
struct PressureDefine Pressure_Define={0};
void Pressure_Config(struct PressureDefine defines)
        GPIO_InitTypeDef  GPIO_InitStructure;
        struct PressureDefine def = defines;
        memcpy(&Pressure_Define,&defines,sizeof(struct PressureDefine));
        GPIO_InitStructure.GPIO_Pin = def.pin_of_dt;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(def.pin_of_dt_group, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = def.pin_of_sck;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_Init(def.pin_of_sck_group, &GPIO_InitStructure);
unsigned long ReadCount(void)
   unsigned long Count = 0;
         uint8_t i;
         SCK_LOW;
         while(DT);
           for(i=0;i<24;i++)
              SCK_HIGH;
                    Count=Count<<1;
              SCK_LOW;
              if(DT)
                    Count++;
              SCK_HIGH;
              Count=Count^0x800000;
              SCK_LOW;
              return Count;
ID:200458 發表于 2018-3-18 16:23 | 只看該作者
請問下用的是什么壓力傳感器
ID:283304 發表于 2018-10-9 17:38 | 只看該作者
ljw285 發表于 2018-3-18 16:23
請問下用的是什么壓力傳感器
HX711
