查看: 4835|回復: 0
STM32 HALL驅動
ID:282777 發表于 2018-2-7 10:50 | 顯示全部樓層 |閱讀模式
兩種方案:第一種就時STM32每個IO口都用按鍵中斷,你可以犧牲一個定時器,當一個中斷過來就計數,等待下一個中斷進來后兩者的差就得出了一個與速度相關的值,說句實話編碼器沒用過,我用的是HALL接口。這種方法是比較簡單的,
第二種方法就是樓主所說的,定時器里面有hall接口,同時可以捕獲定時器的值,還是以HALL為例,配置好后會每60度(電角度)進入中斷一次,同事進入后捕獲開始,也就是定時器開始計數。計數出來的值就是電機轉過60度的時間(電角度)。配置我會截圖給你,其實還可以計數跑了多少個PWM周期。在PWM中斷里計數。通常他們是這莫做的,應為在FOC中可以簡化運算。不知道你的編碼器是咋樣回事了,但是都應該通用的。
配置如下:
  //GPIO
  GPIO_InitTypeDef  GPIO_InitStructure;
  //Interrupt
  NVIC_InitTypeDef NVIC_InitStructure;
  //Tmer
  TIM_BDTRInitTypeDef  TIM_BDTRInitStructure;           //死區剎車結構體變量定義
  TIM_OCInitTypeDef TIM_OCInitStructure;
  TIM_ICInitTypeDef TIM_ICInitStructure;           //定義結構體變量
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  //---------------------------------TMER3 HALL------------------------------
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_0);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_0);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_0);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  TIM_DeInit(TIM3);
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_OCStructInit(&TIM_OCInitStructure);
  TIM_TimeBaseStructure.TIM_Prescaler = 47;        //TIM基本初始化
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period =65535;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;            //選擇通道1
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //輸入上升沿捕獲
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_TRC ; //配置通道為輸入,并映射到哪里
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;       //輸入捕獲預分頻值
  TIM_ICInitStructure.TIM_ICFilter = 10;                      //輸入濾波器帶寬設置
  TIM_ICInit(TIM3, &TIM_ICInitStructure);                     //輸入通道配置
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;         //TIM輸出通道初始化
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_Pulse =65535;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC4Init(TIM3,&TIM_OCInitStructure);
  TIM_SelectHallSensor(TIM3,ENABLE);                          //使能TIMx的霍爾傳感器接口
  TIM_SelectInputTrigger(TIM3, TIM_TS_TI1F_ED);               //輸入觸發源選擇
  TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);             //從模式選擇
  TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);//主從模式選擇
  //        TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_OC2Ref );//選擇輸出觸發模式(TRGO端)
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;              //開TIM3中斷
  NVIC_InitStructure.NVIC_IRQChannelPriority = 2;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  TIM_ITConfig(TIM3, TIM_IT_Trigger|TIM_IT_CC4, ENABLE);   //開定時器中斷
  TIM_ClearFlag(TIM3, TIM_FLAG_Trigger);
  TIM_ClearFlag(TIM3, TIM_FLAG_CC4);
  TIM_Cmd(TIM3,ENABLE);
//中斷入口。
void TIM3_IRQHandler(void)
  if((TIM_GetFlagStatus(TIM3,TIM_FLAG_Trigger)) != RESET )
    TIM_ClearITPendingBit(TIM3, TIM_FLAG_Trigger);
    HallPLLCtrl();
