查看: 1510|回復: 0
51單片機矩陣鍵盤
ID:282367 發表于 2018-2-5 15:08 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit key1=P3^4;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0};
uchar num,temp;//,num1,beep;
void delay(uint z)
        uint x,y;
        for(x=z; x>0; x--)
                for(y=110; y>0; y--);
uchar keyscan();
void display(uchar aa);
        num=17;
        dula=1;
        P0=0;
        dula=0;
        wela=1;
        P0=0xc0;                                //P0=0;
        wela=0;
                display(keyscan());
        dula=1;
        P0=table[aa-1];
        dula=0;
uchar keyscan()
                        P3=0xfe;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                                switch(temp)
                                                        case 0xee:num=1;
        break;
                                                        case 0xde:num=2;
        break;
                                                        case 0xbe:num=3;
        break;
                                                        case 0x7e:num=4;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                                                        //beep=0;
                         /* dula=1;
                          P0=table[num-1];
                          dula=0;        */
                        P3=0xfd;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                            switch(temp)
                                                        case 0xed:num=5;
        break;
                                                        case 0xdd:num=6;
        break;
                                                        case 0xbd:num=7;
        break;
                                                        case 0x7d:num=8;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                                                //        beep=0;
                /*          dula=1;
                          P0=table[num-1];
                          dula=0;          */
                        P3=0xfb;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                                switch(temp)
                                                        case 0xeb:num=9;
        break;
                                                        case 0xdb:num=10;
        break;
                                                        case 0xbb:num=11;
        break;
                                                        case 0x7b:num=12;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
