單片機(jī)源程序如下:
- #include"lcd.h"
- void Read_Busy() //忙檢測(cè)函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
- unsigned char sta; //
- LCD1602_DB = 0xff;
- LCD1602_RS = 0;
- LCD1602_RW = 1;
- do
- LCD1602_EN = 1;
- sta = LCD1602_DB;
- LCD1602_EN = 0; //使能,用完就拉低,釋放總線(xiàn)
- }while(sta & 0x80);
- void Lcd1602_Write_Cmd(unsigned char cmd) //寫(xiě)命令
- Read_Busy();
- LCD1602_RS = 0;
- LCD1602_RW = 0;
- LCD1602_DB = cmd;
- LCD1602_EN = 1;
- LCD1602_EN = 0;
- void Lcd1602_Write_Data(unsigned char dat) //寫(xiě)數(shù)據(jù)
- Read_Busy();
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- LCD1602_DB = dat;
- LCD1602_EN = 1;
- LCD1602_EN = 0;
- void LcdSetCursor(unsigned char x,unsigned char y) //坐標(biāo)顯示
- unsigned char addr;
- if(y == 0)
- addr = 0x00 + x;
- else
- addr = 0x40 + x;
- Lcd1602_Write_Cmd(addr|0x80);
- //按指定位置顯示一個(gè)字符
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
- X |= 0x80; //算出指令碼
- Lcd1602_Write_Cmd(X); //發(fā)命令字
- Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
- void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
- LcdSetCursor(x,y); //當(dāng)前字符的坐標(biāo)
- while(*str != '\0')
- Lcd1602_Write_Data(*str++);
- void InitLcd1602() //1602初始化
- Lcd1602_Write_Cmd(0x38); //打開(kāi),5*8,8位數(shù)據(jù)
- Lcd1602_Write_Cmd(0x0c);
- Lcd1602_Write_Cmd(0x06);
- Lcd1602_Write_Cmd(0x01); //清屏
