查看: 16666|回復: 25
RFID RC522程序源碼(51單片機可用)
ID:281734 發表于 2018-2-2 15:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
RFID程序(51可用)
詳見附件
單片機源碼:
  1. /**********************RC522實驗開發板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ------------------------------------------------*/
  5. #include <reg52.h>
  6. #include  <STDIO.H>
  7. #include <string.h>
  8. #include "main.h"
  9. #include "mfrc522.h"
  10. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  11. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
  12. //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
  13. unsigned char code data2[4]  = {0,0,0,0x01};
  14. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  15. unsigned char g_ucTempbuf[20];
  16. void delay1(unsigned int z)
  17. {
  18.         unsigned int x,y;
  19.         for(x=z;x>0;x--)
  20.         for(y=110;y>0;y--);
  21. }
  22. void main( )
  23. {
  24.     unsigned char status,i,j;
  25.           unsigned int temp;
  26.      InitializeSystem( );
  27.      PcdReset();
  28.      PcdAntennaOff();
  29.      PcdAntennaOn();
  30.      while ( 1 )
  31.      {
  32.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  33.          if (status != MI_OK)
  34.          {
  35.               InitializeSystem( );
  36.      PcdReset();
  37.      PcdAntennaOff();
  38.      PcdAntennaOn();
  39.                           continue;
  40.          }
  41.
  42.                         printf("卡的類型:");
  43.             for(i=0;i<2;i++)
  44.                                         {
  45.                                                 temp=g_ucTempbuf[i];
  46.                                                 printf("%X",temp);
  47.
  48.                                         }
  49.
  50.          status = PcdAnticoll(g_ucTempbuf);//防沖撞
  51.          if (status != MI_OK)
  52.          {    continue;    }
  53.
  54.                                         ////////以下為超級終端打印出的內容////////////////////////
  55.
  56.                                         printf("卡序列號:");        //超級終端顯示,
  57.                                         for(i=0;i<4;i++)
  58.                                         {
  59.                                                 temp=g_ucTempbuf[i];
  60.                                                 printf("%X",temp);
  61.
  62.                                         }
  63.                                         ///////////////////////////////////////////////////////////
  64.          status = PcdSelect(g_ucTempbuf);//選定卡片
  65.          if (status != MI_OK)
  66.          {    continue;    }
  67.
  68.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  69.          if (status != MI_OK)
  70.          {    continue;    }
  71.
  72.          status = PcdWrite(1, data1);//寫塊
  73.          if (status != MI_OK)
  74.          {    continue;    }
  75. while(1)
  76.                 {
  77.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  78.          if (status != MI_OK)
  79.          {
  80.                   InitializeSystem( );
  81.      PcdReset();
  82.      PcdAntennaOff();
  83.      PcdAntennaOn();
  84.                           continue;
  85.          }
  86.                  status = PcdAnticoll(g_ucTempbuf);//防沖撞
  87.          if (status != MI_OK)
  88.          {    continue;    }
  89.                 status = PcdSelect(g_ucTempbuf);//選定卡片
  90.          if (status != MI_OK)
  91.          {    continue;    }
  92.
  93.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  94.          if (status != MI_OK)
  95.          {    continue;    }
  96.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  97.          if (status != MI_OK)
  98.          {    continue;    }
  99.
  100.          status = PcdBakValue(1, 2);//塊備份
  101.          if (status != MI_OK)
  102.          {    continue;    }
  103.
  104.          status = PcdRead(2, g_ucTempbuf);//讀塊
  105.          if (status != MI_OK)
  106.          {    continue;    }
  107.                 printf("對花:");        //超級終端顯示,
  108.          for(i=0;i<16;i++)
  109.                                         {
  110.                                                 temp=g_ucTempbuf[i];
  111.                                                 printf("%X",temp);
  112.
  113.                                         }
  114.                  printf("\n");
  115.                 LED_GREEN = 0;
  116.             for(i=0;i<250;i++)//先輸出一種頻率的聲音
  117.         {
  118.          for(j=0;j<80;j++);
  119.          Speaker=~Speaker;
  120.         }
  121.                 delay1(100);
  122.                 LED_GREEN = 1;
  123.                 delay1(100);
  124.                 LED_GREEN = 0;
  125.                 delay1(200);
  126.                 LED_GREEN = 1;
  127.                  PcdHalt();
  128.                 }
  129.     }
  130. }
  131. /////////////////////////////////////////////////////////////////////
  132. //系統初始化
  133. /////////////////////////////////////////////////////////////////////
  134. void InitializeSystem()
  135. {
  136. /*        P0M1 = 0x0; P0M2 = 0x0;
  137.         P1M1 = 0x0;        P1M2 = 0x0;
  138.         P3M1 = 0x0; P3M2 = 0xFF;
  139. */        P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  140.          TMOD=0x21;                   //設T0為方式1,GATE=1;
  141.         SCON=0x50;
  142.         TH1=0xF4;          //波特率為2400bps
  143. ……………………
  144. …………限于本文篇幅 余下代碼請從51黑下載附件…………
MFRC522(51可用).zip (65.86 KB, 下載次數: 512)
參與人數 1黑幣 +1 收起 理由
ttland + 1 共享資料的黑幣獎勵!
收藏收藏9 分享淘帖 頂1 踩
來自 5#
ID:449992 發表于 2018-12-19 16:24 | 只看該作者
rc522人員定位系統
rc522人員定位系統.7z
1.28 MB, 下載次數: 60, 下載積分: 黑幣 -5
stm320人員定位
admin + 50 回帖助人的獎勵!
ID:383498 發表于 2018-12-3 13:56 | 只看該作者
有用嗎
ID:375092 發表于 2018-12-5 13:36 | 只看該作者
能夠實現些啥子功能呢樓主,我現在想要扣款,充值,等一些高級一點的程序功能
ID:480303 發表于 2019-2-25 11:30 | 只看該作者
不管咋樣 感謝樓主分享
不管怎么樣 感謝樓主的分享  這樣的例子很好
ID:489048 發表于 2019-3-20 16:12 | 只看該作者
謝謝樓主分享,研究學習一下。
ID:289193 發表于 2019-3-20 17:09 | 只看該作者
牛逼啊
學習一下先
ID:308951 發表于 2019-3-21 08:28 | 只看該作者
這個項目我也做過,我做的門禁系統結合語音的只要在他的主函數里面調用那些寫好的庫就跟STM32標準庫編程時一樣的,然后用顯示屏進行顯示
ID:503143 發表于 2019-4-4 12:54 | 只看該作者
jwl595 發表于 2019-3-21 08:28
這個項目我也做過,我做的門禁系統結合語音的只要在他的主函數里面調用那些寫好的庫就跟STM32標準庫編程時 ...
有資料嗎兄弟
ID:515887 發表于 2019-4-18 22:06 | 只看該作者
有這個下載好的文件嗎?急需急需,剛注冊,積分不夠。有沒有誰下載好了跟我分享一下?
ID:440456 發表于 2019-5-15 21:30 | 只看該作者
我也想下載學習
ID:440456 發表于 2019-5-15 21:46 | 只看該作者
是我想要的
ID:440456 發表于 2019-5-15 21:47 | 只看該作者
ID:540405 發表于 2019-5-17 08:01 | 只看該作者
正在學習中,但愿有用。
ID:588638 發表于 2019-7-25 08:55 | 只看該作者
謝謝lz的分享
ID:384520 發表于 2019-10-19 21:12 | 只看該作者
我只想復制卡 能實現嗎
ID:505153 發表于 2019-11-13 13:52 | 只看該作者
沒看見單片機引腳在哪配置的。
ID:242883 發表于 2019-11-13 16:30 | 只看該作者
感謝分享。
ID:20672 發表于 2019-11-14 12:56 | 只看該作者
啥東西都要學習學習
ID:328790 發表于 2020-1-10 16:06 | 只看該作者
學習下最近在弄這個
ID:505400 發表于 2020-2-16 20:54 | 只看該作者
可以實現什么功能
ID:266164 發表于 2020-5-8 15:54 | 只看該作者
謝謝分享
ID:1005936 發表于 2022-2-21 22:39 | 只看該作者
你好請問stc89c52,晶振是12mhz的板子,程序需要改動嗎?改動的話是只改動定時器的部分嗎?
