#include <stdio.h> #include <absacc.h> #include <reg52.h> #include <math.h> #define uchar unsigned char #define uint unsigned int
//*????? sbit E0=P3^0; //*??P3.0,?EPWM?????? sbit L0=P2^4; sbit K2=P2^2; sbit K1=P2^1; sbit K0=P2^0;
//*????????"0"-"5" uchar code a[6]={0x11,0x12,0x13,0x14,0x15,0x16}; //*IPWM???? uchar code b[6]={0x0c,0x19,0xab,0x32,0x3f,0x4f}; uchar time; uchar period[6]={6000,5938,5875,5813,5750,5688}; uchar high[6]={250,312,375,437,500,562}; int i;
timer0 () interrupt 1 using 1 { TH0=(65536-6250)/256; TL0=(65536-6250)%256; if (++time==high[i])E0=0; else if(time==period[i]) {time=0; E0=1; } }
//*????? void delay(void) { int j; for(j=300;j>0;j--); } main() { TMOD=0X01; TH0=(65536-6250)/256; TL0=(65536-6250)%256; EA=1; ET0=1; TR0=1; i=5; E0=1; //* ????? K0=1; K1=1; K2=0; P0=0; P1=0x10;
delay(); if ((K1==0)&&(K2==1)) {i++; time=period[i];time++; time=high[i]; P0= b[i]; P1= a[i]; } else if ((K2==0)&&(K1==1)) { i--; time=period[i]; time++; time=high[i]; P0= b[i]; P1= a[i]; } if ((K1==0)&&(i<=0)) { i=0; time=period[i];time++; time=high[i]; P0= b[i]; P1= a[i]; } if ((K2==0)&&(i>=5)) { i=5; time=period[i];time++; time=high[i]; P0= b[i]; P1= a[i]; } }
模擬出現 *** error 65: access violation at C:0x0100 : no 'execute/read' permission 方面的錯誤
誰可以幫解決下 然后告訴我相關方法 讓我學習下 cmm_1@163.com QQ:78636072( 晚上在) |
