#include<reg52.h> //包含單片機寄存器的頭文件
sbit p2_0 = p2^0;
sbit p2_1 = p2^1;
sbit p2_2 = p2^2;
sbit p2_3 = p2^3;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
/* 函數(shù)申明 -----------------------------------------------*/
void delay(uint z);
/* 變量定義 ----------------------------------------------*/
sbit key1=P3^5;
sbit key2=P3^4;
sbit key3=P3^3;
sbit key4=P3^2;
void display()
uchar m;
for(m=9;m>0;m--)
p0=table[m];
p2_0 =0;
delay(2000);
p2_0 = 1;
for(m=0;m<10;m++)
p0=table[m];
p2_1=0;
delay(2000);
p2_1= 1;
for(m=9;m>0;m--)
p0=table[m];
p2_2 = 0;
delay(2000);
p2_2 = 1;
for(m=0;m<10;m++)
p0=table[m];
p2_3 = 0;
delay(2000);
p2_3 = 1;
** 函數(shù)名稱 : main(void)
** 函數(shù)功能 : 主函數(shù)
void main(void)
unsigned int a;
P0 = 0;
for(a=100;a>0;a--)
display();
while(1) //無限掃描
if(key1==0)
delay(5); //消抖動
if(key1==0) //確認(rèn)按鍵被按下
while(!key1);//松手檢測
P1=0;
delay(200);
P1=0XFF;
if(key2==0)
delay(5); //消抖動
if(key2==0) //確認(rèn)按鍵被按下
while(!key2);//松手檢測
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
if(key3==0)
delay(5); //消抖動
if(key3==0) //確認(rèn)按鍵被按下
while(!key3);//松手檢測
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
delay(200);
if(key4==0)
delay(5); //消抖動
if(key4==0) //確認(rèn)按鍵被按下
while(!key4);//松手檢測
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
delay(200);
P1=0;
delay(200);
P1=0XFF;
delay(200);
delay(10);
** 函數(shù)名稱 : delay(uint z)
** 函數(shù)功能 : 延時函數(shù)
void delay(uint z)
uint i,j;
for(i=z;i>0;i--)
for(j=110;j>0;j--);
