查看: 2845|回復: 3
stc單片機串口控制led燈的程序有問題
ID:278835 發表于 2018-1-23 10:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 11059200L          //系統頻率
#define BAUD 9600             //串口波特率
#define NONE_PARITY     0       //無校驗
#define ODD_PARITY      1       //奇校驗
#define EVEN_PARITY     2       //偶校驗
#define MARK_PARITY     3       //標記校驗
#define SPACE_PARITY    4       //空白校驗
#define PARITYBIT EVEN_PARITY   //定義校驗位
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr AUXR  = 0x8e;               //輔助寄存器
sfr T2H   = 0xd6;               //定時器2高8位
sfr T2L   = 0xd7;               //定時器2低8位
sfr P_SW1   = 0xA2;             //外設功能切換寄存器1
#define S1_S0 0x40              //P_SW1.6
#define S1_S1 0x80              //P_SW1.7
sbit P22 = P2^2;
sbit P30=P3^0;
bit busy;
BYTE RXtemp;
bit RX_flag=0;                //接收到串口數據標志
//延時函數
void delay(WORD t)
        WORD t1;
        for(;t>0;t--)
                for(t1=0;t1<200;t1++);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
    ACC = P_SW1;
    ACC &= ~(S1_S0 | S1_S1);
    P_SW1 = ACC;
#if (PARITYBIT == NONE_PARITY)
    SCON = 0x50;                //8位可變波特率
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    SCON = 0xda;                //9位可變波特率,校驗位初始為1
#elif (PARITYBIT == SPACE_PARITY)
    SCON = 0xd2;                //9位可變波特率,校驗位初始為0
#endif
    T2L = (65536 - (FOSC/4/BAUD));   //設置波特率重裝值
    T2H = (65536 - (FOSC/4/BAUD))>>8;
    AUXR = 0x14;                //T2為1T模式, 并啟動定時器2
    AUXR |= 0x01;               //選擇定時器2為串口1的波特率發生器
    ES = 1;                     //使能串口1中斷
    EA = 1;
UART 中斷服務程序
void Uart() interrupt 4
    if (RI)
        RI = 0;
                 RXtemp = SBUF;
        switch(RXtemp)
case '1':P30=1;
break;
case '2':P30=0;
break;
}              //清除RI位
    if (TI)
        TI = 0;                 //清除TI位
                    //清忙標志
發送1時,LED燈亮
發送0時,LED無反應這是什么原因,求大家幫忙
ID:97438 發表于 2018-1-24 16:09 | 只看該作者
case '1':P30=1;
break;
case '2':P30=0;
你的程序判斷的是‘1’或者‘2’。。。你發‘0’肯定是沒有反應啊。。。
ID:232681 發表于 2018-1-24 22:49 | 只看該作者
        switch(RXtemp)
case '1':P30=1;
break;
case '2':P30=0;
break;
}              //清除RI位
case 里面只有1和2的懸著,所以0米有反應哦,你可以將case '2':P30=0;改為case '0':P30=0;
ID:292103 發表于 2018-3-15 08:24 | 只看該作者
程序完整嗎
