//用數(shù)碼管的前兩位顯示一個(gè)十進(jìn)制數(shù),變化范圍為0到59,開始時(shí)顯示00
//每按下key1鍵一次,數(shù)值加1;每按下key2鍵,數(shù)值減一,每按下key3鍵一次,數(shù)值歸零;
//每按下key4鍵一次,利用定時(shí)器功能使數(shù)值開始自動(dòng)每秒加1,再次按下key4鍵,數(shù)值停止自動(dòng)加1,保持顯示原數(shù)
#include
#include //定義8255A的絕對(duì)地址時(shí)用,必須包含此庫(kù)函數(shù)
//-----宏聲明-----
#define D8255 XBYTE[0x7f03] //8255控制口地址
#define D8255A XBYTE[0x7f00] //8255 PA口地址
#define D8255B XBYTE[0x7f01] //8255 PB口地址
#define D8255C XBYTE[0x7f02] //8255 PC口地址
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar num0,num;
void delay(uint z)
{uint x,y;
for(x=z;x>0;x--)
for(y=123;y>0;y--);
void display(uchar numdis)
uchar shi,ge;
shi=numdis/10;
ge=numdis%10;
D8255B=0xfe; //PB口送出位選字,初始選十位數(shù)碼管;
D8255A=table[shi] ;
delay(5);
D8255B=0xfd; //PB口送出位選字,初始選中個(gè)位數(shù)碼管;
D8255A=table[ge] ;
delay(5);
void init()
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
void keyscan()
if(key1==0)
delay(10);
if(key1==0)
{ num++;
if(num==60) //到60時(shí)重新歸0
num=0;
while(!key1);//等待按鍵釋放
if(key2==0)
delay(10);
if(key2==0)
if(num==0) //到0時(shí)重新歸60
num=60;
num-- ;
while(!key2);
if(key3==0)
delay(10);
if(key3==0)
num=0; // 清0
while(!key1);
if(key4==0)
delay(10);
if(key4==0)
while(!key4)
TRO=!TR0;
init();
keyscan();
display(num);
void timer0() interrupt 1
num0++;
if(num0==20) //20次計(jì)滿,表示1秒定時(shí)時(shí)間到
num0=0;
num++;
if(num==60)
num=0;
[此貼子已經(jīng)被作者于2010-12-14 16:45:49編輯過(guò)]
