查看: 6504|回復(fù): 0
n76e003單片機(jī)IAP的寫入源程序
ID:272544 發(fā)表于 2018-1-20 17:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
n76e003 IAP的寫入
單片機(jī)源程序如下:
  1. #include <intrins.h>
  2. #include "..\lib\n76e003.h"
  3. #include "..\lib\my.h"
  4. unsigned char xdata UIDBuf[12];                //存儲(chǔ)96bit的UID內(nèi)容
  5. //讀出芯片的96bit的UID
  6. void ReadUID(void)
  7. {
  8.         unsigned char ch;
  9.         TA = 0xaa;
  10.         TA = 0x55;
  11.         CHPCON |= 0x01;                        //使能IAP
  12.
  13.         for (ch=0; ch<0x0c; ch++)
  14.         {
  15.                 IAPAH = 0x00;
  16.                 IAPAL = ch;                        //0x02;
  17.                 IAPCN = 0X04;
  18.
  19.                 TA = 0xaa;
  20.                 TA = 0x55;
  21.                 IAPTRG |= 0x01;
  22.                 UIDBuf[ch] = IAPFD;
  23.         }
  24. //        ch = IAPFD;
  25. //        TA = 0xaa;
  26. //        TA = 0x55;
  27. //        IAPTRG |= 0x01;
  28. /*        TA = 0xaa;
  29.         TA = 0x55;
  30.         IAPUEN |= 0x01;                        //選擇要寫入的區(qū)域 BIT2 -- 1 使能IAP擦除或編程CONFIG  BIT1 -- 1 使能IAP擦除或編程LDROM  BIT0 -- 1 使能IAP擦除或編程APROM
  31.         IAPCN = 0x22;
  32.         IAPAH = 0x10;
  33.         IAPAL = 0x00;
  34.         IAPFD = 0xff;
  35.         TA = 0xaa;
  36.         TA = 0x55;
  37.         IAPTRG |= 0x01;
  38.         IAPCN = 0x21;
  39.         IAPAH = 0x10;
  40.         IAPAL = 0x00;
  41.         IAPFD = 0xaa;
  42.         TA = 0xaa;
  43.         TA = 0x55;
  44.         IAPTRG |= 0x01;
  45.         TA = 0xaa;
  46.         TA = 0x55;
  47.         IAPUEN &= ~0x01;*/
  48.         TA = 0xaa;
  49.         TA = 0x55;
  50.         CHPCON &= ~0x01;
  51. }
  52. bit CompUID(unsigned char code *cp_r)
  53. {
  54.         unsigned char code *cp;
  55.         unsigned char xdata *xp;
  56.         unsigned char xdata tmpx[128];
  57.         unsigned char loop;
  58.         cp = cp_r;                //&UID1;
  59.         xp = &tmpx;
  60.         for (loop=0,B=12; ; )
  61.         {
  62.                 if (*cp == 0xff) loop++;
  63.                 cp++;
  64.                 B--;
  65.                 if (B==0) break;
  66.         }
  67.         cp = cp_r;                //&UID1;
  68.         if (loop>5)                //沒有寫入U(xiǎn)ID,寫入U(xiǎn)ID
  69.         {
  70.                 for (loop=0; loop<12;loop++)
  71.                 {
  72.                         *xp = UIDBuf[loop];
  73.                         xp++;
  74.                         cp++;
  75.                 }
  76.                 for ( ; loop<128; )
  77.                 {
  78.                         *xp = *cp;
  79.                         loop++;
  80.                         xp++;
  81.                         cp++;
  82.                 }
  83.                 TA = 0xaa;
  84.                 TA = 0x55;
  85.                 CHPCON |= 0x01;                        //使能IAP
  86. //                TA = 0xaa;
  87. //                TA = 0x55;
  88. //                IAPTRG |= 0x01;
  89.                 TA = 0xaa;
  90.                 TA = 0x55;
  91.                 IAPUEN |= 0x01;                        //選擇要寫入的區(qū)域 BIT2 -- 1 使能IAP擦除或編程CONFIG  BIT1 -- 1 使能IAP擦除或編程LDROM  BIT0 -- 1 使能IAP擦除或編程APROM
  92.
  93.                 IAPCN = 0x22;                        //APRROM擦除
  94.                 IAPAH = (unsigned char)(((unsigned int)cp_r)/256);                //0x10;
  95.                 IAPAL = (unsigned char)cp_r;                        //0x00;
  96.                 IAPFD = 0xff;
  97.                 TA = 0xaa;
  98.                 TA = 0x55;
  99.                 IAPTRG |= 0x01;                         //執(zhí)行IAP
  100. //APROM寫入
  101.                 xp = &tmpx;
  102.                 for (loop=0; loop<128; loop++)
  103.                 {
  104.                         IAPCN = 0x21;
  105.                         IAPAH = (unsigned char)(((unsigned int)cp_r)/256);                //0x10;
  106.                         IAPAL = loop;        //0x00;
  107.                         IAPFD = *xp;        //0xaa;
  108.                         xp++;
  109.                         TA = 0xaa;
  110.                         TA = 0x55;
  111.                         IAPTRG |= 0x01;
  112.                 }
  113.                 TA = 0xaa;
  114.                 TA = 0x55;
  115.                 IAPUEN &= ~0x01;
  116.
  117.                 TA = 0xaa;
  118. ……………………
  119. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
iap.rar (943 Bytes, 下載次數(shù): 62)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏1 分享淘帖 頂 踩1
無效樓層,該帖已經(jīng)被刪除
