分享一個讀寫正常的基于STM32的AT45DB041源程序
2018-1-18 20:24 上傳
- 文件名 :main.c
- 編寫者 :尚曉飛
- 編寫日期:10月18日
- 簡要描述:AT45DB041讀寫程序
- 當前版本:V1.0
- 運行平臺:STM32F10x
- Copyright (c) 2008-2018, shangxiaofei.
- All rights reserved.
- /*********************** 修改記錄 ******************************************/
- 修改人: 尚曉飛
- 日 期: 2008年10月18日
- 版 本: V1.0
- 描 述: AT45DB041讀寫測試基本正常 ,
- u8 定義unsigned char改為 signed char 可在調試時顯示ASCII碼,方便查看,
- 注意CS,MISO 要接上拉電阻
- /* Includes ------------------------------------------------------------------*/
- #include "platform_config.h"
- #include "spi_flash.h"
- /* Local includes ------------------------------------------------------------*/
- /* Private typedef -----------------------------------------------------------*/
- typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
- /* Private define ------------------------------------------------------------*/
- #define FLASH_WriteAddress 0x01 //9位地址 0 - 263
- #define FLASH_ReadAddress FLASH_WriteAddress
- #define FLASH_SectorToErase FLASH_WriteAddress
- #define M25P64_FLASH_ID 0x202017
- #define BufferSize (countof(Tx_Buffer)-1)
- /* Private macro -------------------------------------------------------------*/
- #define countof(a) (sizeof(a) / sizeof(*(a)))
- /* Private variables ---------------------------------------------------------*/
- u8 Tx_Buffer[] = "STM32F10x communication with an AT45DB041 SPI FLASH";
- u8 Tx_Buffer1[] = "112233445566778899abcdefghifjfkdsajfkdsjakfjdskafjdksajfkdslafj;d";
- u8 Index, Rx_Buffer[BufferSize];
- u8 Rx_Buffer2[BufferSize];
- volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = PASSED;
- vu32 FLASH_ID = 0;
- ErrorStatus HSEStartUpStatus;
- /* Private functions ---------------------------------------------------------*/
- TestStatus Buffercmp(u8* pBuffer1, u8* pBuffer2, u16 BufferLength);
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- * Function Name : main
- * Description : Main program
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- /* System clocks configuration */
- RCC_Configuration();
- /* NVIC configuration */
- NVIC_Configuration();
- /* GPIO configuration */
- GPIO_Configuration();
- /* Initialize the SPI FLASH driver */
- SPI_FLASH_Init();
- SPI_FLASH_Buffer1Write(Tx_Buffer, FLASH_WriteAddress, BufferSize);//寫buffer1
- SPI_FLASH_Buffer1Read(Rx_Buffer, FLASH_WriteAddress, BufferSize); //讀buffer1
- SPI_FLASH_Buffer2Write(Tx_Buffer1, FLASH_WriteAddress, BufferSize);//寫buffer2
- SPI_FLASH_Buffer2Read(Rx_Buffer, FLASH_ReadAddress, BufferSize); //讀buffer2
- SPI_FLASH_Buffer1ProgAutoErase(7);//buffer1寫入flash
- SPI_FLASH_Buffer1ProgAutoErase(8);//buffer1寫入flash
- SPI_FLASH_PageToBuffer2(1); //flash頁讀入buffer
- SPI_FLASH_Buffer1Write(Tx_Buffer1, FLASH_WriteAddress, BufferSize);
- SPI_FLASH_Buffer1Read(Rx_Buffer, FLASH_ReadAddress, BufferSize);
- SPI_FLASH_Buffer2Read(Rx_Buffer2, FLASH_ReadAddress, BufferSize);
- SPI_FLASH_BulkErase(0); //塊擦除
- //SPI_FLASH_PageErase(1);//頁擦除
- SPI_FLASH_PageToBuffer2(7); //flash頁讀入buffer
- SPI_FLASH_PageToBuffer2(8); //flash頁讀入buffer
- while (1)
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if (HSEStartUpStatus == SUCCESS)
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_4);
- /* Enable PLL */
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- while (RCC_GetSYSCLKSource() != 0x08)
- /* Enable GPIO_LED clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_LED, ENABLE);
- * Function Name : GPIO_Configuration
- * Description : Configures the different GPIO ports.
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure GPIO LED pin6 and pin7 as Output push-pull --------------------*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIO_LED, &GPIO_InitStructure);
- * Function Name : NVIC_Configuration
- * Description : Configures Vector Table base location.
- * Input : None
- * Output : None
- * Return : None
- #ifdef VECT_TAB_RAM
- /* Set the Vector Table base location at 0x20000000 */
- NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- #else /* VECT_TAB_FLASH */
- /* Set the Vector Table base location at 0x08000000 */
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- #endif
- * Function Name : Buffercmp
- * Description : Compares two buffers.
- * Input : - pBuffer1, pBuffer2: buffers to be compared.
- * : - BufferLength: buffer's length
- * Output : None
- * Return : PASSED: pBuffer1 identical to pBuffer2
- * FAILED: pBuffer1 differs from pBuffer2
- while (BufferLength--)
- if (*pBuffer1 != *pBuffer2)
- return FAILED;
- pBuffer1++;
AT45DB041讀寫正常V1.0.rar
(45.35 KB, 下載次數: 41)
2018-1-18 16:10 上傳
下載積分: 黑幣 -5
