查看: 1519|回復: 0
環(huán)形buffer的實現(xiàn)
ID:277262 發(fā)表于 2018-1-18 10:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
public class RingBuffer {
    private final static int bufferSize = 1024;
    private String[] buffer = new String[bufferSize];
    private int head = 0;
    private int tail = 0;
    private Boolean empty() {
        return head == tail;
    private Boolean full() {
        return (tail + 1) % bufferSize == head;
    public Boolean put(String v) {
        if (full()) {
            return false;
        buffer[tail] = v;
        tail = (tail + 1) % bufferSize;
        return true;
    public String get() {
        if (empty()) {
            return null;
        String result = buffer[head];
        head = (head + 1) % bufferSize;
        return result;
    public String[] getAll() {
        if (empty()) {
            return new String[0];
        int copyTail = tail;
        int cnt = head < copyTail ? copyTail - head : bufferSize - head + copyTail;
        String[] result = new String[cnt];
        if (head < copyTail) {
            for (int i = head; i < copyTail; i++) {
                result[i - head] = buffer[i];
        } else {
            for (int i = head; i < bufferSize; i++) {
            for (int i = 0; i < copyTail; i++) {
                result[bufferSize - head + i] = buffer[i];
        head = copyTail;
        return result;
