- //DM430-L型最小系統(tǒng)板串口測(cè)試程序,使用單片機(jī)的串口0
- //使用板載BSL模塊或者用戶外接串口線到DB9,要求是直連公對(duì)母串口線
- //使用串口調(diào)試助手發(fā)送數(shù)據(jù)到系統(tǒng)板,比如02,03等
- //系統(tǒng)板會(huì)將收到的數(shù)據(jù)再發(fā)送到串口調(diào)試助手,接收采用中斷模塊,發(fā)送用查詢
- //板載的BSL模塊可以通過(guò)跳線帽設(shè)置為USB轉(zhuǎn)串口模式,筆記本電腦沒(méi)有串口可以直接代替
- //開(kāi)發(fā)板的BSL_Config區(qū)的RXD和TXD0連接,TXD和RXD0連接即可,另外2個(gè)跳線帽取下
- //使用USB轉(zhuǎn)串口功能時(shí),BSL失效,因此操作前應(yīng)該先將程序下載至芯片中再調(diào)整跳線帽
- #include <msp430x14x.h>
- #include "Config.h"
- #define INT8U unsigned char
- #define INT16U unsigned int
- #define WRITE_BURST 0x40 //連續(xù)寫入
- #define READ_SINGLE 0x80 //讀
- #define READ_BURST 0xC0 //連續(xù)讀
- #define BYTES_IN_RXFIFO 0x7F //接收緩沖區(qū)的有效字節(jié)數(shù)
- #define CRC_OK 0x80 //CRC校驗(yàn)通過(guò)位標(biāo)志
- //***************更多功率參數(shù)設(shè)置可詳細(xì)參考DATACC1100英文文檔中第48-49頁(yè)的參數(shù)表******************
- //INT8U PaTabel[8] = {0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04}; //-30dBm 功率最小
- //INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60}; //0dBm
- INT8U PaTabel[8] = {0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0}; //10dBm 功率最大
- void SpiInit(void);
- void CpuInit(void);
- void RESET_CC1100(void);
- void POWER_UP_RESET_CC1100(void);
- void halSpiWriteReg(INT8U addr, INT8U value);
- void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
- void halSpiStrobe(INT8U strobe);
- INT8U halSpiReadReg(INT8U addr);
- void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
- INT8U halSpiReadStatus(INT8U addr);
- void halRfWriteRfSettings(void);
- void halRfSendPacket(INT8U *txBuffer, INT8U size);
- INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
- // CC1100 STROBE, CONTROL AND STATUS REGSITER
- #define CCxxx0_IOCFG2 0x00 // GDO2 output pin configuration
- #define CCxxx0_IOCFG1 0x01 // GDO1 output pin configuration
- #define CCxxx0_IOCFG0 0x02 // GDO0 output pin configuration
- #define CCxxx0_FIFOTHR 0x03 // RX FIFO and TX FIFO thresholds
- #define CCxxx0_SYNC1 0x04 // Sync word, high INT8U
- #define CCxxx0_SYNC0 0x05 // Sync word, low INT8U
- #define CCxxx0_PKTLEN 0x06 // Packet length
- #define CCxxx0_PKTCTRL1 0x07 // Packet automation control
- #define CCxxx0_PKTCTRL0 0x08 // Packet automation control
- #define CCxxx0_ADDR 0x09 // Device address
- #define CCxxx0_CHANNR 0x0A // Channel number
- #define CCxxx0_FSCTRL1 0x0B // Frequency synthesizer control
- #define CCxxx0_FSCTRL0 0x0C // Frequency synthesizer control
- #define CCxxx0_FREQ2 0x0D // Frequency control word, high INT8U
- #define CCxxx0_FREQ1 0x0E // Frequency control word, middle INT8U
- #define CCxxx0_FREQ0 0x0F // Frequency control word, low INT8U
- #define CCxxx0_MDMCFG4 0x10 // Modem configuration
- #define CCxxx0_MDMCFG3 0x11 // Modem configuration
- #define CCxxx0_MDMCFG2 0x12 // Modem configuration
- #define CCxxx0_MDMCFG1 0x13 // Modem configuration
- #define CCxxx0_MDMCFG0 0x14 // Modem configuration
- #define CCxxx0_DEVIATN 0x15 // Modem deviation setting
- #define CCxxx0_MCSM2 0x16 // Main Radio Control State Machine configuration
- #define CCxxx0_MCSM1 0x17 // Main Radio Control State Machine configuration
- #define CCxxx0_MCSM0 0x18 // Main Radio Control State Machine configuration
- #define CCxxx0_FOCCFG 0x19 // Frequency Offset Compensation configuration
- #define CCxxx0_BSCFG 0x1A // Bit Synchronization configuration
- #define CCxxx0_AGCCTRL2 0x1B // AGC control
- #define CCxxx0_AGCCTRL1 0x1C // AGC control
- #define CCxxx0_AGCCTRL0 0x1D // AGC control
- #define CCxxx0_WOREVT1 0x1E // High INT8U Event 0 timeout
- #define CCxxx0_WOREVT0 0x1F // Low INT8U Event 0 timeout
- #define CCxxx0_WORCTRL 0x20 // Wake On Radio control
- #define CCxxx0_FREND1 0x21 // Front end RX configuration
- #define CCxxx0_FREND0 0x22 // Front end TX configuration
- #define CCxxx0_FSCAL3 0x23 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL2 0x24 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL1 0x25 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL0 0x26 // Frequency synthesizer calibration
- #define CCxxx0_RCCTRL1 0x27 // RC oscillator configuration
- #define CCxxx0_RCCTRL0 0x28 // RC oscillator configuration
- #define CCxxx0_FSTEST 0x29 // Frequency synthesizer calibration control
- #define CCxxx0_PTEST 0x2A // Production test
- #define CCxxx0_AGCTEST 0x2B // AGC test
- #define CCxxx0_TEST2 0x2C // Various test settings
- #define CCxxx0_TEST1 0x2D // Various test settings
- #define CCxxx0_TEST0 0x2E // Various test settings
- // Strobe commands
- #define CCxxx0_SRES 0x30 // Reset chip.
- #define CCxxx0_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
- // If in RX/TX: Go to a wait state where only the synthesizer is
- // running (for quick RX / TX turnaround).
- #define CCxxx0_SXOFF 0x32 // Turn off crystal oscillator.
- #define CCxxx0_SCAL 0x33 // Calibrate frequency synthesizer and turn it off
- // (enables quick start).
- #define CCxxx0_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and
- // MCSM0.FS_AUTOCAL=1.
- #define CCxxx0_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if
- // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
- // Only go to TX if channel is clear.
- #define CCxxx0_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit
- // Wake-On-Radio mode if applicable.
- #define CCxxx0_SAFC 0x37 // Perform AFC adjustment of the frequency synthesizer
- #define CCxxx0_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio)
- #define CCxxx0_SPWD 0x39 // Enter power down mode when CSn goes high.
- #define CCxxx0_SFRX 0x3A // Flush the RX FIFO buffer.
- #define CCxxx0_SFTX 0x3B // Flush the TX FIFO buffer.
- #define CCxxx0_SWORRST 0x3C // Reset real time clock.
- #define CCxxx0_SNOP 0x3D // No operation. May be used to pad strobe commands to two
- // INT8Us for simpler software.
- #define CCxxx0_PARTNUM 0x30
- #define CCxxx0_VERSION 0x31
- #define CCxxx0_FREQEST 0x32
- #define CCxxx0_LQI 0x33
- #define CCxxx0_RSSI 0x34
- #define CCxxx0_MARCSTATE 0x35
- #define CCxxx0_WORTIME1 0x36
- #define CCxxx0_WORTIME0 0x37
- #define CCxxx0_PKTSTATUS 0x38
- #define CCxxx0_VCO_VC_DAC 0x39
- #define CCxxx0_TXBYTES 0x3A
- #define CCxxx0_RXBYTES 0x3B
- #define CCxxx0_PATABLE 0x3E
- #define CCxxx0_TXFIFO 0x3F
- #define CCxxx0_RXFIFO 0x3F
- // RF_SETTINGS is a data structure which contains all relevant CCxxx0 registers
- typedef struct S_RF_SETTINGS
- INT8U FSCTRL2; //自已加的
- INT8U FSCTRL1; // Frequency synthesizer control.
- INT8U FSCTRL0; // Frequency synthesizer control.
- INT8U FREQ2; // Frequency control word, high INT8U.
- INT8U FREQ1; // Frequency control word, middle INT8U.
- INT8U FREQ0; // Frequency control word, low INT8U.
- INT8U MDMCFG4; // Modem configuration.
- INT8U MDMCFG3; // Modem configuration.
- INT8U MDMCFG2; // Modem configuration.
- INT8U MDMCFG1; // Modem configuration.
- INT8U MDMCFG0; // Modem configuration.
- INT8U CHANNR; // Channel number.
- INT8U DEVIATN; // Modem deviation setting (when FSK modulation is enabled).
- INT8U FREND1; // Front end RX configuration.
- INT8U FREND0; // Front end RX configuration.
- INT8U MCSM0; // Main Radio Control State Machine configuration.
- INT8U FOCCFG; // Frequency Offset Compensation Configuration.
- INT8U BSCFG; // Bit synchronization Configuration.
- INT8U AGCCTRL2; // AGC control.
- INT8U AGCCTRL1; // AGC control.
- INT8U AGCCTRL0; // AGC control.
- INT8U FSCAL3; // Frequency synthesizer calibration.
- INT8U FSCAL2; // Frequency synthesizer calibration.
- INT8U FSCAL1; // Frequency synthesizer calibration.
- INT8U FSCAL0; // Frequency synthesizer calibration.
- INT8U FSTEST; // Frequency synthesizer calibration control
- INT8U TEST2; // Various test settings.
- INT8U TEST1; // Various test settings.
- INT8U TEST0; // Various test settings.
- INT8U IOCFG2; // GDO2 output pin configuration
- INT8U IOCFG0; // GDO0 output pin configuration
- INT8U PKTCTRL1; // Packet automation control.
- INT8U PKTCTRL0; // Packet automation control.
- INT8U ADDR; // Device address.
- INT8U PKTLEN; // Packet length.
- } RF_SETTINGS;
- //-------------以下波特率為38.4K---------------------------//
- const RF_SETTINGS rfSettings =
- 0x00,
- 0x08, // FSCTRL1 Frequency synthesizer control. for 38.4K
- 0x00, // FSCTRL0 Frequency synthesizer control.
- 0x10, // FREQ2 Frequency control word, high byte.
- 0xA7, // FREQ1 Frequency control word, middle byte.
- 0x62, // FREQ0 Frequency control word, low byte.
- 0xCA, // MDMCFG4 Modem configuration. for 38.4K
- 0x83, // MDMCFG3 Modem configuration. for 38.4K
- 0x03, // MDMCFG2 Modem configuration. for 38.4K
- 0x22, // MDMCFG1 Modem configuration.
- 0xF8, // MDMCFG0 Modem configuration.
- 0x00, // CHANNR Channel number.
- 0x34, // DEVIATN Modem deviation setting (when FSK modulation is enabled). for 38.4K
- 0x56, // FREND1 Front end RX configuration. for 38.4K
- 0x10, // FREND0 Front end RX configuration.
- 0x18, // MCSM0 Main Radio Control State Machine configuration.
- 0x16, // FOCCFG Frequency Offset Compensation Configuration. for 38.4K
- 0x6C, // BSCFG Bit synchronization Configuration. for 38.4K
- 0x43, // AGCCTRL2 AGC control. for 38.4K
- 0x40, // AGCCTRL1 AGC control. for 38.4K
- 0x91, // AGCCTRL0 AGC control. for 38.4K
- 0xE9, // FSCAL3 Frequency synthesizer calibration. for 38.4k
- 0x2A, // FSCAL2 Frequency synthesizer calibration. for 38.4K
- 0x00, // FSCAL1 Frequency synthesizer calibration. for 38.4K
- 0x1f, // FSCAL0 Frequency synthesizer calibration. for 38.4K
- 0x59, // FSTEST Frequency synthesizer calibration.
- 0x81, // TEST2 Various test settings.
- 0x35, // TEST1 Various test settings.
- 0x09, // TEST0 Various test settings.
- 0x0B, // IOCFG2 GDO2 output pin configuration.
- 0x06, // IOCFG0D GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
- 0x04, // PKTCTRL1 Packet automation control.
- 0x05, // PKTCTRL0 Packet automation control.
- 0x00, // ADDR Device address.
- 0x20 // PKTLEN Packet length. old is 0x0c ,0x20
- //函數(shù)名:delay(unsigned int s)
- //輸入:時(shí)間
- //輸出:無(wú)
- //功能描述:普通廷時(shí),內(nèi)部用
- static void delay(unsigned int s)
- unsigned int i;
- for(i=0; i<s; i++);
- void halWait(INT16U timeout)
- do {
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- } while (--timeout);
- CC1100_CSN_0;
- CC1100_SCK_0;
- CC1100_CSN_1;
- //函數(shù)名:SpisendByte(INT8U dat)
- //輸入:發(fā)送的數(shù)據(jù)
- //輸出:無(wú)
- //功能描述:SPI發(fā)送一個(gè)字節(jié)
- INT8U SpiTxRxByte(INT8U dat)
- INT8U i,temp;
- temp = 0;
- CC1100_SCK_0;
- for(i=0; i<8; i++)
- if(dat & 0x80)
- CC1100_MOSI_1;
- else CC1100_MOSI_0;
- dat <<= 1;
- CC1100_SCK_1 ;
- // _nop_();
- temp <<= 1;
- if(CC1100_MISO_0)temp++;
- CC1100_SCK_0;
- // _nop_();
- return temp;
- //函數(shù)名:void POWER_UP_RESET_CC1100(void)
- //輸入:無(wú)
- //輸出:無(wú)
- //功能描述:上電復(fù)位CC1100
- CC1100_CSN_1 ;
- halWait(1);
- CC1100_CSN_0;
- halWait(1);
- CC1100_CSN_1;
- halWait(41);
- RESET_CC1100(); //復(fù)位CC1100
- //函數(shù)名:void halSpiWriteReg(INT8U addr, INT8U value)
- //輸入:地址和配置字
- //輸出:無(wú)
- //功能描述:SPI寫寄存器
- CC1100_CSN_0 ;
- while (CC1100_MISO_0);
- SpiTxRxByte(addr); //寫地址
- SpiTxRxByte(value); //寫入配置
- CC1100_CSN_1;
- //函數(shù)名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
- //輸入:地址,寫入緩沖區(qū),寫入個(gè)數(shù)
- //輸出:無(wú)
- //功能描述:SPI連續(xù)寫配置寄存器
- INT8U i, temp;
- temp = addr | WRITE_BURST;
- CC1100_CSN_0;
- SpiTxRxByte(temp);
- for (i = 0; i < count; i++)
- SpiTxRxByte(buffer[i]);
- CC1100_CSN_1 ;
- //函數(shù)名:void halSpiStrobe(INT8U strobe)
- //輸入:命令
- //輸出:無(wú)
- //功能描述:SPI寫命令
- CC1100_CSN_0 ;
- SpiTxRxByte(strobe); //寫入命令
- CC1100_CSN_1 ;
- //函數(shù)名:INT8U halSpiReadReg(INT8U addr)
- //輸入:地址
- //輸出:該寄存器的配置字
- //功能描述:SPI讀寄存器
- INT8U temp, value;
- temp = addr|READ_SINGLE;//讀寄存器命令
- CC1100_CSN_0;
- value = SpiTxRxByte(0);
- CC1100_CSN_1 ;
- return value;
- //函數(shù)名:void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count)
- //輸入:地址,讀出數(shù)據(jù)后暫存的緩沖區(qū),讀出配置個(gè)數(shù)
- //輸出:無(wú)
- INT8U i,temp;
- temp = addr | READ_BURST; //寫入要讀的配置寄存器地址和讀命令
- CC1100_CSN_0 ;
- buffer[i] = SpiTxRxByte(0);
- CC1100_CSN_1;
- //輸入:地址
- //輸出:該狀態(tài)寄存器當(dāng)前值
- //功能描述:SPI讀狀態(tài)寄存器
- INT8U value,temp;
- temp = addr | READ_BURST; //寫入要讀的狀態(tài)寄存器的地址同時(shí)寫入讀命令
- CC1100_CSN_0 ;
- CC1100_CSN_1 ;
- return value;
- //函數(shù)名:void halRfWriteRfSettings(RF_SETTINGS *pRfSettings)
- //輸入:無(wú)
- //輸出:無(wú)
- //功能描述:配置CC1100的寄存器
- halSpiWriteReg(CCxxx0_FSCTRL0, rfSettings.FSCTRL2);//自已加的
- // Write register settings
- halSpiWriteReg(CCxxx0_FSCTRL1, rfSettings.FSCTRL1);
- halSpiWriteReg(CCxxx0_FSCTRL0, rfSettings.FSCTRL0);
- halSpiWriteReg(CCxxx0_FREQ2, rfSettings.FREQ2);
- halSpiWriteReg(CCxxx0_FREQ1, rfSettings.FREQ1);
- halSpiWriteReg(CCxxx0_FREQ0, rfSettings.FREQ0);
- halSpiWriteReg(CCxxx0_MDMCFG4, rfSettings.MDMCFG4);
- halSpiWriteReg(CCxxx0_MDMCFG3, rfSettings.MDMCFG3);
- halSpiWriteReg(CCxxx0_MDMCFG2, rfSettings.MDMCFG2);
- halSpiWriteReg(CCxxx0_MDMCFG1, rfSettings.MDMCFG1);
- halSpiWriteReg(CCxxx0_MDMCFG0, rfSettings.MDMCFG0);
- halSpiWriteReg(CCxxx0_CHANNR, rfSettings.CHANNR);
- halSpiWriteReg(CCxxx0_DEVIATN, rfSettings.DEVIATN);
- halSpiWriteReg(CCxxx0_FREND1, rfSettings.FREND1);
- halSpiWriteReg(CCxxx0_FREND0, rfSettings.FREND0);
- halSpiWriteReg(CCxxx0_MCSM0 , rfSettings.MCSM0 );
- halSpiWriteReg(CCxxx0_FOCCFG, rfSettings.FOCCFG);
- halSpiWriteReg(CCxxx0_BSCFG, rfSettings.BSCFG);
- halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
- halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
- halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
- halSpiWriteReg(CCxxx0_FSCAL3, rfSettings.FSCAL3);
- halSpiWriteReg(CCxxx0_FSCAL2, rfSettings.FSCAL2);
- halSpiWriteReg(CCxxx0_FSCAL1, rfSettings.FSCAL1);
- halSpiWriteReg(CCxxx0_FSCAL0, rfSettings.FSCAL0);
- halSpiWriteReg(CCxxx0_FSTEST, rfSettings.FSTEST);
- halSpiWriteReg(CCxxx0_TEST2, rfSettings.TEST2);
- halSpiWriteReg(CCxxx0_TEST1, rfSettings.TEST1);
- halSpiWriteReg(CCxxx0_TEST0, rfSettings.TEST0);
- halSpiWriteReg(CCxxx0_IOCFG2, rfSettings.IOCFG2);
- halSpiWriteReg(CCxxx0_IOCFG0, rfSettings.IOCFG0);
- halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
- halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
- halSpiWriteReg(CCxxx0_ADDR, rfSettings.ADDR);
- halSpiWriteReg(CCxxx0_PKTLEN, rfSettings.PKTLEN);
- //函數(shù)名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
- //輸入:發(fā)送的緩沖區(qū),發(fā)送數(shù)據(jù)個(gè)數(shù)
- //輸出:無(wú)
- //功能描述:CC1100發(fā)送一組數(shù)據(jù)
- halSpiWriteReg(CCxxx0_TXFIFO, size);
- halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size); //寫入要發(fā)送的數(shù)據(jù)
- halSpiStrobe(CCxxx0_STX); //進(jìn)入發(fā)送模式發(fā)送數(shù)據(jù)
- // Wait for GDO0 to be set -> sync transmitted
- while (CC1100_GDO0_1);
- // Wait for GDO0 to be cleared -> end of packet
- while (CC1100_GDO0_0);
- halSpiStrobe(CCxxx0_SFTX);
- void setRxMode(void)
- halSpiStrobe(CCxxx0_SRX); //進(jìn)入接收狀態(tài)
- // Bit masks corresponding to STATE[2:0] in the status byte returned on MISO
- #define CCxx00_STATE_BM 0x70
- #define CCxx00_FIFO_BYTES_AVAILABLE_BM 0x0F
- #define CCxx00_STATE_TX_BM 0x20
- #define CCxx00_STATE_TX_UNDERFLOW_BM 0x70
- #define CCxx00_STATE_RX_BM 0x10
- #define CCxx00_STATE_RX_OVERFLOW_BM 0x60
- #define CCxx00_STATE_IDLE_BM 0x00
- static INT8U RfGetRxStatus(void)
- INT8U temp, spiRxStatus1,spiRxStatus2;
- INT8U i=4;// 循環(huán)測(cè)試次數(shù)
- temp = CCxxx0_SNOP|READ_SINGLE;//讀寄存器命令
- CSN = 0;
- while (MISO);
- spiRxStatus1 = SpiTxRxByte(0);
- do
- spiRxStatus2 = SpiTxRxByte(0);
- if(spiRxStatus1 == spiRxStatus2)
- if( (spiRxStatus1 & CCxx00_STATE_BM) == CCxx00_STATE_RX_OVERFLOW_BM)
- halSpiStrobe(CCxxx0_SFRX);
- return 0;
- return 1;
- spiRxStatus1=spiRxStatus2;
- while(i--);
- CSN = 1;
- return 0;
- INT8U status[2];
- INT8U packetLength;
- INT8U i=(*length)*4; // 具體多少要根據(jù)datarate和length來(lái)決定
- //delay(5);
- //while (!GDO1);
- //while (GDO1);
- delay(2);
- delay(2);
- --i;
- if(i<1)
- return 0;
- if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字節(jié)數(shù)不為0
- packetLength = halSpiReadReg(CCxxx0_RXFIFO);//讀出第一個(gè)字節(jié),此字節(jié)為該幀數(shù)據(jù)長(zhǎng)度
- if (packetLength <= *length) //如果所要的有效數(shù)據(jù)長(zhǎng)度小于等于接收到的數(shù)據(jù)包的長(zhǎng)度
- halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //讀出所有接收到的數(shù)據(jù)
- *length = packetLength; //把接收數(shù)據(jù)長(zhǎng)度的修改為當(dāng)前數(shù)據(jù)的長(zhǎng)度
- // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI)
- halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2); //讀出CRC校驗(yàn)位
- halSpiStrobe(CCxxx0_SFRX); //清洗接收緩沖區(qū)
- return (status[1] & CRC_OK); //如果校驗(yàn)成功返回接收成功
- else
- return 0;
- else
- return 0;
- //函數(shù)名:void RESET_CC1100(void)
- //輸入:無(wú)
- //輸出:無(wú)
- //功能描述:復(fù)位CC1100
- CC1100_CSN_0;
- while (CC1100_MISO_1);
- SpiTxRxByte(CCxxx0_SRES); //寫入復(fù)位命令
- CC1100_CSN_1;
- //函數(shù)名:CpuInit()
- //輸入:無(wú)
- //輸出:無(wú)
- //功能描述:SPI初始化程序
- SpiInit();
- delay(5000);
- // MSP430串口初始化
- void UART_Init()
- U0CTL|=SWRST; //復(fù)位SWRST
- U0CTL|=CHAR; //8位數(shù)據(jù)模式
- U0TCTL|=SSEL1; //SMCLK為串口時(shí)鐘
- U0BR1=baud_h; //BRCLK=8MHZ,Baud=BRCLK/N
- U0BR0=baud_l; //N=UBR+(UxMCTL)/8
- U0MCTL=0x00; //微調(diào)寄存器為0,波特率9600bps
- ME1|=UTXE0; //UART0發(fā)送使能
- ME1|=URXE0; //UART0接收使能
- U0CTL&=~SWRST;
- IE1|=URXIE0; //接收中斷使能位
- P3SEL|= BIT4; //設(shè)置IO口為普通I/O模式
- P3DIR|= BIT4; //設(shè)置IO口方向?yàn)檩敵?br />
- P3SEL|= BIT5;
- // 串口0發(fā)送數(shù)據(jù)函數(shù)
- void Send_Byte(uchar data)
- while((IFG1&UTXIFG0)==0); //發(fā)送寄存器空的時(shí)候發(fā)送數(shù)據(jù)
- U0TXBUF=data;
- // 處理來(lái)自串口 0 的接收中斷
- #pragma vector=UART0RX_VECTOR
- __interrupt void UART0_RX_ISR(void)
- uchar data=0;
- data=U0RXBUF; //接收到的數(shù)據(jù)存起來(lái)
- Send_Byte(data); //將接收到的數(shù)據(jù)再發(fā)送出去
- // 處理來(lái)自串口 0 的發(fā)送中斷,預(yù)留
- #pragma vector=UART0TX_VECTOR
- __interrupt void UART0_TX_ISR(void)
- // 主函數(shù)
- void main(void)
- INT8U n;
- INT8U TxBuf[8]={0}; // 8字節(jié), 如果需要更長(zhǎng)的數(shù)據(jù)包,請(qǐng)正確設(shè)置
- WDT_Init(); //看門狗設(shè)置
- Clock_Init(); //系統(tǒng)時(shí)鐘設(shè)置
- UART_Init(); //串口設(shè)置初始化
- _EINT(); //開(kāi)中斷
- CpuInit();
- POWER_UP_RESET_CC1100();
- halRfWriteRfSettings();
- halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8);
- //TxBuf[0] = 8 ;
- TxBuf[1] = 1 ;
- TxBuf[2] = 1 ;
- // halRfSendPacket(TxBuf,8); // Transmit Tx buffer data
- delay(6000);
- while(1) //無(wú)限循環(huán)
- TxBuf[1] = 1 ;
- for(n=16; n>=1; n--)
- halRfSendPacket(TxBuf,8); // Transmit Tx buffer data 發(fā)送16個(gè)數(shù)據(jù)包,總計(jì)耗時(shí)120ms
- delay(1); // delay(200)=10ms
- TxBuf[1] = 0xff;
- TxBuf[2] = 0xff;
- delay(6000);
復(fù)制代碼 |
