(2)程序代碼 1主程序 OKEQU20H RINGEQU22H ORG0000H AJMPMAIN ORG0003H AJMPINT0SUB ORG000BH AJMPT0INT ORG0013H AJMPINT1SUB ORG001BH AJMPT1INT ORG0040H MAIN:MOVR1,#30 MOVR2,#60 MOVTMOD,#11H MOVTH0,#0F0H MOVTL0,#0FFH MOVTH1,#3CH MOVTL1,#0B0H SETBEA SETBET0 SETBET1 SETBEX0 SETBEX1 CLROK CLRRING SETBTR1 SETBTR0 2查詢程序 START:MOVR5,#0BH MOVR4,#0BH MOVR3,#0BH ACALLDISPLAY JBP3.0,NEXT ACALLDELAY JBP3.0,NEXT ACALLBARK MOVA,R1 MOVR6,A SETBOK MOVR7,#01H MOVR3,#0AH AJMPCOUNT NEXT:JNBP1.0,FALSE1 JNBP1.1,FALSE2 JNBP1.2,FALSE3 JNBP1.3,FALSE4 JNBP1.4,FALSE5 JNBP1.5,FALSE6 JNBP1.6,FALSE7 JNBP1.7,FALSE8 AJMPSTART 3非法搶答處理程序 FALSE1:MOVR3,#01H AJMPERROR FALSE2:MOVR3,#02H AJMPERROR FALSE3:MOVR3,#03H AJMPERROR FALSE4:MOVR3,#04H AJMPERROR FALSE5:MOVR3,#05H AJMPERROR FALSE6:MOVR3,#06H AJMPERROR FALSE7:MOVR3,#07H AJMPERROR FALSE8:MOVR3,#08H 4搶答、回答時(shí)間調(diào)整程序 =====INT0(搶答時(shí)間R1調(diào)整程序)===== INT0SUB:MOVA,R1 MOVB,#0AH DIVAB MOVR5,A MOVR4,B MOVR3,#0AH ACALLDISPLAY JNBP3.4,INC0 JNBP3.5,DEC0 JNBP3.1,BACK0 AJMPINT0SUB INC0:MOVA,R1 CJNEA,#63H,ADD0 MOVR1,#00H ACALLDELAY1 AJMPINT0SUB ADD0:INCR1 ACALLDELAY1 AJMPINT0SUB DEC0:MOVA,R1 JZSETR1 DECR1 ACALLDELAY1 AJMPINT0SUB SETR1:MOVR1,#63H ACALLDELAY1 AJMPINT0SUB BACK0:RETI ;=====INT1(回答時(shí)間R2調(diào)整程序)===== INT1SUB:MOVA,R2 MOVB,#0AH DIVAB MOVR5,A MOVR4,B MOVR3,#0AH ACALLDISPLAY JNBP3.4,INC1 JNBP3.5,DEC1 JNBP3.1,BACK1 AJMPINT1SUB INC1:MOVA,R2 CJNEA,#63H,ADD1 MOVR2,#00H ACALLDELAY1 AJMPINT1SUB ADD1:INCR2 ACALLDELAY1 AJMPINT1SUB DEC1:MOVA,R2 JZSETR2 DECR2 ACALLDELAY1 AJMPINT1SUB SETR2:MOVR2,#63H ACALLDELAY1 AJMPINT1SUB BACK1:RETI 5倒計(jì)時(shí)程序 REPEAT:MOVA,R2 MOVR6,A CLRRING COUNT:MOVR0,#00H MOVTH1,#3CH MOVTL1,#0B0H RECOUNT:MOVA,R6 MOVB,#0AH DIVAB MOV30H,A MOV31H,B MOVR5,30H MOVR4,31H MOVA,R6 SUBBA,#07H JNCLARGER MOVA,R0 CJNEA,#0AH,FULL CLRRING AJMPCHECK FULL:CJNEA,#14H,CHECK SETBRING MOVA,R6 JZQUIT MOVR0,#00H DECR6 AJMPCHECK LARGER:MOVA,R0 CJNEA,#14H,CHECK DECR6 MOVR0,#00H CHECK:JNBP3.1,QUIT JNBOK,CHECKK AJMPNEXTT CHECKK:JNBP3.0,REPEAT NEXTT:ACALLDISPLAY JBOK,ACCOUT AJMPRECOUNT ACCOUT: MOVA,36H JNBACC.0,TRUE1 JNBACC.1,TRUE2 JNBACC.2,TRUE3 JNBACC.3,TRUE4 JNBACC.4,TRUE5 JNBACC.5,TRUE6 JNBACC.6,TZ1 JNBACC.7,TZ2 AJMPRECOUNT TZ1:JMPTRUE7 TZ2:JMPTRUE8 QUIT:CLROK CLRRING AJMPSTART 6正常搶答處理程序 TRUE1:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#01H CLROK AJMPCOUNT TRUE2:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#02H CLROK AJMPCOUNT TRUE3:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#03H CLROK AJMPCOUNT TRUE4:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#04H CLROK AJMPCOUNT TRUE5:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#05H CLROK AJMPCOUNT TRUE6:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#06H CLROK AJMPCOUNT TRUE7:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#07H CLROK AJMPCOUNT TRUE8:ACALLBARK MOVA,R2 MOVR6,A MOVR3,#08H CLROK AJMPCOUNT 7犯規(guī)搶答程序 ERROR:MOVR0,#00H MOVTH1,#3CH MOVTL1,#0B0H MOV34H,R3 HERE:MOVA,R0 CJNEA,#06H,FLASH;0.3s CLRRING MOVR3,#0AH MOVR4,#0AH MOVR5,#0AH AJMPCHECK1 FLASH:CJNEA,#0CH,CHECK1 SETBRING MOVR0,#00H MOVR3,34H MOVR5,#0BH MOVR4,#0BH AJMPCHECK1 CHECK1:JNBP3.1,QUIT1 ACALLDISPLAY AJMPHERE QUIT1:CLRRING CLROK AJMPSTART 8其他功能程序 =====顯示程序===== DISPLAY:MOVDPTR,#DAT1 MOVA,R3 MOVCA,@A+DPTR MOVP2,#0feH MOVP0,A ACALLDELAY2 MOVDPTR,#DAT2 MOVA,R5 MOVCA,@A+DPTR MOVP2,#0fdH MOVP0,A ACALLDELAY2 MOVA,R4 MOVCA,@A+DPTR MOVP2,#0fbH MOVP0,A ACALLDELAY2 RET DAT1:DB00h,06h,5Bh,4Fh,66h,6Dh,7Dh,07h,7Fh,6Fh,00H,71H DAT2:DB3Fh,06h,5Bh,4Fh,66h,6Dh,7Dh,07h,7Fh,6Fh,00H,71H =====發(fā)聲程序===== BARK:SETBRING ACALLDELAY1 ACALLDELAY1 CLRRING RET =====TO溢出中斷(響鈴程序)===== T0INT:MOVTH0,#0ECH MOVTL0,#0FFH JNBRING,OUT; CPLP3.6 OUT:RETI ;=====T1溢出中斷(計(jì)時(shí)程序)===== T1INT:MOVTH1,#3CH MOVTL1,#0B0H END |
