查看: 2378|回復: 0
STM32 12通道ADC_DMA采集程序的庫函數版本
ID:265300 發表于 2018-1-16 21:41 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
STM32 12通道采集程序
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. //ALIENTEK 探索者STM32F407開發板 實驗18
  8. //ADC模數轉換實驗-庫函數版本
  9. extern __IO uint16_t ADC1ConvertedValue[10][12];
  10. __IO uint32_t ADC1ConvertedVoltage[12];
  11. int main(void)
  12. {
  13.     u8 i;
  14.         u8 j;
  15.         u8 k;
  16.         float temp[12];
  17.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統中斷優先級分組2
  18.         delay_init();    //初始化延時函數
  19.         uart_init(115200);        //初始化串口波特率為115200
  20.         LED_Init();                                        //初始化LED
  21.         LCD_Init();         //初始化LCD接口
  22.         Adc_Init();         //初始化ADC
  23.         POINT_COLOR=RED;
  24.
  25.         LCD_ShowString(200,70,200,16,24,"UESTC");
  26.
  27.         POINT_COLOR=BLUE;//設置字體為藍色
  28.         LCD_ShowString(160,130,200,16,16,"ADC1_CH00_VAL:");
  29.         LCD_ShowString(160,150,200,16,16,"ADC1_CH00_VOL:0.000V");        //先在固定位置顯示小數點
  30.     LCD_ShowString(160,170,200,16,16,"ADC1_CH01_VAL:");
  31.         LCD_ShowString(160,190,200,16,16,"ADC1_CH01_VOL:0.000V");        //先在固定位置顯示小數點
  32.
  33.         LCD_ShowString(160,210,200,16,16,"ADC1_CH02_VAL:");
  34.         LCD_ShowString(160,230,200,16,16,"ADC1_CH02_VOL:0.000V");        //先在固定位置顯示小數點
  35.     LCD_ShowString(160,250,200,16,16,"ADC1_CH03_VAL:");
  36.         LCD_ShowString(160,270,200,16,16,"ADC1_CH03_VOL:0.000V");        //先在固定位置顯示小數點
  37.
  38.         LCD_ShowString(160,290,200,16,16,"ADC1_CH04_VAL:");
  39.         LCD_ShowString(160,310,200,16,16,"ADC1_CH04_VOL:0.000V");        //先在固定位置顯示小數點
  40.     LCD_ShowString(160,330,200,16,16,"ADC1_CH05_VAL:");
  41.         LCD_ShowString(160,350,200,16,16,"ADC1_CH05_VOL:0.000V");        //先在固定位置顯示小數點
  42.
  43.         LCD_ShowString(160,370,200,16,16,"ADC1_CH06_VAL:");
  44.         LCD_ShowString(160,390,200,16,16,"ADC1_CH06_VOL:0.000V");        //先在固定位置顯示小數點
  45.     LCD_ShowString(160,410,200,16,16,"ADC1_CH07_VAL:");
  46.         LCD_ShowString(160,430,200,16,16,"ADC1_CH07_VOL:0.000V");        //先在固定位置顯示小數點
  47.
  48.         LCD_ShowString(160,450,200,16,16,"ADC1_CH09_VAL:");
  49.         LCD_ShowString(160,470,200,16,16,"ADC1_CH09_VOL:0.000V");        //先在固定位置顯示小數點
  50.     LCD_ShowString(160,490,200,16,16,"ADC1_CH10_VAL:");
  51.         LCD_ShowString(160,510,200,16,16,"ADC1_CH10_VOL:0.000V");        //先在固定位置顯示小數點
  52.
  53.         LCD_ShowString(160,530,200,16,16,"ADC1_CH11_VAL:");
  54.         LCD_ShowString(160,550,200,16,16,"ADC1_CH11_VOL:0.000V");        //先在固定位置顯示小數點
  55.     LCD_ShowString(160,570,200,16,16,"ADC1_CH12_VAL:");
  56.         LCD_ShowString(160,590,200,16,16,"ADC1_CH12_VOL:0.000V");        //先在固定位置顯示小數點
  57.         while(1)
  58.         {
  59.
  60.                 ADC1ConvertedVoltage[0] = 0;
  61.
  62.
  63.         for(i=0;i<12;i++)
  64.         {
  65.                         ADC1ConvertedVoltage[i] = 0;
  66.                         for(j=0;j<10;j++)
  67.                         {
  68.             ADC1ConvertedVoltage[i]+= ADC1ConvertedValue[j][i];
  69.
  70.             };
  71.                         ADC1ConvertedVoltage[i] = ADC1ConvertedVoltage[i]/10;
  72.             };
  73.
  74.                 for(k=0;k<12;k++)
  75.                 {
  76.         temp[k] = ADC1ConvertedVoltage[k]*3.3/4096;
  77.
  78.
  79.                 LCD_ShowxNum(272,130+40*k,ADC1ConvertedVoltage[k],4,16,0);    //顯示ADCC采樣后的原始值
  80.                 i=temp[k];                            //賦值整數部分給adcx變量,因為adcx為u16整形
  81.                 LCD_ShowxNum(272,150+40*k,i,1,16,0);    //顯示電壓值的整數部分,3.1111的話,這里就是顯示3
  82.                 temp[k]-=i;                           //把已經顯示的整數部分去掉,留下小數部分,比如3.1111-3=0.1111
  83.                 temp[k]*=1000;                           //小數部分乘以1000,例如:0.1111就轉換為111.1,相當于保留三位小數。
  84.                 LCD_ShowxNum(288,150+40*k,temp[k],3,16,0X80); //顯示小數部分(前面轉換為了整形顯示),這里顯示的就是111.
  85.
  86.                 };
  87.                 /*LCD_ShowxNum(264,170,ADC1ConvertedVoltage[1],4,16,0);    //顯示ADCC采樣后的原始值
  88.                 i=temp2;                            //賦值整數部分給adcx變量,因為adcx為u16整形
  89.                 LCD_ShowxNum(264,190,i,1,16,0);    //顯示電壓值的整數部分,3.1111的話,這里就是顯示3
  90.                 temp2-=i;                           //把已經顯示的整數部分去掉,留下小數部分,比如3.1111-3=0.1111
  91.                 temp2*=1000;                           //小數部分乘以1000,例如:0.1111就轉換為111.1,相當于保留三位小數。
  92.                 LCD_ShowxNum(280,190,temp2,3,16,0X80); //顯示小數部分(前面轉換為了整形顯示),這里顯示的就是111.
  93.         */
  94.                 LED0=!LED0;
  95.                 delay_ms(1000);
  96.         }
  97. }
12通道ADC_DMA -.rar (361.7 KB, 下載次數: 33)
