查看: 1599|回復: 0
單片機簡單程序試試發
ID:276209 發表于 2018-1-15 15:24 | 顯示全部樓層 |閱讀模式
#include <avr/io.h>
#include <util/delay.h>
//口定義
#define PORT_DHT PORTC
//口方向定義
#define DDR_DHT DDRC
//讀取口定義
#define PIN_DHT PINC
//數據位定義
#define BIT_DHT PC4
#define RS PA0 //數據/命令控制端 0命令,1 數據
#define RW PA1 //讀/寫選擇控制端 0寫,1讀
#define E PA2 //使能端 下降沿讀,高電平寫
#define                L_DHT                PORT_DHT&=~(1<<BIT_DHT)                        //數據線強制拉低
#define                H_DHT                PORT_DHT|=(1<<BIT_DHT)                                //數據線強制拉高
#define                O_DHT                DDR_DHT|=(1<<BIT_DHT)                                //Mega16控制總線,PD4為輸出
#define                P_DHT                DDR_DHT&=~(1<<BIT_DHT)                            //釋放總線,PD4為輸入
#define                I_DHT                PIN_DHT&(1<<BIT_DHT)                                //數據線的狀態
void LCDPort_Init(void); //液晶端口初始化
void LCD_Init(void); //LCD 初始化
void Write_Com(unsigned char LCD_Com); //LCD 寫指令
void Write_Data_Byte(unsigned char LCD_Data); //LCD 寫字節數據
void Write_Place_xy(unsigned char x,unsigned char y); //指定當前寫字符的位置
void Write_Data_String(unsigned char x,unsigned char y,unsigned char *data);//在指定的(x,y)位置上寫入字符串數據
void Write_Data_Char(unsigned char x,unsigned char y,unsigned char data);//在指定的(x,y)位置上寫入字符數據
void Check_Busy(void); //讀寫檢測函數,每次對液晶操讀作前都要進行寫檢測
void Delayus(unsigned int lus); //us延時函數
void Delayms(unsigned int lms); //ms延時函數
unsigned  Reset()
        O_DHT;
        H_DHT;
        _delay_us(2);
        L_DHT;
        _delay_us(19);
        P_DHT;
        _delay_us(20);
        if(I_DHT)
        return 0;
        return 1;
int main(void)
        _delay_ms(1000);
        unsigned char tdata[5];
        unsigned long u16Flag; // 超時計數
        unsigned char iiii;
        unsigned long u32I; // 接收數據臨時變量
        unsigned long ReceiveValue = 0; // 接收數據包變量
        unsigned long ReceiveValue1 = 0; // 接收校驗和變量
        unsigned int ReceiveHighByte; // 分解數據包 濕度
        unsigned int ReceiveLowByte; // 分解數據包溫度
        LCDPort_Init();
        LCD_Init();
        Write_Data_String(0,0,"ddddddd");
        if(Reset())
        {        P_DHT;
                while((!(I_DHT)) && ((u16Flag++)<50000));
                ReceiveValue = 0;
                ReceiveValue1 = 0;
                u16Flag = 0;
                while((I_DHT) && ((u16Flag++)<50000));
                for(u32I=0x80000000; u32I>0; u32I>>=1)
                        u16Flag = 0;
                        while((!(I_DHT))&& ((u16Flag++)<3000));
                        u16Flag = 0;
                        _delay_us(28);
                        if(I_DHT)
                                ReceiveValue |= u32I;
                        while((I_DHT)&&((u16Flag++)<300));
                for(u32I=0x80;u32I>0;u32I>>=1)
                        u16Flag = 0;
                        while((!(I_DHT))&&((u16Flag++)<3000));
                        u16Flag = 0;
                        _delay_us(28);
                        if(I_DHT)
                                ReceiveValue1 |= u32I;
                while(!(I_DHT));
                O_DHT;
                H_DHT;
                ReceiveLowByte =(unsigned int )( ReceiveValue&0x0000FFFF);
                ReceiveHighByte = ReceiveValue>>16;
                /****************************display******************************/
                        tdata[0]=*((unsigned char*)(&ReceiveHighByte) + 1)/10;
                      tdata[1]=*((unsigned char*)(&ReceiveHighByte) + 1)%10;
                      tdata[2]=*((unsigned char*)(&ReceiveLowByte) + 1)/10;
                        tdata[3]=*((unsigned char*)(&ReceiveLowByte) + 1)%10;
                        Write_Com(0xc0);
            Write_Data_Byte( tdata[0]+0x30 );//顯示濕度十位
                        Write_Com(0xc1);
                        Write_Data_Byte( tdata[1]+0x30 );//顯示濕度個位
                        Write_Com(0xc2);
                //        Write_Data_Byte("%");
                        Write_Com(0xc4);
                        Write_Data_Byte( tdata[2]+0x30 );//顯示溫度十位
                        Write_Com(0xc5);
                        Write_Data_Byte( tdata[3]+0x30 );//顯示溫度個位
                        Write_Com(0xc6);
                          Write_Data_Byte(0xdf);//顯示"。"
                          Write_Com(0xc7);
                          Write_Data_Byte('C');
void LCDPort_Init()
  //LCD 數據端口設置
  PORTD = 0X00; //
  DDRD = 0XFF; //配置端口PD全部為輸出口,LCD 數據端口
  //LCD 控制端口設置
  PORTA &= ~((1 << RS) | (1 << RW) | (1 << E)); //
  DDRA |= (1 << RS) | (1 << RW) | (1 << E);
//LCD 初始化
void LCD_Init()
Write_Com(0X01); //清屏
Delayms(5);
Write_Com(0X38); //顯示模式設置 16x2顯示,5x7點陣,8 位數據接口
Delayms(5);
//Write_Com(0X0f); //顯示開關控制,開顯示,光標顯示,光標閃爍
Write_Com(0X0c); //顯示開關控制,開顯示,光標不顯示,光標不閃爍
Delayms(5);
Write_Com(0X06); //光標設置,讀或寫一個字符后,地址指針加一,光標加一,整屏不移動
Delayms(5);
//LCD 寫指令
Check_Busy();
PORTA &= ~(1 << RS); //RS=0,寫命令
PORTA &= ~(1 << RW); //RW=0,寫指令
PORTA |= (1 << E); //E=1,寫操作
Delayms(1);
PORTD = LCD_Com; //指令送數據端口
PORTA &= ~(1 << E); //E=0,停止寫操作
Delayms(1);
//LCD 寫字節數據
  Check_Busy();
  PORTA |= (1 << RS); //RS=1,寫數據
  Delayms(1);
  PORTD = LCD_Data; // 數據送數據端口
  Delayms(1);
//指定當前寫字符的位置
  unsigned char address;
  if(y == 0) //行位置
    address = 0x80 + x; //列位置,
    address = 0x80 + 0x40 + x; //
  Write_Com(address); //寫地址
  Write_Place_xy(x,y); //寫地址
  while(*data)
   Write_Data_Byte(*data); //寫字符串
   data++; //指針地址加1
//在指定的(x,y)位置上寫入字符數據 x列位置,y行位置
  Write_Data_Byte(data); //
//讀寫檢測函數,每次對液晶操作前都要進行讀寫檢測
void Check_Busy()
  DDRD = 0X00; //PB口置為輸入口,準備讀取數據
  PORTA &= ~(1 << RS); //RS=0,讀命令
  PORTA |= (1 << RW); //RW=1,讀指令
  PORTA |= (1 << E); //E=1,使能
  while(0X80 & PIND); //監測忙信號,直到忙信號為0,才能進行讀寫操作
  DDRD = 0XFF; //PB口置為輸出口,準備向端口發送數據
//us級別的延時函數
while(lus--)
   _delay_loop_2(4); //_delay_loop_2(1)是延時4 個時鐘周期,參數為4 則延時16
    //個時鐘周期,本實驗用16M晶體,則16 個時鐘周期為16/16=1us
//ms級別的延時函數
  while(lms--)
   Delayus(1000); //延時1ms
