查看: 3622|回復: 0
51單片機時,分,秒程序
ID:272841 發表于 2018-1-9 20:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機,時分秒程序設計
  1. #include <reg51.h>//<stc15.h>
  3. #define uint unsigned int
  4. void BCSegNum();
  5. void XSSegNum();
  6. void DelayMs(uint n);
  7. uchar Second=59, Hour=8, Minute=13;
  8. static uchar Counter;
  9. uchar flag0=0;
  10. sbit dp=P2^7;
  11. SegNum[]={1,2,3,4};//四個數碼管
  12. SegCode[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
  13. BitCode[]={0x01,0x02,0x04,0x08};
  14. void main()
  15. {
  16. TMOD = 0x01;//16位不自動重裝,方式1
  17. TH0 = 0x4c;//50ms
  18. TL0 = 0x00;
  19. ET0 = 1;
  20. EA = 1;
  21. TR0 = 1;
  22. EX0 = 1;
  23. EX1 =1;
  24. IT0 = 1;
  25. IT1 = 1;
  26. P1 = 0;
  27. while(1)
  28. {
  29. BCSegNum();
  30. XSSegNum();
  31. }
  32. }
  33. void BCSegNum()
  34. {
  35. SegNum[3] = Hour/10;//時十位
  36. SegNum[2] = Hour%10;
  37. SegNum[1] = Minute/10;
  38. SegNum[0] = Minute%10;
  39. }
  40. void XSSegNum()
  41. {
  42. uchar i;
  43. for(i=0;i<4;i++)
  44. {
  45. P2=SegCode[SegNum[i]];
  46. P1=BitCode[i];
  47. DelayMs(3);
  48. P1=0x00;
  49. }
  50. }
  51. void T0_Isr(void)interrupt 1
  52. {
  53. TH0 = 0x4c;
  54. TL0 =0x00;
  55. Counter++;
  56. if(Counter<=10)dp = 0;
  57. else dp = 1;
  58. if(Counter==20)
  59. {
  60. Second++;
  61. Counter = 0;
  62. if(Second==60)
  63. {
  64. Second=0;
  65. Minute++;
  66. if(Minute==60)
  67. {
  68. Minute=0;
  69. Hour++;
  70. if(Hour==24)
  71. {
  72. Hour=0;
  73. }
  74. }
  75. }
  76. }
  77. }
  78. void DelayMs(uint n)
  79. {
  80. uchar j;
  81. while(n--)
  82. {
  83. for(j=0;j<113;j++);
  84. }
  85. }
  86. void Ex0Isr() interrupt 0 //選擇鍵
  87. {
  88. TR0 = 0;
  89. flag0++;//flag0=0無鍵按下
  90. if(flag0==3)
  91. {
  92. flag0=0;
  93. TR0 = 1;
  94. }
  95. }
  96. void Ex1tsr() interrupt 2 //加鍵
  97. {
  98. if(flag0==1)//分加1
  99. {
  100. Minute++;
  101. if(Minute==60)
  102. Minute=0;
  103. }
  104. if(flag0==2)//時加1
  105. {
  106. Hour++;
  107. if(Hour==24)
  108. Hour=0;
  109. }
  110. }
51單片機時,分,秒程序.rar (11.97 KB, 下載次數: 5)
