查看: 3176|回復(fù): 2
這是我做的8086控制直流電機轉(zhuǎn)速的代碼
ID:273933 發(fā)表于 2018-1-9 19:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. CODE    SEGMENT 'CODE'
  2.         ASSUME CS:CODE,SS:STACK,DS:DATA
  3.
  4. TCONTRO   EQU 0A006H
  5. TCON0     EQU 0A000H
  6. TCON1     EQU 0A002H
  7. TCON2     EQU 0A004H
  8. IOCON        EQU 8006H
  9. IOA     EQU 8000H
  10. IOB     EQU 8002H
  11. IOC     EQU 8004H
  12. START:
  13.         MOV AX, DATA
  14.         MOV DS, AX
  15.         MOV AX, STACK
  16.         MOV SS, AX
  17.         MOV AX, TOP
  18.         MOV SP, AX
  19.
  20.
  21.         MOV AL,90H
  22.         MOV DX,IOCON
  23.         OUT DX,AL
  24.         NOP
  25.         NOP
  26.
  27.         MOV DX,TCONTRO
  28.         MOV AL,36H
  29.             OUT DX,AL
  30.
  31.         MOV DX,TCON0
  32.             MOV AX,50
  33.         OUT DX,AL
  34.             MOV AL,AH
  35.             OUT DX,AL
  36. TEST_BU:
  37.         MOV DX,IOA
  38.             IN  AL,DX
  39.             MOV DX,IOA
  40.             IN  AL,DX
  41.         NOP
  42.
  43. test_1:        TEST AL,01H
  44.             JE MOT1
  45. test_2:        TEST AL,02H
  46.             JE MOT2
  47. test_3: TEST AL,04H
  48.         JE MOT3
  49.         JMP TEST_BU
  50. MOT1:
  51.         MOV DX,TCON0
  52.             MOV AX,50
  53.         OUT DX,AL
  54.             MOV AL,AH
  55.             OUT DX,AL
  56.
  57.         MOV DX,IOA
  58.             IN  AL,DX
  59.             TEST AL,02H
  60.             JE MOT2
  61.         TEST AL,04H
  62.         JE MOT3
  63.         JMP MOT1
  64. MOT2:
  65.         MOV DX,TCON0
  66.             MOV AX,20
  67.         OUT DX,AL
  68.             MOV AL,AH
  69.             OUT DX,AL
  70.
  71.         MOV DX,IOA
  72.             IN  AL,DX
  73.             TEST AL,01H
  74.             JE MOT1
  75.         TEST AL,04H
  76.         JE MOT3
  77.         JMP MOT2
  78. MOT3:
  79.         MOV DX,TCON0
  80.             MOV AX,10
  81.         OUT DX,AL
  82.             MOV AL,AH
  83.             OUT DX,AL
  84.
  85.         MOV DX,IOA
  86.             IN  AL,DX
  87.             TEST AL,01H
  88.             JE MOT1
  89.         TEST AL,02H
  90.         JE MOT2
  91.         JMP MOT3
  92.
  93. DELAY:  PUSH CX
  94.         MOV CX,0FH
  95. DELAY1:        NOP
  96.         NOP
  97.         NOP
  98.         NOP
  99.         LOOP DELAY1
  100.         POP CX
  101.         RET
  102.
  103. CODE    ENDS
  104.
  105. STACK   SEGMENT 'STACK'
  106. STA     DB  100 DUP('?')
  107. TOP     EQU $-STA
  108. STACK   ENDS
  109. DATA    SEGMENT 'DATA'
  110. DATA    ENDS
  111.         END START
ID:668657 發(fā)表于 2020-6-15 16:37 來自觸屏版 | 只看該作者
有仿真圖嗎
ID:668657 發(fā)表于 2020-6-15 16:50 來自觸屏版 | 只看該作者
老哥有完整版嗎
無效樓層,該帖已經(jīng)被刪除
