查看: 3083|回復(fù): 1
基于STC89C51的溫度報警器實現(xiàn)
ID:271749 發(fā)表于 2018-1-5 03:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 zhouyuan12 于 2018-1-5 05:32 編輯
#include <reg52.h>
#include "eepom52.h"
#define uint  unsigned int
//數(shù)碼管段選定義      0    1    2    3   4    5 6      7     8     9
uchar codesmg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
                              0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff};     //斷碼
//數(shù)碼管位選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
uchar dis_smg[8] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
uchar smg_i = 3;    //顯示數(shù)碼管的個位數(shù)
sbit dq   = P2^4;     //18b20 IO口的定義
sbit beep = P2^5;   //蜂鳴器IO口定義
uchar a_a;
uint temperature ;  //
bit flag_300ms ;
uchar key_can;          //按鍵值的變量
uchar menu_1;        //菜單設(shè)計的變量
uint t_high = 300,t_low = 100;
bit flag_lj_en;           //按鍵連加使能
bit flag_lj_3_en;        //按鍵連3次連加后使能加的數(shù)就越大了
uchar key_time,flag_value;     //用做連加的中間變量
bit key_500ms  ;
uchar flag_clock;
uchar zd_break_en,zd_break_value;  //自動退出設(shè)置界面
/***********************1ms延時函數(shù)*****************************/
void delay_1ms(uint q)
   uint i,j;
   for(i=0;i<q;i++)
          for(j=0;j<120;j++);
/***********************小延時函數(shù)*****************************/
void delay_uint(uint q)
   while(q--);
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
   uchar i;
   for(i=0;i<smg_i;i++)
          P3 = smg_we;                  //位選
          P1 = dis_smg;            //段選
          delay_1ms(1);
          P3 = 0xff;                    //位選
          P1 = 0xff;                    //消隱
/******************把數(shù)據(jù)保存到單片機內(nèi)部eepom******************/
void write_eepom()
   SectorErase(0x2000);
   byte_write(0x2000, t_high %256);
   byte_write(0x2001, t_high /256);
   byte_write(0x2002, t_low %256);
   byte_write(0x2003, t_low /256);
   byte_write(0x2055, a_a);
/******************把數(shù)據(jù)從單片機內(nèi)部eepom中讀出來*****************/
void read_eepom()
   t_high  = byte_read(0x2001);
   t_high <<= 8;
   t_high  |= byte_read(0x2000);
   t_low   =byte_read(0x2003);
   t_low <<= 8;
   t_low   |= byte_read(0x2002);
   a_a      = byte_read(0x2055);
/***********************18b20初始化函數(shù)*****************************/
void init_18b20()
   bit q;
   dq = 1;                         //把總線拿高
   delay_uint(1);          //15us
   dq = 0;                         //給復(fù)位脈沖
   delay_uint(80);            //750us
   dq = 1;                         //把總線拿高 等待
   delay_uint(10);            //110us
   q = dq;                         //讀取18b20初始化信號
   delay_uint(20);            //200us
   dq = 1;                         //把總線拿高 釋放總線
/*************18b20內(nèi)的數(shù)據(jù)***************/
void write_18b20(uchar dat)
   uchar i;
   for(i=0;i<8;i++)
   {                                  //寫數(shù)據(jù)是低位開始
          dq = 0;                  //把總線拿低寫時間隙開始
          dq = dat & 0x01; //18b20總線寫數(shù)據(jù)了
          delay_uint(5);        //60us
          dq = 1;                  //釋放總線
          dat >>= 1;
/*************讀取18b20內(nèi)的數(shù)據(jù)***************/
uchar read_18b20()
   uchar i,value;
   for(i=0;i<8;i++)
          dq = 0;                  //把總線拿低讀時間隙開始
          value >>= 1;   //讀數(shù)據(jù)是低位開始
          dq = 1;                  //釋放總線
          if(dq == 1)             //開始讀寫數(shù)據(jù)
                 value |= 0x80;
          delay_uint(5);       //60us   讀一個時間隙最少要保持60us的時間
   return value;         //返回數(shù)據(jù)
/*************讀取溫度的值 讀出來的是小數(shù)***************/
uint read_temp()
   uint value;
   uchar low;                     //在讀取溫度的時候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會影響到18b20的時序
   init_18b20();            //初始化18b20
   write_18b20(0xcc);        //跳過64ROM
   write_18b20(0x44);        //啟動一次溫度轉(zhuǎn)換命令
   delay_uint(50);               //500us
   write_18b20(0xbe);        //發(fā)出讀取暫存器命令
   EA = 0;
   low = read_18b20();        //讀溫度低字節(jié)
   value = read_18b20();  //讀溫度高字節(jié)
   EA = 1;
   value <<= 8;            //把溫度的高位左移8
   value |= low;            //把讀出的溫度低位放到value的低八位中
   value *= 0.625;           //轉(zhuǎn)換到溫度值 小數(shù)
   return value;            //返回讀出的溫度帶小數(shù)
/*************定時器0初始化程序***************/
void time_init()
   EA   = 1;            //開總中斷
   TMOD = 0X01;      //定時器0、定時器1工作方式1
   ET0  = 1;             //開定時器0中斷
   TR0  = 1;             //允許定時器0定時
/****************獨立按鍵處理函數(shù)************************/
void key()
   static uchar key_new =0,key_old = 0,key_value = 0;
   if(key_new == 0)
   {                                           //按鍵松開的時候做松手檢測
          if((P2 & 0x0f) == 0x0f)
                 key_value ++;
                 key_value = 0;
          if(key_value >= 10)
                 write_eepom();
                 key_value = 0;
                 key_new = 1;
                 flag_lj_en = 0;             //關(guān)閉連加使能
                 flag_lj_3_en = 0;   //關(guān)閉3秒后使能
                 flag_value = 0;             //清零
          if((P2 & 0x0f) != 0x0f)
                 key_value ++;  //按鍵按下的時候
                 key_value = 0;
          if(key_value >= 7)
                 key_value = 0;
                 key_new = 0;
                 flag_lj_en = 1;       //連加使能
                 zd_break_en = 1;//自動退出設(shè)置界使能
                 zd_break_value =0; //自動退出設(shè)置界變量清零
   key_can = 20;
   if(key_500ms == 1)
          key_500ms = 0;
          zd_break_en = 1; //自動退出設(shè)置界使能
          zd_break_value = 0; //自動退出設(shè)置界變量清零
          key_new = 0;
          key_old = 1;
   if((key_new == 0) &&(key_old == 1))
          switch(P2 & 0x0f)
                 case 0x0e: key_can= 4; break;       //得到k1鍵值
                 case 0x0d: key_can= 3; break;       //得到k2鍵值
                 case 0x0b: key_can= 2; break;       //得到k3鍵值
                 case 0x07: key_can= 1; break;       //得到k4鍵值
   key_old = key_new;
/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
void key_with()
   if(key_can == 4)
          menu_1 ++;
          if(menu_1 >= 3)
                 menu_1 = 0;
          if(menu_1 == 0)
                 dis_smg[0] =smg_du[temperature % 10];  //取溫度的小數(shù)顯示
                 dis_smg[1] =smg_du[temperature / 10 % 10] & 0x7f; //取溫度的個位顯示
                 dis_smg[2] =smg_du[temperature / 100 % 10] ;        //取溫度的十位顯示
                 smg_i = 3;
          if(menu_1 == 1)
                 dis_smg[0] =smg_du[t_high % 10];             //取小數(shù)顯示
                 dis_smg[1] =smg_du[t_high / 10 % 10] & 0x7f;  //取個位顯示
                 dis_smg[2] =smg_du[t_high / 100 % 10] ;          //low十位顯示
                 dis_smg[3] = 0x89;
                 smg_i = 4;
          if(menu_1 == 2)
                 dis_smg[0] =smg_du[t_low % 10];              //low小數(shù)顯示
                 dis_smg[1] =smg_du[t_low / 10 % 10] & 0x7f;  //取個位顯示
                 dis_smg[2] =smg_du[t_low / 100 % 10] ;    //取十位顯示
                 dis_smg[3] = 0xc7;
                 smg_i = 4;
   if(menu_1 == 1)                 //設(shè)置高溫報警
          if(key_can == 3)
                 if(flag_lj_3_en ==0)
                        t_high ++ ;           //按鍵按下未松開自動加三次
                        t_high += 10; //按鍵按下未松開自動加三次之后每次自動加10
                 if(t_high >990)
                        t_high = 990;
                 dis_smg[2] =smg_du[t_high / 100 % 10] ;          //取十位顯示
                 dis_smg[3] = 0x89;       //H
          if(key_can == 1)
                        t_high -- ;             //按鍵按下未松開自動加三次
                        t_high -= 10; //按鍵按下未松開自動減三次之后每次自動減10
                 if(t_high <=t_low)
                        t_high = t_low + 1;
//        write_eepom();
   if(menu_1 == 2)                 //設(shè)置低溫報警
          if(key_can == 3)
                        t_low ++ ;
                        t_low += 10;
                 if(t_low >=t_high)
                        t_low = t_high - 1;
                 dis_smg[0] =smg_du[t_low % 10];              //取小數(shù)顯示
                 dis_smg[3] = 0xc7;        //L
          if(key_can == 1)
                        t_low -- ;
                        t_low -= 10;
                 if(t_low <= 10)
                        t_low = 10;
//        write_eepom();
/****************報警函數(shù)***************/
void clock_h_l()
   if((temperature <= t_low)|| (temperature >= t_high))
          flag_clock = 1;
          flag_clock = 0;
          beep = 1;
   temperature = read_temp();        //先讀出溫度的值
   time_init();                    //初始化定時器
   read_eepom();
   if(a_a == 0xff)                                  //新的單片機初始單片機內(nèi)問EEPOM
          t_high = 300;
          t_low  = 100;
          a_a = 1;
          write_eepom();
   delay_1ms(650);
          display();                      //顯示函數(shù)
          key();                                 //按鍵程序
          if(key_can < 10)
                 key_with();                  //設(shè)置報警溫度
          if(flag_300ms == 1)             //300ms 處理一次溫度程序
                 clock_h_l();            //報警函數(shù)
                 if(flag_clock ==1)
                        beep = ~beep;
                 flag_300ms = 0;
                 if(menu_1 == 0)
                        smg_i = 3;
                        dis_smg[0] = smg_du[temperature % 10];  //取溫度的小數(shù)顯示
                        dis_smg[1] = smg_du[temperature / 10 %10] & 0x7f; //取溫度的個位顯示
                        dis_smg[2] = smg_du[temperature / 100 %10] ;        //取溫度的十位顯示
                 if(zd_break_en ==1)    //自動退出設(shè)置界面程序
                        zd_break_value ++;  //300ms加一次
                        if(zd_break_value > 50)   //15秒后自動退出設(shè)置界面
                               menu_1= 0;
                               zd_break_en= 0;
                               zd_break_value= 0;
/*************定時器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
   static uchar value;
   TH0 = 0x3c;
   TL0 = 0xb0;     // 50ms
   value ++;
   if(value % 6 == 0)
          flag_300ms = 1;       //300ms
          value = 0;
   if(flag_lj_en == 1)    //按下按鍵使能
          key_time ++;
          if(key_time >= 10) //500ms
                 key_time = 0;
                 key_500ms = 1; //500ms
                 flag_value ++;
                 if(flag_value >3)
                        flag_value = 10;
                        flag_lj_3_en = 1; //3次后1.5秒連加大些
ID:276340 發(fā)表于 2018-1-15 19:46 | 只看該作者
點贊!
