查看: 2169|回復: 0
C51單片機
ID:271617 發表于 2018-1-4 20:57 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define BLANKCHAR 10
#define PCHAR 11
#define OPENCHAR 12
#define ALARMCHAR 13
#define LINECHAR 14
#define BACKKEY 0X0D
#define ENTERKEY 0X0F
#define LOCKKEY 0X0E
#define NO_KEY 20
uchar code KEYCODE[] = {0XEE,0XDE,0XBE,0X7E,0XED,0XDD,0XBD,0X7D,0XEB,0XDB,0XBB,0X7B,0XE7,0XD7,0XB7,0X77};
uchar KeyPre;
uchar KeyUp;
#define LEDPORT P0
#define LEDCON P1
#define KEYPORT P2
sbit ALARMCON = P3^3;
sbit LOCKCON = P3^5;
uchar code SEGCODE[] ={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90, 0XFF,0X8C,0X8F,0X88,0XBF,0X9f, };
uchar code BITCODE[6] = {0XC1,0XC2,0XC4,0XC8,0XD0,0XE0};
uchar DispBuf[6];
bit DispNormal;
uchar DispCnt;
#define SHORT_TIME 10
#define LONG_TIME 100
#define LONGER_TIME 9000
bit AlarmEnable;
uint AlarmTime;
uchar code PassWord[] = {1,2,3,4,5,6};
uchar PassInBuf[5];
uchar PassPosi;
bit TimerBit;
uchar SysMode;
uchar ErrorCnt;
void Delay(int z)
        uchar y;
        int x;
        for(x=z; x>0; x--)
                for(y=255; y>0; y--);
void Fill_Buf(uchar FillChar)
        uchar i;
        for (i=0; i<6; i++)
                DispBuf[i] = FillChar;
                PassInBuf[i] = FillChar;
void  Fill_Buf_P()
        Fill_Buf(BLANKCHAR);
        DispBuf[0] = PCHAR;
        LEDPORT = SEGCODE[PCHAR];
        LEDCON = BITCODE[5];
void  Fill_Buf_O()
        DispBuf[0] = OPENCHAR;
        LEDPORT = SEGCODE[OPENCHAR];
void  Fill_Buf_A()
        DispBuf[0] = ALARMCHAR;
        LEDPORT = SEGCODE[ALARMCHAR];
void  Disp_Led_Sin(uchar DispChar, uchar DispPosi)
        LEDPORT = SEGCODE[DispChar];//輸出顯示段碼
        LEDCON = BITCODE[DispPosi];//輸出顯示位碼
        Delay(500);
        LEDCON = 0X00;//關閉顯示器
void Sys_Speaker(uint stime)
        AlarmEnable = 1;//允許報警
        AlarmTime = stime;//報警時間長短
/*********系統報警函數**********/
void Sys_Alarm()
        if (AlarmEnable == 1)  //允許報警
                ALARMCON = 0;//報警
                AlarmTime--;
                if (AlarmTime == 0)        //停止報警時間到
                        AlarmEnable = 0;
                        ALARMCON = 1;
                        if (SysMode == 1) //報警發生在模式1.要返回模式0
                                SysMode = 0;
                                Fill_Buf_P();//顯示P
uchar Find_Key()
        uchar KeyTOP, i;
        KEYPORT = 0XF0;//行線輸出全0,列線輸出全1
        KeyTOP = KEYPORT;//讀按鍵端口值
        if(KeyTOP == 0XF0)
                return NO_KEY;
        KEYPORT = KeyTOP | 0X0F;//列線輸出,行線輸入
        KeyTOP = KEYPORT;
        for (i=0; i<16; i++)
                if(KeyTOP == KEYCODE[i])//根據按鍵端口掃描值,查找按鍵值
                        return i;//返回按鍵值
                else if(i >= 15)
                                i = NO_KEY;
                                return i;
uchar Scan_Key()
        uchar KeyTOP;
        KeyTOP = Find_Key();//接收按鍵檢測的返回值
        if (KeyTOP != NO_KEY)
                Delay(100);
                        KeyPre = KeyTOP;
                while(KeyTOP == Find_Key());
                return KeyPre;
                return NO_KEY;
void Key_Process(uchar Key)
        uchar i;
        if (Key == NO_KEY)
                return;//無按鍵,不處理
        switch(SysMode)
                case 0://輸入密碼
                        switch(Key)
                                case 0:
                                case 1:
                                case 2:
                                case 3:
                                case 4:
                                case 5:
                                case 6:
                                case 7:
                                case 8:
                                case 9:
                                        Disp_Led_Sin(Key,PassPosi);
                                        PassInBuf[PassPosi] = Key;//保存用戶輸入的密碼
                                        if (PassPosi<5)
                                                PassPosi++;//調整密碼輸入位置
                                        Sys_Speaker(SHORT_TIME);//發按鍵提示音
                                        break;
                                case 20:break;
                                case BACKKEY:
                                        DispBuf[PassPosi] =  BLANKCHAR;//顯示空鍵
                                        PassInBuf[PassPosi] = BLANKCHAR;//清除當前位置的密碼
                                        if (PassPosi>0)
                                                PassPosi--;//調整顯示位置
                                                Disp_Led_Sin(15,5);
                                        break;
                                case ENTERKEY:
                                        for (i=0; i<5; i++)//比較用戶密碼是否與預設密碼一致
                                                if (PassInBuf[i] != PassWord[i])
                                                        break;
                                        if (i>=5)//輸入密碼正確
                                                 Fill_Buf_O();//顯示開鎖狀態
                                                 PassPosi = 0;
                                                 LOCKCON = 1;//開鎖
                                                 ErrorCnt = 0;
                                                 Sys_Speaker(LONG_TIME);//發長提示音
                                                 SysMode = 2;//轉模式2
                                                 ErrorCnt++;
                                                 if(ErrorCnt>2)//超過3次
                                                         ErrorCnt = 0;
                                                        Fill_Buf_A();//顯示報警狀態
                                                        PassPosi = 0;
                                                        Sys_Speaker(LONGER_TIME);//發報警音
                                                        SysMode = 1;
                                                 else //少于3次,重新輸入
                                                          Fill_Buf_P();
                                                         PassPosi = 0;
                                        break;
                                        case LOCKKEY://閉鎖鍵
                                                Fill_Buf_P();
                                                PassPosi = 0;
                                                 Sys_Speaker(SHORT_TIME);//發短提示音
                                                break;
                        break;
                        case 2://開鎖狀態
                                if (Key == LOCKKEY)//用戶按動閉鎖按鍵
                                        Fill_Buf_P();
                                        SysMode = 0;
                                        LOCKCON = 0;//閉鎖
                                break;
void Init_Timer()
        TMOD &= 0XF0;
        TMOD |= 0X01;
        TR0 = 0;
        TH0 = (65536-20000) / 256;
        TL0 = (65536-20000) % 256;
        TR0 = 1;
        ET0 = 1;
void Timer0() interrupt 1
        TR0 = 0;
        TR0 = 1;
        TimerBit = 1;//20ms定時時間到
void Init_System()
        PassPosi = 1;
        LOCKCON = 0; //閉鎖
        Init_Timer();
        Fill_Buf_P();
        EA = 1;
        uchar KeyTemp;
        Init_System();
        PassPosi = 0;
                if(TimerBit == 1)
                        Sys_Alarm();//報警函數
                        KeyTemp = Scan_Key();//按鍵掃描
                        Key_Process(KeyTemp);//按鍵處理
                        TimerBit = 0;
