查看: 2092|回復: 0
按鍵控制有源蜂鳴器報警
ID:271219 發表于 2018-1-4 10:20 | 顯示全部樓層 |閱讀模式
按鍵控制有源蜂鳴器報警:
#include <reg51.h>
  sbit BEEP=P1^0;
  sbit ButtonA=P3^2;
  sbit ButtonB=P3^3;
  bit playOn;
void Delay(unsigned int t)
    unsigned char m;
    while(t--)
    for(m=0;m<120;m++);
void EXT0_ISR() interrupt 0 using 1
     unsigned char i;
     i f(ButtonA==0)
          for(i=0;i<20;i++);
           if(ButtonA==0)
                    while(ButtonA==0);
                       playOn=1;
  void EXT1_ISR() interrupt 2 using 2
     unsigned char i;
     if(ButtonB==0)
         for(i=0;i<20;i++);
         if(ButtonB==0)
              while(ButtonB==0);
              playOn=0;
BEEP=1;
playOn=0;
if(playOn==1)
BEEP=0;
BEEP=1;
Delay(1000);
