MCS-51系列單片機指令速查表 算術運算指令 (共24條) 邏輯運算指令 (共25條) 數據傳送指令 (共28條) | 機器碼 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ((direct))→direct (SP)-1→SP | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
位操作指令 (共12條) 控制轉移指令 (共22條) | 機器碼 | | | | | | | | | | | | (PC)+2→PC (SP)+1→SP (PC)L→SP (SP)+1→SP (PC)H→SP addr11→PC10~0 | | | | | | | | | (PC)+2→PC (SP)+1→SP (PC)L→SP (SP)+1→SP (PC)H→SP addr16→PC | | | | | | | | | ((SP))→PCH (SP)-1→SP ((SP))→PCL (SP)-1→SP | | | | | | | | | ((SP))→PCH (SP)-1→SP ((SP))→PCL (SP)-1→SP 從中斷返回 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | (PC)+2→PC 若(A)=0,(PC)+(rel)→PC | | | | | | | | | (PC)+2→PC 若(A)≠0,(PC)+(rel)→PC | | | | | | | | | (PC)+2→PC 若(Cy)=1,(PC)+(rel)→PC | | | | | | | | | (PC)+2→PC 若(Cy)=0,(PC)+(rel)→PC | | | | | | | | | (PC)+3→PC 若(bit)=1,(PC)+(rel)→PC | | | | | | | | | (PC)+3→PC 若(bit)≠1,(PC)+(rel)→PC | | | | | | | | | (PC)+3→PC 若(bit)=1,0 → bit, (PC)+(rel)→PC | | | | | | | | | (PC)+3→PC 若(A)≠(direct),則(PC)+(rel)→PC 若(A)<(direct),則1→Cy | | | | | | | | | (PC)+3→PC 若(A)≠data,則(PC)+(rel)→PC 若(A)<DATA,則1→CY< font> | | | | | | | | | (PC)+3→PC 若(Rn)≠data,則(PC)+(rel)→PC 若(Rn)<DATA,則1→CY< font> | | | | | | | | | (PC)+3→PC 若((Ri))≠data,則(PC)+(rel)→PC 若((Ri))<DATA,則1→CY< font> | | | | | | | | | (PC)+2→PC,(Rn)-1→Rn 若(Rn)≠0,則(PC)+(rel)→PC | | | | | | | | | (PC)+2→PC,(direct)-1→direct 若(direct)≠0,則(PC)+(rel)→PC | | | | | | | | | | | | | | | |
偽指令(共7條) | 偽指令 | | | | | | | 將一個常數或匯編符號賦給字符名,相當于C語言的define | | | | | | 從指定的ROM地址單元開始存入DB后面的數據,這些數據可以是用逗號隔開的字節串或括在單引號中的ASCII字符串 | | | 從指定的ROM地址開始,在連續的單元中定義雙字節數據 | | | 從指令地址開始保留DS之后表達式的值所規定的存儲單元數,以備后用 | | | | |
51單片機指令速查表.doc
2018-1-2 22:10 上傳
下載積分: 黑幣 -5
225 KB, 下載次數: 26, 下載積分: 黑幣 -5
