查看: 1840|回復: 0
密碼鎖
ID:270029 發表于 2018-1-2 17:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//原始程序中相鄰兩位密碼不能相同.
//本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
//實訓100例中本例內的main函數可用以下代碼替換.
//改動的主要是main函數中while循環內的代碼.
// 主程序
   uchar i = 0;
   uchar IIC_Password[10];
   uchar IS_Valid_User = 0;
   P0 = 0xFF;
   P1 = 0xFF;
   P2 = 0xFF;
   TMOD = 0x02;                     //T0設置為8位自動重裝模式
   TH0 = 175;
   TL0 = 175;
   TR0 = 1;                         //啟動T0
   DelayMS(10);
   LCD_Init();                      //初始化LCD
   IIC_24C04_Init();                //初始化24C04
   Display_String(Title_Text,0x00); //在第1行顯示標題
   //24C04的內容已由初始化BIN文件導入
   //將24C04中預先寫入的密碼讀入pass
   RecString(0xa0, 0 , IIC_Password, 6);
   IIC_Password[6] = '\0';
      P1 = 0xF0;
      if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
      switch ( KeyNo )
           case 0:  case 1: case 2: case 3: case 4:
           case 5:  case 6: case 7: case 8: case 9:
                   if ( i<= 5 )             //密碼限制在6位以內
                        //如果i為0則執行一次清屏
                        if (i ==0) Display_String("                ",0x40);
                        UserPassword[i] = KeyNo + '0';
                        UserPassword[i+1] = '\0';
                        DSY_BUFFER[i] = '*';
                        DSY_BUFFER[i+1] = '\0';
                        Display_String(DSY_BUFFER,0x40);
                        i++;
                    break;
           case 10: //按A鍵開鎖
                    if (strcmp(UserPassword,IIC_Password) == 0)
                       LED_OPEN = 0;  //點亮LED
                       Clear_Password();
                       Display_String("Unlock OK!      ",0x40);
                       IS_Valid_User = 1;
                       LED_OPEN =1;   //關閉LED
                       Clear_Password();
                       Display_String("ERROR !         ",0x40);
                       IS_Valid_User = 0;
                    i = 0;
                    break;
           case 11: //按B鍵上鎖
                    LED_OPEN =1;
                    Clear_Password();
                    i = 0;
                    IS_Valid_User = 0;
                    break;
           case 12: //按C鍵設置新密碼
                    //如果是合法用戶則提示輸入新密碼
                    if ( !IS_Valid_User ) Display_String("No rights !",0x40);
                       i = 0;
                       Display_String("New Password:   ",0x00);
                    break;
           case 13: //按D鍵保存新密碼
                       SendString(0xa0, 0 , UserPassword, 6);
                       //重新讀入剛寫的密碼
                       i = 0;
                       Display_String("Password Saved! ",0x40);
                    break;
           case 14: //按E鍵消除所有輸入
                    i = 0;
                    Clear_Password();
       Beep();
       DelayMS(100);
       P1= 0xF0;
       while (P1 != 0xF0);    //如果有鍵未釋放則等待
       while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
