BLCD FOC控制 軟件
stm32單片機(jī)源程序如下:
- /******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
- * File Name : main.c
- * Author : IMS Systems Lab
- * Date First Issued : 21/11/07
- * Description : Main program body.
- * History:
- * 21/11/07 v1.0
- * 29/05/08 v2.0
- * 27/06/08 v2.0.1
- * THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- * CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * THIS SOURCE CODE IS PROTECTED BY A LICENSE.
- * FOR MORE INFORMATION PLEASE CAREFULLY READ THE LICENSE AGREEMENT FILE LOCATED
- * IN THE ROOT DIRECTORY OF THIS FIRMWARE PACKAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x_lib.h"
- #include "stm32f10x_MClib.h"
- #include "MC_Globals.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- void NVIC_Configuration(void);
- void GPIO_Configuration(void);
- void RCC_Configuration(void);
- * Function Name : main
- * Description : Main program.
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- NVIC_Configuration();
- RCC_Configuration();
- GPIO_Configuration();
- #ifdef THREE_SHUNT
- SVPWM_3ShuntInit();
- #elif defined ICS_SENSORS
- SVPWM_IcsInit();
- #elif defined SINGLE_SHUNT
- SVPWM_1ShuntInit();
- #endif
- #ifdef ENCODER
- ENC_Init();
- #ifdef OBSERVER_GAIN_TUNING
- STO_StateObserverInterface_Init();
- STO_Init();
- #endif
- #elif defined HALL_SENSORS
- HALL_HallTimerInit();
- STO_Init();
- #endif
- #elif defined NO_SPEED_SENSORS
- STO_Init();
- #ifdef VIEW_ENCODER_FEEDBACK
- ENC_Init();
- #elif defined VIEW_HALL_FEEDBACK
- #endif
- #endif
- #ifdef DAC_FUNCTIONALITY
- MCDAC_Init();
- #endif
- TB_Init();
- PID_Init(&PID_Torque_InitStructure, &PID_Flux_InitStructure, &PID_Speed_InitStructure);
- #ifdef BRAKE_RESISTOR
- MCL_Brake_Init();
- #endif
- KEYS_Init();
- /* TIM1 Counter Clock stopped when the core is halted */
- DBGMCU_Config(DBGMCU_TIM1_STOP, ENABLE);
- // Init Bus voltage and Temperature average
- MCL_Init_Arrays();
- LCD_Init();
- LCD_Clear(White);
- LCD_SetTextColor(Blue);
- LCD_SetBackColor(White);
- Display_Welcome_Message();
- while(1)
- Display_LCD();
- MCL_ChkPowerStage();
- //User interface management
- KEYS_process();
- switch (State)
- case IDLE: // Idle state
- break;
- case INIT:
- MCL_Init();
- TB_Set_StartUp_Timeout(3000);
- State = START;
- break;
- case START:
- //passage to state RUN is performed by startup functions;
- break;
- case RUN: // motor running
- #ifdef ENCODER
- if(ENC_ErrorOnFeedback() == TRUE)
- MCL_SetFault(SPEED_FEEDBACK);
- if(HALL_IsTimedOut())
- if (HALL_GetSpeed() == HALL_MAX_SPEED)
- #endif
- break;
- case STOP: // motor stopped
- // shutdown power
- /* Main PWM Output Disable */
- TIM_CtrlPWMOutputs(TIM1, DISABLE);
- State = WAIT;
- SVPWM_3ShuntAdvCurrentReading(DISABLE);
- #endif
- #ifdef SINGLE_SHUNT
- SVPWM_1ShuntAdvCurrentReading(DISABLE);
- #endif
- Stat_Volt_alfa_beta.qV_Component1 = Stat_Volt_alfa_beta.qV_Component2 = 0;
- #ifdef ICS_SENSORS
- SVPWM_IcsCalcDutyCycles(Stat_Volt_alfa_beta);
- #elif defined THREE_SHUNT
- SVPWM_3ShuntCalcDutyCycles(Stat_Volt_alfa_beta);
- #endif
- TB_Set_Delay_500us(2000); // 1 sec delay
- break;
- case WAIT: // wait state
- if (TB_Delay_IsElapsed() == TRUE)
- #ifdef ENCODER
- if(ENC_Get_Mechanical_Speed() ==0)
- State = IDLE;
- if (HALL_IsTimedOut())
- State=IDLE;
- STO_InitSpeedBuffer();
- State=IDLE;
- #endif
- break;
- case FAULT:
- if (MCL_ClearFault() == TRUE)
- if(wGlobal_Flags & SPEED_CONTROL == SPEED_CONTROL)
- bMenu_index = CONTROL_MODE_MENU_1;
- else
- bMenu_index = CONTROL_MODE_MENU_6;
- #if defined NO_SPEED_SENSORS
- #endif
- State = IDLE;
- wGlobal_Flags |= FIRST_START;
- break;
- default:
- break;
- * Function Name : GPIO_Configuration
- * Description : Configures the TIM1 Pins.
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable GPIOC clock */
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_DeInit(GPIOC);
- GPIO_StructInit(&GPIO_InitStructure);
- /* Configure PC.06, PC.07, PC.08 and PC.09 as Output push-pull for debugging
- purposes */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- ErrorStatus HSEStartUpStatus;
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- while(RCC_GetSYSCLKSource() != 0x08)
- * Function Name : NVIC_Configuration
- * Description : Configures the Vector Table base address.
- * Input : None
- * Output : None
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
MC _KIT_20.zip
(2.98 MB, 下載次數(shù): 116)
2018-1-2 09:06 上傳
點(diǎn)擊文件名下載附件
