單片機(jī)源程序如下:
- #include "TIM_pwm_output.h"
- * @brief 配置TIM2和TIM3時(shí)復(fù)用輸出PWM時(shí)用到的I/O
- * @param 無
- * @retval 無
- static void TIM_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /*設(shè)置TIM2CLK和TIM3CLk 為72MHZ*/
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);
- /* GPIOA clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
- /*GPIOA Configuration: TIM2 channel 1 2 3 4 6 and 7
- as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|
- GPIO_Pin_2| GPIO_Pin_3|GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 復(fù)用推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- * @brief 配置TIM2、TIM3輸出的PWM信號(hào)的模式,如周期,極性,占空比
- * @param 無
- * @retval 無
- * TIMxCLK/CK_PSC --> TIMxCNT --> TIMx_ARR --> TIMxCNT 重新計(jì)數(shù)
- * TIMx_CCR(電平發(fā)生變化)
- * 信號(hào)周期=(TIMx_ARR +1 ) * 時(shí)鐘周期
- * 占空比=TIMx_CCR/(TIMx_ARR +1)
- static void TIM_Mode_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* 初始化PWM信號(hào)電平 */
- u16 CCR1_Val = 0;
- u16 CCR2_Val = 0;
- u16 CCR3_Val = 0;
- u16 CCR4_Val = 0;
- u16 CCR5_Val = 0;
- u16 CCR6_Val = 0;
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 999; //當(dāng)定時(shí)器計(jì)數(shù)1000次,為一個(gè)周期
- TIM_TimeBaseStructure.TIM_Prescaler = 5; //設(shè)置預(yù)分頻,預(yù)分頻為5,pwm頻率為12KHZ
- /* 設(shè)置時(shí)鐘分頻系數(shù) */
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計(jì)數(shù)模式
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置為PWM模式1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- TIM_OC1Init(TIM2, &TIM_OCInitStructure); //使能通道1
- TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
- TIM_OC2Init(TIM2, &TIM_OCInitStructure); //使能通道2
- TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel3 */
- TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
- TIM_OC3Init(TIM2, &TIM_OCInitStructure); //使能通道3
- TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel4 */
- TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
- TIM_OC4Init(TIM2, &TIM_OCInitStructure); //使能通道4
- TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(TIM2, ENABLE); // 使能TIM2重載寄存器ARR
- /* PWM1 Mode configuration: Channel5 */
- TIM_OCInitStructure.TIM_Pulse = CCR5_Val;
- TIM_OC1Init(TIM3, &TIM_OCInitStructure); //使能通道5
- TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel6 */
- TIM_OCInitStructure.TIM_Pulse = CCR6_Val;
- TIM_OC2Init(TIM3, &TIM_OCInitStructure); //使能通道6
- TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(TIM3, ENABLE); // 使能TIM3重載寄存器ARR
- /* TIM2 and TIM3 enable counter */
- TIM_Cmd(TIM2, ENABLE); //使能定時(shí)器2
- TIM_Cmd(TIM3, ENABLE); //使能定時(shí)器3
- void TIM_PWM_Init(void)//
- TIM_GPIO_Config();
- TIM_Mode_Config();
- void TIM_PWM1_Update(double n)
- u16 CCR1_Val = n*999;
- TIM_SetCompare1(TIM2, CCR1_Val);
- void TIM_PWM2_Update(double n)
- u16 CCR2_Val = n*999;
- TIM_SetCompare2(TIM2, CCR2_Val);
- void TIM_PWM3_Update(double n)
- u16 CCR3_Val = n*999;
- TIM_SetCompare3(TIM2, CCR3_Val);
- void TIM_PWM4_Update(double n)
stm32f10x_temple-nb-1401011140.zip
(672.48 KB, 下載次數(shù): 63)
2017-12-26 18:01 上傳
點(diǎn)擊文件名下載附件
六路pwm波輸出 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
