alarmflag=1;
//led=0;
lcdinit();//初始化液晶函數(shù)
ds1302_init();//DS1302時(shí)鐘芯片初始化函數(shù)
init();//定時(shí)器初始化函數(shù)
beep=0;
delay(200);
beep=1;
//led=0;
year1=(nian)/10*16+(nian)%10;//轉(zhuǎn)換為bcd碼
month1=(yue)/10*16+(yue)%10;
day1=(ri)/10*16+(ri)%10;
chushihua();//初始化時(shí)間函數(shù)
Conversion(0,year1,month1,day1);//
timealarm();//報(bào)時(shí)程序
keyscan();//不斷掃面按鍵函數(shù)
/*if(key2==1)//加鍵不按下時(shí)才有用
ledcontrol();//背光控制
void timer0() interrupt 1//中斷任務(wù):取數(shù)據(jù)并顯示
TH0=(65536-60000)/256;//重新賦初值
TL0=(65536-60000)%256;
//讀取數(shù)據(jù)
flag=ReadTemperature();//讀取溫度(考慮是否放在此處)
miao=turnBCD(read_1302(0x81));//讀出秒
fen=turnBCD(read_1302(0x83));//讀出分
shi=turnBCD(read_1302(0x85));//讀出時(shí)
ri=turnBCD(read_1302(0x87));//讀出日
yue=turnBCD(read_1302(0x89));//讀出月
nian=turnBCD(read_1302(0x8d));//讀出年
week=turnBCD(read_1302(0x8b));//讀出周
//顯示數(shù)據(jù)
if(((0<=miao)&&(miao<15))||(((miao/10==2)||(miao/10==4))&&(miao%10<=5))||((54<=miao)&&(miao<60))) /*顯示所有信息的時(shí)間段*/
print(0x80,"20 / / W < >");
writecom(h1+0x0c);
writedata(0x7e);//→右箭頭
writeday(8,ri);//顯示日
writeday(5,yue);//顯示月
writeday(2,nian);//顯示年
writeweek(week);//顯示星期
print(0x40," : : ");
writetemp(9,flag);//顯示溫度,第二行顯示
writetime(6,miao);//顯示出秒
writetime(3,fen);//顯示出分
writetime(0,shi);//顯示出時(shí),第二行第一個(gè)開(kāi)始
} //if(15<=miao)/*當(dāng)秒大于15時(shí)才顯示*/
if(((miao/10==1)||(miao/10==3))&&(miao%10>=5))
switch(flag/100)//取出溫度的十位數(shù)
case 0:print(0x80,"Pretty cold now!");
break;
case 1:print(0x80,"little cold now!");
break;
case 2:print(0x80,"It is warm now. ");
break;
case 3:print(0x80,"It's hot !!! ");
break;
case 4:print(0x80,"Very very hot!!!");
break;
case 5:print(0x80,"Very very hot!!!");
break;
case 6:print(0x80,"Very very hot!!!");
break;
//print(0x80,"It is warm now. ");
if(((miao/10==2)||(miao/10==4))&&(miao%10>=5))/*25-30 45-50*/
if((5<=shi)&&(shi<=11)) flagT=1;//5-11時(shí)為早上
if((11<shi)&&(shi<=14)) flagT=2;//11-14為中午
if((14<shi)&&(shi<=18)) flagT=3;//14-18為下午
if((18<shi)||(shi<5)) flagT=4;//18-24或者0-5為晚上
switch(flagT)//分段時(shí)間
case 1:print(0x80," Good Morning! ");
break;
case 2:print(0x80," Good Noon! ");
break;
case 3:print(0x80,"Good afternoon! ");
break;
case 4:print(0x80," Good night! ");
break;
if(((30<=miao)&&(miao<35))||((50<=miao)&&(miao<54)))//30-35 50-54
{//else改為范圍
festival();//選擇顯示節(jié)日
void timer1() interrupt 3//任務(wù):計(jì)時(shí)用作報(bào)時(shí)
TH1=(65536-50000)/256;//中斷后重新賦初值
TL1=(65536-50000)%256;
//count++;//計(jì)算時(shí)間
if(alarmflag==1)//設(shè)置鍵按下才有效
if(fen==0 && miao<4)
count++;
ledcount=count/10;//分開(kāi)時(shí)間段
switch(ledcount)
case 0:Gled=0;Yled=1;break;//從零開(kāi)始
case 1:Gled=1;Yled=0;break;
case 2:Gled=0;Yled=1;break;
case 3:Gled=1;Yled=0;break;
case 4:Gled=0;Yled=0;break;
case 5:Gled=1;Yled=1;break;
case 6:Gled=0;Yled=0;break;
case 7:Gled=0;Yled=0;count=0;break;//在這里面清零
else if(fen==30 && miao<2)
Gled=0;
Yled=0;
else {
Gled=1;
Yled=1;
