手頭上攢了一些手機電池不知道干嘛就尋思著做一些小玩意,于是就有了一個主意就是搖搖棒即簡單又好玩,本人喜歡小而巧的東西所以就把這個東西做的很小。
2017-12-25 23:04 上傳
上圖是搖搖棒的原理利用人的視覺暫留結合單片機控制LED的亮滅就可以在空中顯示字符或者圖標
2017-12-25 23:04 上傳
上圖是電路圖為了把東西做小我選擇了STC15F104單片機它有8個引腳去除VCC和GND還有6個I/O口可以顯示一些簡單的字母和數字單片機內部自帶了EEPROM所以利用它可以存儲每一次顯示的狀態(每一次的開關電源就可以切換到下一個顯示的字符)程序在最后面。
2017-12-25 23:05 上傳
顯示效果:
2017-12-25 23:05 上傳
單片機源程序如下: - #include
- #define uchar unsigned char
- #define EN_EPROM 0x83; //使能EEPROM
- #define S_MODE 0x00; //待機模式
- #define R_MODE 0x01; //讀模式
- #define W_MODE 0x02; //寫模式
- #define F_MODE 0x03; //擦除模式
- sfr IAP_DATA = 0xC2;
- sfr IAP_ADDRH = 0xC3;
- sfr IAP_ADDRL = 0xC4;
- sfr IAP_CMD = 0xC5;
- sfr IAP_TRIG = 0xC6;
- sfr IAP_CONTR = 0xC7;
- void init();
- uchar num=0,m=0;
- uchar read_dat(uchar addr_h,uchar addr_l);
- void erase_dat(uchar addr_h,uchar addr_l);
- void write_dat(uchar addr_h,uchar addr_l,uchar w_dat);
- unsigned char code tab[10][32]={
- 0xe7,0xc3,0xc1,0xe0,0xc1,0xc3,0xe7,0xff,
- 0xff,0xff,0xff,0xe7,0xc3,0xc1,0xe0,0xc1,
- 0xc3,0xe7,0xff,0xff,0xff,0xff,0xe7,0xc3,
- 0xc1,0xe0,0xc1,0xc3,0xe7,0xff,0xff,0xff
- 0xff,0xff,0xde,0xc0,0xde,0xff,0xff,0xff,
- 0xc3,0xe7,0xff,0xff,0xff,0xff,0xff,0xc1,
- 0xfe,0xfe,0xfe,0xfe,0xc1,0xff,0xff,0xff
- 0xde,0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,
- 0xff,0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,
- 0xde,0xff,0xff,0xff,0xff,0xff,0xff,0xde,
- 0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,0xff
- 0xfb,0xfd,0xd6,0xe8,0xd6,0xfd,0xfb,0xff,
- 0xff,0xff,0xff,0xfb,0xfd,0xd6,0xe8,0xd6,
- 0xfd,0xfb,0xff,0xff,0xff,0xff,0xfb,0xfd,
- 0xd6,0xe8,0xd6,0xfd,0xfb,0xff,0xff,0xff
- 0xea,0xd5,0xea,0xd5,0xea,0xd5,0xea,0xd5,
- 0xfa,0xfd,0xfa,0xff,0xef,0xd7,0xef,0xff,
- 0xf0,0xed,0xdd,0xed,0xf0,0xff,0xff,0xdf,
- 0xdf,0xc0,0xdf,0xdf,0xff,0xff,0xc1,0xfe,
- 0xfe,0xfe,0xc1,0xff,0xff,0xc1,0xfe,0xf1,
- 0xfe,0xc1,0xff,0xff,0xe1,0xde,0xde,0xe1
- 0xc0,0xfb,0xfb,0xfb,0xc0,0xff,0xff,0xff,
- 0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,0xde,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xcf,0xf7,
- 0xf8,0xf7,0xcf,0xff,0xff,0xff,0xff,0xff
- 0xc0,0xde,0xd2,0xda,0xda,0xc2,0xfe,0xc0,
- 0xdf,0xd0,0xd6,0xd6,0xd2,0xde,0xc0,0xff,
- 0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xfd,0xfb,
- 0xf7,0xef,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
- 0xfd,0xfb,0xf7,0xef,0xdf,0xef,0xf7,0xfb,
- 0xfd,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xff
- void delay(uchar xms)
- char i,j;
- for(i=0;i for(j=0;j<50;j++);
- void main()
- init();
- num=read_dat(0x00,0x01);
- ++num;
- if(num>=11)
- num=1;
- erase_dat(0x00,0x01);
- write_dat(0x00,0x01,num);
- while(1)
- uchar i=0;
- for(i=0;i<32;i++)
- P3=tab[num-1][i];
- delay(100);
- void init()
- IAP_CONTR = EN_EPROM; //把第7位置1允許EEPROM可以讀寫
- IAP_CMD = S_MODE; //待機模式無ISP操作
- IAP_ADDRH = 0x00;
- IAP_ADDRL = 0x00;
- uchar E_dat = 0x00;
- IAP_CMD = R_MODE; //模式選擇為讀EEPROM
- IAP_ADDRH = addr_h;
- IAP_ADDRL = addr_l;
- IAP_TRIG = 0x5A; //使命令有效
- IAP_TRIG = 0xA5; //使命令有效
- E_dat = IAP_DATA;
- return E_dat;
2017-12-25 23:06 上傳
