查看: 1837|回復: 0
任意I/O口的數碼管掃描
ID:265979 發表于 2017-12-24 11:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#define _LED_DIRIVE_C_
#include "main.h"
//====     數碼管管腳宏定義      ====//
#define            p_seg_a         P3_5
#define                  p_seg_b         P3_4
#define           p_seg_c         P2_7
#define                  p_seg_d         P0_2
#define                  p_seg_e         P0_0
#define                  p_seg_f         P2_5
#define           p_seg_g         P2_6
#define           p_seg_dp        P0_1
#define                        p_dig_0                                         P2_2
#define                        P_dig_1                                        P2_3
#define                        P_dig_2                                        P1_6
//====     數碼管顯示宏定義      ====//
#define BIT0                0x01
#define BIT1                0x02
#define BIT2                0x04
#define BIT3                0x08
#define BIT4                0x10
#define BIT5                0x20
#define BIT6                0x40
#define BIT7                0x80
#define seg_a   BIT0
#define seg_b   BIT1
#define seg_c   BIT2
#define seg_d   BIT3
#define seg_e   BIT4
#define seg_f   BIT5
#define seg_g   BIT6
#define seg_h   BIT7
#define seg00   (seg_a+seg_b+seg_c+seg_d+seg_e+seg_f)             //"0"
#define seg01   (seg_b+seg_c)        //"1"
#define seg02   (seg_a+seg_b+seg_d+seg_e+seg_g)                              //"2"
#define seg03   (seg_a+seg_b+seg_c+seg_d+seg_g)                              //"3"
#define seg04   (seg_b+seg_c+seg_f+seg_g)                                              //"4"
#define seg05   (seg_a+seg_c+seg_d+seg_f+seg_g)                                      //"5"
#define seg06   (seg_a+seg_c+seg_d+seg_e+seg_f+seg_g)                 //"6"
#define seg07   (seg_a+seg_b+seg_c)                                                      //"7"
#define seg08   (seg_a+seg_b+seg_c+seg_d+seg_e+seg_f+seg_g)           //"8"
#define seg09   (seg_a+seg_b+seg_c+seg_d+seg_f+seg_g)                 //"9"
#define seg10   (seg_a+seg_b+seg_c+seg_d+seg_e+seg_f+seg_h)           //"0."
#define seg11   (seg_b+seg_c+seg_h)        //"1."
#define seg12   (seg_a+seg_b+seg_d+seg_e+seg_g+seg_h)                      //"2."
#define seg13   (seg_a+seg_b+seg_c+seg_d+seg_g+seg_h)                          //"3."
#define seg14   (seg_b+seg_c+seg_f+seg_g+seg_h)                                          //"4."
#define seg15   (seg_a+seg_c+seg_d+seg_f+seg_g+seg_h)                                      //"5."
#define seg16   (seg_a+seg_c+seg_d+seg_e+seg_f+seg_g+seg_h)           //"6."
#define seg17   (seg_a+seg_b+seg_c+seg_h)        //"7."
#define seg18   (seg_a+seg_b+seg_c+seg_d+seg_e+seg_f+seg_g+seg_h)     //"8."
#define seg19   (seg_a+seg_b+seg_c+seg_d+seg_f+seg_g+seg_h)           //"9."
#define seg20   (0x00)        //關閉
#define seg21   (seg_g)        //"-"
u8 code table_seg[22]=//字形碼表
{seg00,seg01,seg02,seg03,seg04,seg05,seg06,seg07,seg08,seg09,
seg10,seg11,seg12,seg13,seg14,seg15,seg16,seg17,seg18,seg19,
seg20,seg21};
/***************數碼管緩沖區*********************/
u8 r_dis_buff[3] = {0x00,0x00,0x00};        //
//獨立LLED
#define   set_Led_ANT      (r_dis_buff[2] |= seg_h)                //0x10
#define   set_Led_SLP      (r_dis_buff[2] |= seg_e)                //0x04
#define   set_Led_TIME     (r_dis_buff[2] |= seg_d)   //0x08
#define   set_Led_SPEED    (r_dis_buff[2] |= seg_b)   //0x01
#define   set_Led_Hr       (r_dis_buff[2] |= seg_g)   //0x40
#define   set_Led_SW       (r_dis_buff[2] |= seg_c)   //0x20
//顯示函數
void  LedShow(u8 tmp)
        CLR_WDT;                                //CLR WDT
        p_seg_a = tmp & BIT0;
        p_seg_b = tmp & BIT1;
        p_seg_c = tmp & BIT2;
        p_seg_d = tmp & BIT3;
        p_seg_e = tmp & BIT4;
        p_seg_f = tmp & BIT5;
        p_seg_g = tmp & BIT6;
        p_seg_dp = tmp & BIT7;
//數碼管掃描函數
void LedScan(void)
        static u8  r_dig_bit = 0;
        CLR_WDT;                        //CLR WDT
        //LedShow(0x00);
        p_dig_0 = 1;
        P_dig_1 = 1;
        P_dig_2        = 1;                     //關顯示 消隱
        if(r_dig_bit < 2)
                LedShow(table_seg[r_dis_buff[r_dig_bit]]);                        //數碼管顯示
        else if(r_dig_bit == 2)
                LedShow(r_dis_buff[r_dig_bit]);                //獨立LED顯示
        switch(r_dig_bit)
                case 0:
                                p_dig_0 = 0;
                                break;
                case 1:
                                P_dig_1 = 0;
                                break;
                case 2:
                                P_dig_2 = 0;
                                break;
                default:        break;
        CLR_WDT;                                //喂狗
        r_dig_bit++;
        if(r_dig_bit >= 4)
                r_dig_bit = 0;
收藏收藏2 分享淘帖 頂 踩
