查看: 10393|回復: 2
JZ4054充電ic引腳圖與電路圖及pdf資料下載
鋰電常用的充電ic,經典中的經典
JZ4054引腳圖:
JZ4054應用電路:
Description
JZ4054 is a complete constant-current & constant voltage linear charger for single cell lithium-ion and Lithium-Polymer batteries.  Its SOT-23 package and low external component count make JZ4054 ideally suited for portable applications.
Furthermore, the JZ4054 is specifically designed to work within USB power specification.   At the same time, JZ4054 can also be used in the standalone lithium-ion and Lithium-polymer battery charger.
完整的pdf格式文檔51黑下載地址:
4054 充電.pdf (169.29 KB, 下載次數: 20)
ID:149286 發表于 2017-12-23 08:55 | 只看該作者
BAT管腳應該加一個電容下地比較好,樓主這個不算經典電路
ID:323994 發表于 2018-5-10 08:21 | 只看該作者
提示都沒有,扣了5黑幣。不劃算!
