查看: 3188|回復: 0
lcd1602 4bit 驅動程序代碼
ID:258566 發表于 2017-12-21 19:04 | 顯示全部樓層 |閱讀模式
另存為xx.c文件,不同時鐘頻率下,根據需要修改delay_lcd函數。
  1. #include <AT89x51.h>
  2. #include "lcd4bit.h"
  3. sbit RS = P1^2;
  4. sbit En = P1^3;
  5. sbit D0 = P1^4;
  6. sbit D1 = P1^5;
  7. sbit D2 = P1^6;
  8. sbit D3 = P1^7;
  9. #define LCD_Port P1
  10. void init_lcd (void)
  11. {
  12.   RS = Lo;
  13.   write_nibble_lcd(0x03);        delay_lcd();
  14.   write_nibble_lcd(0x03);        delay_lcd();
  15.   write_nibble_lcd(0x02);        delay_lcd();
  16.   write_lcd(0x28);
  17.   write_lcd(0x06);
  18.   write_lcd(0x0c);
  19.   write_lcd(0x01);
  20. }
  21. void gotoxy_lcd(unsigned char col,unsigned char line)
  22. {
  23.         RS = Lo;
  24.         if (line == 1)
  25.                 write_lcd(0x7f+col);
  26.         if (line == 2)
  27.                 write_lcd(0xbf+col);
  28. }
  29. void putc_lcd(unsigned char byte)
  30. {
  31.    RS = Hi;
  32.    write_lcd(byte);
  33. }
  34. void print_lcd(char String[])
  35. {
  36.         int i = 0;
  37.         do
  38.            {
  39.                 putc_lcd(String[i]);
  40.             i++;
  41.         }
  42.         while(String[i] != '\0');
  43. }
  44. void delay_lcd (void)
  45. {
  46.         int del1,del2;
  47.           for(del1=0;del1<10;del1++)
  48.           {
  49.             for(del2=0;del2<200;del2++);
  50.           }
  51. }
  52. void write_lcd(unsigned char Val)
  53. {
  54.         write_nibble_lcd(Val >> 4);
  55.         write_nibble_lcd(Val);
  56.         delay_lcd();
  57. }
  58. void write_nibble_lcd(unsigned char Val)
  59. {
  60.         En = Hi;
  61.         D0 = D1 = D2 = D3 = 0;
  62.         if(Val & 0x01)
  63.                 D0 = 1;
  64.         if(Val & 0x02)
  65.                 D1 = 1;
  66.         if(Val & 0x04)
  67.                 D2 = 1;
  68.         if(Val & 0x08)
  69.                 D3 = 1;
  70.         En = Lo;
  71. }
另存為lcd4bit.h 文件
  1. #ifndef lcd4bit_h
  2. #define lcd4bit_h 1
  3. #define Hi 1
  4. #define Lo 0
  5. #ifndef TRUE
  6.         #define TRUE 1
  7. #endif
  8. #ifndef FALSE
  9.         #define FALSE 0
  10. #endif
  11. #define RIGHT 0
  12. #define LEFT  1
  13. void init_lcd(void);
  14. void write_high_lcd(unsigned char Val);
  15. void gotoxy_lcd(unsigned char col,unsigned char line);
  16. void putc_lcd(unsigned char byte);
  17. void print_lcd(char String[]);
  18. void delay_lcd(void);
  19. void write_lcd(unsigned char Val);
  20. void write_low_lcd(unsigned char Val);
  21. void write_command_lcd(char cmd);
  22. void scroll_lcd(char enable, char dir);
  23. //void clear_lcd();
  24. void write_nibble_lcd(unsigned char Val);
  25. #endif
