查看: 2042|回復: 0
MT10單色上位機恒流源程序
MT10-單色上位機恒流
  1. #include <STC12C5A60S2.H>
  2. #include <intrins.h>
  3. #include"zimo.h"
  4. #include"yinpin.h"
  5. #include"flash.h"
  6. #include"hanshu.h"
  7. uchar data rxcnt=0;
  8. /*************************************************************************/
  9. void main()
  10. {                     initial595();
  11.                                 initial5952();
  12.                                 timer0init();
  13.                                 out=1;
  14.                                 menu=0;
  15.                                 amenu=1;
  16.                                 bb=1;
  17.                           while(1)
  18.                    {
  19.                                 huxi();
  20.                                 zhu2();
  21.                            }
  22. }
  23.
  24. /******************************************************************************/
  25. /**************************************************************************/
  26.   void print1() interrupt 3
  27. {
  28.   if(out==1)
  29.    {
  30.                                 TR1=0;                //關閉定時器1
  31.                                 TH1=(65536-2500)/256;  //定時  time = F63C ;104.1us
  32.                                 TL1=(65536-2500)%256;
  33.                                 if(num>=(amenu-1))
  34.                                         num=0;
  35.                                 else
  36.                                         num++;
  37.                                 if(b[num]<c[num])
  38.                                 {b[num]++;}
  39.                                 if(b[num]>c[num])
  40.                                 {b[num]--;}
  41.                                 if(b[num]>8)
  42.                                 {b[num]=8;}
  43.
  44.         switch(yp)
  45.         {
  46.                 case 1:        send_data2(~tuku2[b[num]]);
  47.                         if(amenu<=2){}
  48.                                 else delay(50);
  49.                                 break;
  50.                 case 2:        send_data2(~tuku1[b[num]]);
  51.                                 if(amenu<=2){}
  52.                                 else delay(50);
  53.                                 break;
  54.                 case 3:        send_data2(~tuku3[b[num]]);
  55.                                 if(amenu<=2){}
  56.                                 else delay(50);
  57.                                 default:break;
  58.     }
  59.   }
  60. if(out==2||out==3)
  61. {                        uchar i;
  62.                         static uchar layer=0;
  63.                       for (i=0;i<8;i++)
  64.                        {
  65.                         buffer[i]=~display[layer][i];
  66.                        }
  67.                                 xiansi1();
  68.                                     cheng=(0x01<<layer);
  69.                                     DS2 = ~cheng&0x01; //發送最低位
  70.                                         SH_CP2 = 1;
  71.                                         SH_CP2 = 0;                 //移位寄存器移位
  72.                                         ST_CP=1;
  73.                                     ST_CP=0;
  74.                                         ST_CP2=1;
  75.                                     ST_CP2=0;
  76.
  77.                                 if (layer<7)
  78.                                 layer++;
  79.                         else
  80.                         layer=0;
  81.                                     TH1=0xfe;
  82.                                     TL1=0xfe;
  83.                                         delay(2);
  84.                                         key_amenu_scan();
  85.                                         key_menu_scan();
  86.                                         key_out_scan();
  87.                                 if(out==4||out==1)
  88.                                     {IAP_CONTR=0x20;}
  89.
  90. }
  91.                                     TR1=1;//啟動定時器1
  92. }
  93. /***************************************************************************/
  94.   void UART1_Int(void) interrupt 4
  95. {           uchar j,temp=0;
  96.
  97.   if (RI == 1)
  98.   {                 sa=0;
  99.                                 RI = 0;
  100.                                     ES = 0;             //串口1中斷
  101.                                 rxcnt++;                         //前面有一個地址碼0xf2,要去掉,>=2時才能接收數據
  102.                   if(rxcnt>=2&&rxcnt<=9)
  103.                {
  104.                     temp=SBUF;
  105.                          for(j=0;j<8;j++)
  106.                           { if(temp&(0x01<<j))
  107.                                     display[j][rxcnt-2]|=0x80;
  108.                                         else
  109.                                     display[j][rxcnt-2]&=~0x80;
  110.                            }
  111.                 }
  112.                   if(rxcnt>=10&&rxcnt<=17)
  113.                {    temp=SBUF;
  114.                              for(j=0;j<8;j++)
  115.                                   {
  116.                                     if(temp&(0x01<<j))
  117.                                         display[j][rxcnt-10]|=0x40;
  118.                                         else
  119.                                          display[j][rxcnt-10]&=~0x40;
  120.                           }
  121.                }
  122.                   if(rxcnt>=18&&rxcnt<=25)
  123.                {
  124.                                 temp=SBUF;
  125.                                  for(j=0;j<8;j++)
  126.                                   {
  127.                                     if(temp&(0x01<<j))
  128.                                         display[j][rxcnt-18]|=0x20;
  129.                                         else
  130.                                         display[j][rxcnt-18]&=~0x20;
  131.                                   }
  132.                                }
  133.                           if(rxcnt>=26&&rxcnt<=33)
  134.                       {
  135.                                 temp=SBUF;
  136.                                  for(j=0;j<8;j++)
  137.                                   {
  138.                                     if(temp&(0x01<<j))
  139.                                         display[j][rxcnt-26]|=0x10;
  140.                                         else
  141.                                         display[j][rxcnt-26]&=~0x10;
  142.                                    }
  143.                       }
  144.                           if(rxcnt>=34&&rxcnt<=41)
  145.                       {
  146.                                 temp=SBUF;
  147.                                   for(j=0;j<8;j++)
  148.                                   {
  149.                                     if(temp&(0x01<<j))
  150.                                         display[j][rxcnt-34]|=0x08;
  151.                                         else
  152.                                         display[j][rxcnt-34]&=~0x08;
  153.                                    }
  154.                        }
  155.                           if(rxcnt>=42&&rxcnt<=49)
  156.                       {
  157.                                 temp=SBUF;
  158.                                   for(j=0;j<8;j++)
  159.                                   {
  160.                                     if(temp&(0x01<<j))
  161.                                         display[j][rxcnt-42]|=0x04;
  162.                                         else
  163.                                         display[j][rxcnt-42]&=~0x04;
  164.                                    }
  165.                           }
  166.
  167.                           if(rxcnt>=50&&rxcnt<=57)
  168.                       {
  169.                                 temp=SBUF;
  170.                                     for(j=0;j<8;j++)
  171.                                    {
  172.                                     if(temp&(0x01<<j))
  173.                                         display[j][rxcnt-50]|=0x02;
  174.                                         else
  175.                                         display[j][rxcnt-50]&=~0x02;
  176.                                    }
  177.                        }
  178.                           if(rxcnt>=58&&rxcnt<=65)
  179.                       {
  180.                                 temp=SBUF;
  181.                                     for(j=0;j<8;j++)
  182.                                    {
  183.                                    if(temp&(0x01<<j))
  184.                                         display[j][rxcnt-58]|=0x01;
  185.                                    else
  186.                                         display[j][rxcnt-58]&=~0x01;
  187.                                    }
  188. ……………………
  189. …………限于本文篇幅 余下代碼請從51黑下載附件…………
MT10-單色上位機恒流.zip (240.26 KB, 下載次數: 11)
