使用了 溫度傳感器 和DS1302時(shí)鐘芯片
單片機(jī)源程序如下(注釋部分很詳細(xì)):
#include<reg52.h>
#include<intrins.h>
#define LCD1602_DATA P0 //定義P3口為定LCD數(shù)據(jù)口
sbit buzz=P2^7;
sbit LCD1602_RS=P1^2;
sbit LCD1602_RW=P1^1;
sbit LCD1602_E =P1^0;
sbit key_select=P3^2; //定義選擇按鍵的IO口
sbit key_increment=P3^3; //定義自加按鍵的IO口
sbit key_decrement=P3^4; //定義自減按鍵的IO口
sbit key_detemine= P3^5; //定義確定按鍵的IO口
sbit SCLK=P1^5;
sbit DSIO=P1^6;
sbit RST=P1^7;
sbit DQ=P2^0;//定義DS18B20的數(shù)據(jù)通訊IO口為P2.4
unsigned char year; //定義變量year, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的年份數(shù)據(jù)
unsigned char week; //定義變量week, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的星期數(shù)據(jù)
unsigned char month; //定義變量month, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的月份數(shù)據(jù)
unsigned char day; //定義變量day, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的日份數(shù)據(jù)
static unsigned char hour; //定義變量hour, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的小時(shí)數(shù)據(jù)
static unsigned char minute;//定義變量minute, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的分鐘數(shù)據(jù)
static unsigned char second;//定義變量secode, 用來存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的秒鐘數(shù)據(jù)
unsigned char temperature_integer;//定義變量temperature_integer,用來存儲(chǔ)讀取的溫度整數(shù)部分
unsigned char temperature_decimal;//定義變量temperature_decimal,用來存儲(chǔ)讀取溫度的小數(shù)部分
unsigned char set_time_state; //當(dāng)值為1時(shí)進(jìn)入設(shè)計(jì)時(shí)間的循環(huán)中,當(dāng)為0時(shí)退出設(shè)計(jì)時(shí)間狀態(tài)
unsigned char lcd1602_add; //記錄LCD1602數(shù)據(jù)指針地址
static unsigned char alarm_hour=7; //存儲(chǔ)鬧鐘小時(shí)數(shù)據(jù)變量
static unsigned char alarm_minute=30; //存儲(chǔ)鬧鐘分鐘數(shù)據(jù)變量
static unsigned char hour_ten; // 小時(shí)的十進(jìn)制
static unsigned char minute_ten; //分鐘的十進(jìn)制
uchar ditab[16]= {0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9}; //小數(shù)部分表格,用來計(jì)算方法獲取
static unsigned char *Week_dat[]={
"0000",
"Mon ",
"TUes",
"Wed ",
"Thur",
"Fir ",
"Sat ",
"Sun ",
unsigned char Temp_L,Temp_H;
函數(shù)名稱:delay_ms(uint x)
函數(shù)功能:延時(shí)一定時(shí)間
參數(shù):多少毫秒
void delay(uint x)//延時(shí)函數(shù)
uchar i;
while(x--)
for(i=114; i>0; i--);
函數(shù)名稱:Delay7ms()
函數(shù)功能:延時(shí)7毫秒
輸入?yún)?shù):無
返回值: 無
特別說明:晶振頻率工作在12MHZ情況下延時(shí)7毫秒
void Delay7ms() //@12.000MHz
unsigned char i, j;
i = 82;
j = 179;
do
while (--j);
} while (--i);
函數(shù)名稱:Delay10us()
函數(shù)功能:延時(shí)10微秒
輸入?yún)?shù):無
返回值: 無
void Delay10us() //@12.000MHz
unsigned char i;
_nop_();
i = 2;
while (--i);
函數(shù)名稱:Delay50us()
函數(shù)功能:延時(shí)50微秒
輸入?yún)?shù):無
返回值: 無
void Delay50us() //@12.000MHz
unsigned char i;
_nop_();
i = 22;
while (--i);
函數(shù)名稱:Delay500us()
函數(shù)功能:延時(shí)500微秒
輸入?yún)?shù):無
返回值: 無
void Delay500us() //@12.000MHz
unsigned char i;
_nop_();
i = 247;
while (--i);
函數(shù)名稱:Delay500ms()
函數(shù)功能:延時(shí)500毫秒
輸入?yún)?shù):無
返回值: 無
void Delay500ms() //@12.000MHz
unsigned char i, j, k;
_nop_();
i = 4;
j = 205;
k = 187;
do
do
while (--k);
} while (--j);
} while (--i);
void Delay800ms() //@12.000MHz
_nop_();
i = 7;
j = 21;
k = 96;
do
do
while (--k);
} while (--j);
} while (--i);
函數(shù)名稱:LCD1602_write_com(uchar com)
函數(shù)參數(shù):要寫入的指令
函數(shù)功能:向lcd1602寫入一個(gè)指令
函數(shù)返回值:無
void LCD1602_Write_Com(uchar com)//寫指令
LCD1602_E=0;
LCD1602_RS=0;
LCD1602_RW=0;
LCD1602_DATA =com;
LCD1602_E=1;
delay(2);
LCD1602_E=0;
函數(shù)名稱:LCD1602_write_date(uchar dat)
函數(shù)返回值:無
void LCD1602_Write_Date(uchar dat)//寫數(shù)據(jù)
LCD1602_E=0;
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_DATA =dat;
LCD1602_E=1;
delay(2);
LCD1602_E=0;
函數(shù)名稱:LCD1608_Init()
函數(shù)參數(shù):無
函數(shù)功能:初始化LCD1602
函數(shù)返回值:無
void LCD1602_Init()//初始化LCD_1602
delay(15);
LCD1602_Write_Com(0X38);
delay(5);
delay(5);
LCD1602_Write_Com(0X01);
LCD1602_Write_Com(0X06);
LCD1602_Write_Com(0X0c);
函數(shù): void LCD1602_printf(uchar H,uchar L,uchar dat)
函數(shù)參數(shù):H表示行,L表示列,dat表示數(shù)據(jù)
函數(shù)功能:在指定的H行,第L+1個(gè)處開始寫入一個(gè)字符
函數(shù)返回值:無
void LCD1602_Printf(bit H,uchar L,uchar dat)
if(H)
LCD1602_Write_Com(0X80+0X40+L);
LCD1602_Write_Date(dat);
LCD1602_Write_Com(0X80+L);
函數(shù)名稱:LCD1602_ClS()
函數(shù)功能:清楚屏幕
函數(shù)參數(shù):無
函數(shù)返回值:無
void LCD1602_Cls()
LCD1602_Write_Com(0x01);
函數(shù)名稱:void LCD1602_Printf_String(bit H,uchar L,uchar dat)
函數(shù)功能:H表示行,L表示列,dat表示數(shù)據(jù)
函數(shù)參數(shù):無
函數(shù)返回值:無
void LCD1602_Printf_String(bit H,uchar L,uchar* str)
if(H)
while(*str!='\0')
LCD1602_Write_Date(*str++);
while(*str!='\0')
函數(shù)名稱:bit Key_Select_Is_Dowm()
函數(shù)功能:檢測(cè)key_select按鍵是否被按下,按鍵被按下返回1,按鍵沒有被按下返回0
輸入?yún)?shù):無。
返回值:按鍵被按下返回1,按鍵沒有被按下返回0
if(!key_select)
Delay7ms();
if(!key_select)
return 1;
return 0;
函數(shù)名稱:bit Key_Increment_Is_Dowm()
函數(shù)功能:檢測(cè)key_increment按鍵是否被按下,按下返回1,沒有被按下返回0
輸入?yún)?shù):無
返回值: 按鍵被按下返回1,按鍵沒有被按下返回0
if(!key_increment)
Delay7ms();
if(!key_increment)
return 1;
return 0;
函數(shù)名稱:bit Key_Decrement_Is_Dowm()
函數(shù)功能:檢測(cè)key_decrement按鍵是否被按下,按下返回1,沒有被按下返回0
輸入?yún)?shù):無
if(!key_decrement)
Delay7ms();
if(!key_decrement)
return 1;
return 0;
函數(shù)名稱:bit Key_determine_Is_Dowm()
函數(shù)功能:檢測(cè)key_determine按鍵是否被按下,按下返回1,沒有被按下返回0
輸入?yún)?shù):無
bit Key_Determine_Is_Dowm()
if(!key_detemine)
Delay7ms();
if(!key_detemine)
return 1;
return 0;
函數(shù)名稱:void write_ds1302(uchar dat)
函數(shù)功能:向DS1302芯片寫入一個(gè)字節(jié)
輸入?yún)?shù):寫入的數(shù)據(jù)
返回值:無
void Ds1302_Write(uchar dat)//寫入一個(gè)字節(jié)
uchar i;
for(i=0; i<8; i++)
DSIO=dat&0x01;
SCLK=1;
dat>>=1;
SCLK=0;
函數(shù)名稱: read_ds1302())
函數(shù)功能:向DS1302芯片讀取一個(gè)字節(jié)
輸入?yún)?shù):無
返回值: 返回DS_1302讀取的一個(gè)數(shù)據(jù)
uchar Ds1302_Read()//讀出一個(gè)字節(jié)
uchar i,tem=0;
for(i=0; i<8; i++)
tem>>=1;
if(DSIO)
tem|=0x80;
SCLK=1;
SCLK=0;
return tem;
函數(shù)名稱: rest_ds1302()
函數(shù)功能:ds1302復(fù)位
輸入?yún)?shù):無
返回值:
void Ds1302_Rest()//ds1302復(fù)位
RST=0;
DSIO=0;
RST=1;
函數(shù)名稱:write(uchar add,uchar addr)
函數(shù)功能:向DS1302寫入一個(gè)數(shù)據(jù)
輸入?yún)?shù):地址,數(shù)據(jù)
返回值: 無
void Ds1302_Write_Data(uchar add,uchar dat)//寫入一個(gè)數(shù)據(jù)
uchar t;
t=dat/10;
dat=dat%10;
dat=t*16+dat; //轉(zhuǎn)化為BCD碼
Ds1302_Rest();
Ds1302_Write(add);
Ds1302_Write(dat);
RST=0;
DSIO=0;
函數(shù)名稱:write_BCD(uchar add,uchar addr)
函數(shù)功能:向DS1302寫入一個(gè)BCD數(shù)據(jù)
返回值: 無
void DS1302_Write_BCD(uchar add,uchar dat)//寫入一個(gè)BCD數(shù)據(jù)
// uchar t;
// t=dat/10;
// dat=dat%10;
// dat=t*16+dat; //轉(zhuǎn)化為BCD碼
Ds1302_Rest();
Ds1302_Write(add);
Ds1302_Write(dat);
RST=0;
DSIO=0;
函數(shù)名稱:read(uchar add)
函數(shù)功能:讀出一個(gè)時(shí)間
輸入?yún)?shù):地址
返回值: 時(shí)間
uchar Ds1302_Read_Time(uchar add)//讀出一個(gè)時(shí)間
uchar temp;
Ds1302_Rest();
Ds1302_Write(add);
temp=Ds1302_Read();
RST=0;
DSIO=0;
return temp;
函數(shù)名稱:Open_Wp()
函數(shù)功能:打開寫保護(hù)開關(guān),失之不可以對(duì)DS1302進(jìn)行寫操作
輸入?yún)?shù):無
返回值: 無
void Ds1302_Open_Wp()
Ds1302_Write_Data(0x8e,0x80);
函數(shù)名稱:Colse_Wp()
函數(shù)功能:關(guān)閉寫保護(hù)開關(guān),使之可以對(duì)DS1302進(jìn)行寫操作
輸入?yún)?shù):無
返回值: 無
void Ds1302_Close_Wp()
Ds1302_Write_Data(0x8e,0);
函數(shù)名稱:uchar Get_Ds1302_Year_BCD()
函數(shù)功能:獲取DS1302內(nèi)部年份寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無
返回值: 當(dāng)前DS1302芯片內(nèi)部存儲(chǔ)小時(shí),數(shù)值為BCD碼
return Ds1302_Read_Time(0x8d);
函數(shù)名稱:uchar Get_Ds1302_Week_BCD()
函數(shù)功能:獲取DS1302內(nèi)部星期寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無
return Ds1302_Read_Time(0x8B);
函數(shù)名稱:uchar Get_Ds1302_Month_BCD()
函數(shù)功能:獲取DS1302內(nèi)部月份寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無
return Ds1302_Read_Time(0x89);
函數(shù)名稱:uchar Get_Ds1302_Day_BCD()
函數(shù)功能:獲取DS1302內(nèi)部日份占拇嫫魘藎ɑ袢〉鼻靶∈筆藎?
輸入?yún)?shù):無
return Ds1302_Read_Time(0x87);
函數(shù)名稱:uchar Get_Ds1302_Hour_BCD()
函數(shù)功能:獲取DS1302內(nèi)部小時(shí)寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無
return Ds1302_Read_Time(0x85);
函數(shù)名稱:uchar Get_Ds1302_Minute _BCD()
輸入?yún)?shù):無
uchar Get_Ds1302_Minute_BCD()
return Ds1302_Read_Time(0x83);
函數(shù)名稱:uchar Get_Ds1302_Second_BCD()
輸入?yún)?shù):無
return Ds1302_Read_Time(0x81);
函數(shù)名稱:Ds18b20_Init() //
函數(shù)功能:DS18B20初始化 //
輸入?yún)?shù):無 //
返回值:返回為1表示DS18B20發(fā)出了存在信息,為0表示沒有? // //
uchar Ds18b20_Init() //
uchar value; //定義一個(gè)變量value,用來保存中間結(jié)果。 //
DQ=1; //把總線拉為高電平。 //
Delay10us(); //保持10us,目的是為了穩(wěn)定系統(tǒng)端口。 //
DQ=0; //初始化第一步,總線拉為低電平,低電平時(shí)間應(yīng)該保持480us-960us之間。 //
Delay500us(); //這里選擇保持500us。 //
DQ=1; //初始化第二步:總線拉為高電平(釋放端口),用于下一步檢測(cè)DS18B20 //
Delay50us(); //延時(shí)50微妙。 //
value=DQ; //檢測(cè)總線電平,并把值賦給變量value,返回為1表示DS18B20發(fā)出了存在信息, //
//為0表示沒有發(fā)出存在信息 //
Delay500us(); //檢測(cè) 總線電平后延時(shí)500us,為了穩(wěn)定系統(tǒng)總線。
return value; //返回value值 //
函數(shù)名稱: Ds18b20_Write_Date(uchar dat)
函數(shù)功能:向DS18B20中寫入一個(gè)數(shù)據(jù)
輸入?yún)?shù):要寫入數(shù)據(jù)的值
返回值:無
void Ds18b20_Write_Date(uchar dat)
uchar i; //定義局部變量i,用于循環(huán)計(jì)數(shù)
for(i=0; i<8; i++) //循環(huán)8次將寫入一個(gè)8位的數(shù)據(jù)
DQ=1; //把總線拉為高電平
Delay10us(); //保持10us,目的是為穩(wěn)定系統(tǒng)端口。
DQ=0; //總線時(shí)間為低電平,保持時(shí)間大于1us后寫數(shù)據(jù)。
_nop_(); //空操作,延時(shí)1us。
DQ=dat&0x01; //向DS18b20中寫入一位數(shù)據(jù)。
dat>>=1; //數(shù)據(jù)右移一位準(zhǔn)備寫入下一位,DS18B20先寫低位再寫高位。
Delay50us(); //延時(shí)50us
Delay10us(); //延時(shí)10us,為了DS18b20 采樣總線上的數(shù)據(jù)
DQ=1;
// Delay10us(); //延時(shí)10us,為了DS18b20 采樣總線上的數(shù)據(jù)
DQ=1; //釋放總線。
函數(shù)名稱:uchar Ds18b20_Read_Date()
函數(shù)功能:從DS18B20中讀取一個(gè)字節(jié)數(shù)據(jù)
輸入?yún)?shù):無
返回值:讀取到的值
uchar i, value;//定義中間變量
for(i=0; i<8; i++)
DQ=1; //將總線拉為高電平
Delay10us(); //保持10us,目的是為了讓系統(tǒng)端口穩(wěn)定。
DQ=0; //把總線拉為低電平。
_nop_();
_nop_();
value>>=1; //1,延時(shí),2,數(shù)據(jù)右移一位,準(zhǔn)備讀下一位
DQ=1; //把總線拉為高電平準(zhǔn)備讀數(shù)據(jù)
_nop_();
_nop_();
if(DQ)
value|=0x80;
DQ=1; //釋放總線
return value; //返回讀取到的字節(jié)數(shù)據(jù)
函數(shù)名稱:uchar Get_Ds18b20_Temperature(bit Va
函數(shù)功能:讀取溫度程序
輸入?yún)?shù):輸入?yún)?shù)為0返回溫度的小數(shù),輸入?yún)?shù)為1則返回溫度的整數(shù)
返回值:讀取到的值
uchar Get_Ds18b20_Temperature_Integer()//讀取溫度程序,參數(shù)為1,返回整數(shù),參數(shù)為小數(shù)
unsigned char temp_integer;
while(Ds18b20_Init()); //初始化DS18B20。
Ds18b20_Write_Date(0xcc); //跳過ROM命令。
_nop_();
Ds18b20_Write_Date(0x44); //啟動(dòng)溫度轉(zhuǎn)換。
// Delay500ms();
while(!DQ); //等待轉(zhuǎn)化完畢
_nop_();
Ds18b20_Write_Date(0xbe); //啟動(dòng)溫度轉(zhuǎn)換。
Temp_L=Ds18b20_Read_Date(); //讀取到溫度的低字節(jié)。
Temp_H=Ds18b20_Read_Date(); //暫存讀取到的溫度低字節(jié)。
temp_integer=(Temp_H<<4)+(Temp_L>>4);
return temp_integer; //返回溫度的整數(shù)部分
函數(shù)名稱:uchar Get_Ds18b20_Decimal
函數(shù)功能:讀取溫度程序的小數(shù)部分
輸入?yún)?shù):無
返回值:讀取到的溫度的小數(shù)的值
uchar Get_Ds18b20_Temperature_Decimal()//讀取溫度程序,參數(shù)為1,返回整數(shù),參數(shù)為小數(shù)
unsigned char temp_decimal;
if(Temp_H&0x80)
Temp_L=~Temp_L;
temp_decimal=ditab[Temp_L&0x0f];
return temp_decimal;
函數(shù)名稱:void Update_Time()
函數(shù)功能:更新,年,周,月,日,小時(shí),分鐘,秒鐘的變量里的數(shù)據(jù)
輸入?yún)?shù):無
返回值: 無
void Update_Time()
year = Get_Ds1302_Year_BCD(); //更新年份數(shù)據(jù)
week = Get_Ds1302_Week_BCD(); //更新周數(shù)據(jù)
month = Get_Ds1302_Month_BCD(); //更新月份數(shù)據(jù)
day = Get_Ds1302_Day_BCD(); //更新日期數(shù)據(jù)
hour = Get_Ds1302_Hour_BCD(); //更新小時(shí)數(shù)據(jù)
minute= Get_Ds1302_Minute_BCD();//更新月份數(shù)據(jù)
second= Get_Ds1302_Second_BCD(); //更新秒種數(shù)據(jù)
輸入?yún)?shù):無
返回值: 無
//void Update_Temperature()
// // temperature_integer=Get_Ds18b20_Temperature(1);
// //temperature_decimal=Get_Ds18b20_Temperature(0);
輸入?yún)?shù):無
返回值: 無
void Dispaly_Temperature()
temperature_integer=Get_Ds18b20_Temperature_Integer();
temperature_decimal=Get_Ds18b20_Temperature_Decimal();
if(temperature_integer<127)
LCD1602_Printf(1,10,'+');
temperature_integer=~temperature_integer;
LCD1602_Printf(1,10,'-');
LCD1602_Printf(1,11,(temperature_integer/10)+48);
LCD1602_Printf(1,12,(temperature_integer%10)+48);
LCD1602_Write_Date('.');
LCD1602_Printf(1,14,(temperature_decimal)+48);
LCD1602_Write_Date('C');
函數(shù)名稱:Dispaly_Time()
函數(shù)功能:更新顯示年,周,月,日,小時(shí),分鐘,秒鐘
輸入?yún)?shù):無
返回值: 無
void Dispaly_Time()
//LCD1602_Cls();
LCD1602_Printf_String(0,0,"20");
LCD1602_Printf(0,2,(year>>4)+48); //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,3,(year&0x0f)+48); //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Write_Date('/');
LCD1602_Printf(0,5,(month>>4)+48); //month變量的高四位存儲(chǔ)月份的十位,取month的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,6,(month&0x0f)+48); //month變量的低四位存儲(chǔ)月份的個(gè)位,取month的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,8,(day>>4)+48); //day變量的高四位存儲(chǔ)日份的十位,取day的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,9,(day&0x0f)+48); //day變量的低四位存儲(chǔ)日份的個(gè)位,取day的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf_String(0,12,Week_dat[week&0x0f]); // 調(diào)用week_dat數(shù)組內(nèi)對(duì)應(yīng)數(shù)據(jù)
// LCD1602_Printf(0,12,(week>>4)+48); //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
// LCD1602_Printf(0,13,(week&0x0f)+48); //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
// LCD1602_Printf_String(0,14,"th");
LCD1602_Printf(1,1,(hour>>4)+48); //hour變量的高四位存儲(chǔ)小時(shí)的十位,取hour的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,2,(hour&0x0f)+48); //hour變量的低四位存儲(chǔ)小時(shí)的個(gè)位,取hour的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Write_Date(':');
LCD1602_Printf(1,4,(minute>>4)+48); //minute變量的高四位存儲(chǔ)分鐘的十位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,5,(minute&0x0f)+48); //minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,7,(second>>4)+48); //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,8,(second&0x0f)+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
year=(year>>4)*10+(year&0x0f);
month=(month>>4)*10+(month&0x0f);
day=(day>>4)*10+(day&0x0f); //由BCD碼轉(zhuǎn)變?yōu)槭M(jìn)制碼
week=week&0x0f;
hour=(hour>>4)*10+(hour&0x0f);
minute=(minute>>4)*10+(minute&0x0f);
second=(second>>4)*10+(second&0x0f);
if((alarm_hour==hour)&&(alarm_minute==minute)) //鬧鐘檢測(cè)
if(second%2)
buzz=0;
buzz=1;
buzz=1;
while(minute==0&&second==0) //整點(diǎn)報(bào)時(shí)
if(minute==0&&second==0)
buzz=0;
buzz=1;
Update_Time();
函數(shù)名稱: Set_Time()
函數(shù)功能:調(diào)整設(shè)置時(shí)間
輸入?yún)?shù):無
返回值: 無
void Set_Time()
if(Key_Select_Is_Dowm())
buzz=0;
set_time_state=1;
lcd1602_add=0x83;
LCD1602_Write_Com(0x0f);//開顯示光標(biāo),并且光標(biāo)閃爍
while(Key_Select_Is_Dowm());
buzz=1;
while(set_time_state)
LCD1602_Write_Com(lcd1602_add);
buzz=0;
switch(lcd1602_add)
case 0x83 :
lcd1602_add=0x86;
break;
case 0x86 :
lcd1602_add=0x89;
break;
case 0x89 :
lcd1602_add=0x8d;
break;
case 0x8d :
lcd1602_add=0xc2;
break;
case 0xc2 :
lcd1602_add=0xc5;
break;
case 0xc5 :
lcd1602_add=0xc8;
break;
case 0xc8 :
lcd1602_add=0x83;
break;
default :
break;
buzz=1;
if(Key_Increment_Is_Dowm())
buzz=0;
switch(lcd1602_add)
case 0x83:
year++;
if(year>99)
year=0;
LCD1602_Printf(0,2,(year/10)+48); //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,3,(year%10)+48); //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0x86:
month++;
if(month>12)
month=1;
LCD1602_Printf(0,5,(month/10)+48); //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,6,(month%10)+48); //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0x89:
day++;
switch(month)
case 1:
case 3:
case 5:
case 7:
case 8:
case 10:
case 12:
if(day>31)
day=1;
break;
case 4:
case 6:
case 9:
case 11:
if(day>30)
day=1;
break;
case 2:
if(year%4==0)
if(day>29)
day=1;;
break;
if(day>28)
day=1;
break;
default :
break;
LCD1602_Printf(0,8,(day/10)+48); //month變量的高四位存儲(chǔ)月份的十位,取month的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(0,9,(day%10)+48); //month變量的低四位存儲(chǔ)月份的個(gè)位,取month的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0x8d:
week++;
if(week>7)
week=1;
// LCD1602_Printf(0,12,(week/10)+48); //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
// LCD1602_Printf(0,13,(week%10)+48); //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0xc2:
hour++;
if(hour>23)
hour=0;
LCD1602_Printf(1,1,(hour/10)+48); //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,2,(hour%10)+48); //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0xc5:
minute++;
if(minute>59)
minute=0;
LCD1602_Printf(1,4,(minute/10)+48); //minute變量的高四位存儲(chǔ)分鐘的十位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,5,(minute%10)+48); //minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
case 0xc8:
second++;
if(second>59)
second=0;
LCD1602_Printf(1,7,(second/10)+48); //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,8,(second%10)+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
break;
default :
break;
while(Key_Increment_Is_Dowm());
buzz=1;
//自減按鍵
if(Key_Decrement_Is_Dowm())
buzz=0;
switch(lcd1602_add)
case 0x83:
if(year>0)
year--;
year=99;
break;
case 0x86:
if(month>1)
month--;
month=12;
break;
case 0x89:
switch(month)
case 1:
case 3:
case 5:
case 7:
case 8:
case 10:
case 12:
if(day>1)
day--;
day=31;
break;
case 4:
case 6:
case 9:
case 11:
if(day>1)
day--;
day=30;
break;
break;
case 2:
if(year%4==0)
if(day>1)
day--;
day=29;
break;
if(day>1)
day--;
day=28;
break;
default :
break;
break;
case 0x8d:
if(week>1)
week--;
week=7;
break;
case 0xc2:
if(hour>0)
hour--;
hour=23;
break;
case 0xc5:
if(minute>0)
minute--;
minute=59;
break;
case 0xc8:
if(second>0)
second--;
second=59;
break;
default :
break;
while(Key_Decrement_Is_Dowm());
buzz=1;
if(Key_Determine_Is_Dowm())
buzz=0;
set_time_state=0; //設(shè)置完成,退出循環(huán)
LCD1602_Write_Com(0x0c);//關(guān)閉光標(biāo)
Ds1302_Close_Wp();//關(guān)閉DS1302寫保護(hù),使之可以對(duì)其進(jìn)行寫操作
Ds1302_Write_Data(0x8c,year);
Ds1302_Write_Data(0x88,month);
Ds1302_Write_Data(0x8a,week);
Ds1302_Write_Data(0x86,day);
Ds1302_Write_Data(0x84,hour);
Ds1302_Write_Data(0x82,minute);
Ds1302_Write_Data(0x80,second);
Ds1302_Open_Wp();//打開ds1302寫保護(hù),使之不可以對(duì)其進(jìn)行寫操作
while(Key_Determine_Is_Dowm());
buzz=1;
break;
函數(shù)名稱: set_alarm()
函數(shù)功能:設(shè)計(jì)鬧鐘時(shí)間
輸入?yún)?shù):無
返回值: 無
void set_alarm()
LCD1602_Cls(); //清除屏幕
LCD1602_Printf_String(0,1,"alarm clock ");
LCD1602_Printf(1,1,(alarm_hour/10)+48); //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,2,(alarm_hour%10)+48); //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,3,':');
LCD1602_Printf(1,4,(alarm_minute/10)+48); //alarm_minute變量的高四位存儲(chǔ)分鐘的十位,取alarm_minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,5,(alarm_minute%10)+48); //alarm_minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取alarm_minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,6,':');
LCD1602_Printf(1,7,0+48); //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
LCD1602_Printf(1,8,0+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
lcd1602_add=0xc2; //光標(biāo)初始化地址
set_time_state=1; //菜單標(biāo)志位置1
LCD1602_Write_Com(lcd1602_add); //光標(biāo)顯示地址
buzz=0; //蜂鳴器打開
switch(lcd1602_add)
case 0xc2 :
lcd1602_add=0xc5;
break;
case 0xc5 :
lcd1602_add=0xc2;
break;
default :
break;
buzz=1;
buzz=0;
switch(lcd1602_add)
case 0xc2:
alarm_hour++;
if(alarm_hour>23)
alarm_hour=0;
break;
case 0xc5:
alarm_minute++;
if(alarm_minute>59)
alarm_minute=0;
break;
default :
break;
buzz=1;
//自減按鍵
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
全部資料51hei下載地址:
LCD時(shí)鐘.zip
(186.69 KB, 下載次數(shù): 156)
2017-12-19 22:04 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
