查看: 3526|回復: 0
求教大神,iTOP-4412刷Ubuntu系統后WiFi模塊啟動不了
ID:234049 發表于 2017-12-18 10:20 | 顯示全部樓層 |閱讀模式
如題,wifi模塊是mt6620,集成在板子上面的。
安裝教程修改itop-set文件之后,再修改wpa_supplicant.conf文件。重啟開發板。
但是,wifi模塊附近的led并沒有亮,在Ubuntu系統里面無線網絡也是灰色的。
查看啟動時的系統串口日志發現:
  1. [    6.943863] VFS: Mounted root (ext4 filesystem) on device 179:2.
  2. [    6.949862] Freeing init memory: 220K
  3. [    6.954851] Failed to execute /linuxrc.  Attempting defaults...
  4. mountall: Event failed
  5. [    8.525460] CPU1: shutdown
  6. [   14.133707] CPU2: shutdown
  7. [   19.261819] init: Failed to create pty - disabling logging for job
  8. [   19.285670] init: Failed to create pty - disabling logging for job
  9. [   19.293451] mtk_stp_GPS_chrdev driver(major 191) installed.
  10. [   19.302123] init: Failed to create pty - disabling logging for job
  11. * Starting Userspace bootsplash[ OK ]
  12. [   19.415120] init: Failed to create pty - disabling logging for job
  13. [   19.491937] init: Failed to create pty - disabling logging for job
  14. [   19.506428] init: Failed to create pty - disabling logging for job
  15. [   21.280545] [WMT-C][E]wmt_core_stp_init(717):no hif info!
  16. [   21.284471] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
  17. [   21.291479] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
  18. [   21.298271] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
  19. [   21.304530] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
  20. [   21.312304] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  21. [   21.318314] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
  22. [   21.326024] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  23. [   21.391308] init: Failed to create pty - disabling logging for job
  24. [   21.400263] init: Failed to create pty - disabling logging for job
  25. [   23.330172] [WMT-CTRL][E]wmt_ctrl_ul_cmd(540):wait signal timeout
  26. [   23.335010] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
  27. [   23.344260] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  28. [   23.435632] [WMT-C][E]wmt_core_stp_init(717):no hif info!
  29. [   23.435667] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
  30. [   23.435707] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
  31. [   23.435743] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
  32. [   23.435866] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
  33. [   23.435904] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  34. [   23.435985] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
  35. [   23.436023] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  36. [   23.436156] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
  37. [   23.436194] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  38. [   23.585640] [WMT-C][E]wmt_core_stp_init(717):no hif info!
  39. [   23.585675] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
  40. [   23.585713] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
  41. [   23.585749] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
  42. [   23.585867] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
  43. [   23.585906] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  44. [   23.585986] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
  45. [   23.586024] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  46. [   23.586153] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
  47. [   23.586191] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
  48. [   23.652098] [WMT-C][E]opfunc_func_on(1170):func(3) pwr_on fail(-2)
  49. [   23.660258] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1171, (0)
  50.
  51. [  140.112600] init: Failed to create pty - disabling logging for job
  52. [  140.127310] init: Failed to create pty - disabling logging for job
  53. [  140.143866] init: Failed to create pty - disabling logging for job
  54. [  140.156505] init: Failed to create pty - disabling logging for job
  55. [  140.168729] init: Failed to create pty - disabling logging for job
  56. speech-dispatcher disabled; edit /etc/default/speech-dispatche[  140.188583] inb
  57. r
  58. [  140.206966] init: Failed to create pty - disabling logging for job
  59. [  140.232260] init: Failed to create pty - disabling logging for job
  60.
  61. saned disabled; edit /etc/default/saned
  62. [  140.269808] init: Failed to create pty - disabling logging for job
  63. [  140.284353] init: Failed to create pty - disabling logging for job
  64. [  140.309545] init: Failed to create pty - disabling logging for job
  65. [  140.327651] init: Failed to create pty - disabling logging for job
  66. [  140.345977] init: Failed to create pty - disabling logging for job
  67. Last login: Thu Nov 23 02:21:22 UTC 2017 on tty1
  68. [  140.398203] init: Failed to create pty - disabling logging for job
  69. [  140.472072] init: Failed to create pty - disabling logging for job
  70. [  140.649203] init: Failed to create pty - disabling logging for job
  71. [  140.693059] init: Failed to create pty - disabling logging for job
  72. Welcome to Linaro 12.04 (GNU/Linux 3.0.15 armv7l)
  73.
  74.
  75. New release '14.04.5 LTS' available.
  76. Run 'do-release-upgrade' to upgrade to it.
應該怎么辦?
