查看: 2143|回復: 0
DIY碼表制作源代碼 自創
ID:262981 發表于 2017-12-18 09:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
typedef unsigned char u8;
typedef unsigned int  u16;
/********端口定義*********/
#define DATA P0
#define LED P1
#define DATA1 P2
//sbit seg_sel = P1^4;
//sbit bit_sel = P1^5;
sbit seg_sel=P2^5;
sbit bit_sel0=P2^0;
sbit bit_sel1=P2^1;
sbit bit_sel2=P2^2;
sbit bit_sel3=P2^3;
sbit bit_sel4=P2^4;
sbit start = P3^2;
sbit store = P3^3;
sbit diskey = P3^4;
sbit reset = P3^5;
sbit led = P1^0;
/********變量定義*********/
u16 tem_ms;
u8        n_ten_ms,n_sec,n_min;
u8        run_flag;//當run_flag為1,代表開始計數
u8  temp_buf[5][3];
u8  arr_pt;
u8 num;
u8 code seg_tab[]={
                          0xc0,0xf9,0xa4,0xb0,
                          0x99,0x92,0x82,0xf8,
                          0x80,0x90,0x88,0x83,
                          0xc6,0xa1,0x86,0x8e          };
u8 code seg_tab1[]={
                          0x40,0x79,0x24,0x30,
                          0x19,0x12,0x02,0x78,
                          0x00,0x10,0x08,0x03,
                          0x46,0x81,0x06,0x0e
                                         };//帶小數點
u8 code led_minute[]={
                          0xff,0xfe,0xfc,0xf8,0xf0,
                          0xe0,0xc0,0x80,0x00
                         };//用所點亮LED燈的個數來表示計時的分鐘數
u8 code bit_tab[]={
                          0x7,0xB,0xD,0xE
void delay(unsigned int y)
        unsigned int x,z;
        for(x=y; x>0; x--)
                for(z=110; z>0; z--);
void led_fun(void)
        LED = led_minute[n_min];
void display_led(u8 which_bit, u8 which_number)
{        if(which_bit==2)
        DATA1 = bit_tab[which_bit];
        seg_sel = 1;
        DATA = seg_tab1[which_number];
        seg_sel = 0;
        else if(which_bit==1)
        seg_sel = 1;
        DATA = seg_tab[which_number];
        seg_sel = 0;
//                  1             29
void display(u8 which_bit, u8 which_number)
        u8 x,y;
        x = which_number/10;//分離十位
        y = which_number%10;//分離個位
        if (which_bit == 1)
                display_led(1, x);
                delay(2);
                display_led(0, y);
                delay(2);
        if (which_bit == 2)
                display_led(3, x);
                delay(2);
                display_led(2, y);
                delay(2);
        //if (which_bit == 3)
        //        led_fun(void);
//                delay(2);
        //        led_fun(void);
        //        delay(2);
void reflash (void)
        display(1, n_ten_ms);
        display(2, n_sec);
        display(3, n_min);
void main (void)
        TMOD = 0x01;//設置定時/計數器T0
        TH0 = (65535-10000) / 256;
        TL0 = (65535-10000) % 256;
        EA = 1;//開放總中斷
        ET0 = 1;//開放定時器0的溢出中斷
        //TR0 = 1;
        while (1)
                if (start == 0)
                        delay(5);
                        if (start == 0)
                                run_flag = ~run_flag;
                        } while(!start);
                if (reset == 0)
                        delay(5);
                        if (reset == 0)
                                n_ten_ms = 0;
                                n_sec = 0;
                                n_min = 0;
                        } while(!reset);
                if (store == 0)
                        delay(5);
                        if (store == 0)
                                if ((arr_pt >=0) && (arr_pt< 5))
                                        temp_buf[arr_pt][0] = n_ten_ms;
                                        temp_buf[arr_pt][1] = n_sec;
                                        temp_buf[arr_pt][2] = n_min;
                                        arr_pt++;
                        } while(!store);
                if (run_flag)
                        TR0 = 1; //開始計數
                else if (!run_flag)
                        TR0 = 0;
                reflash();
void t0_server(void) interrupt 1
        n_ten_ms++;
        if (n_ten_ms >= 100)
                n_ten_ms = 0;
                n_sec++;
                if (n_sec >= 60)
                        n_sec = 0;
                        n_min++;
                        num++;
                        if (n_min >= 60)
                                n_min = 0;
