#include<reg51.h>
#include<string.h>
#include<intrins.h>
#define LCDIO P0
#define delay4us() _nop_();_nop_();_nop_();_nop_();
uchar buffer[6]={0};
sbit sda=P3^3;
sbit scl=P3^2;
sbit BEEP=P3^7;
bit flag=0,aa; //用戶蹲淵義定時溢出標志位
uchar DSY_BUFFER[16]=" ";
uchar DSY_BUFFER1[16]=" ";
uchar Userpassword[6]={0};
sbit rs=P2^0;
sbit rd=P2^1;
sbit lcden=P2^2;
sbit led=P2^7;
uchar code table2[]="123456";
uchar code table[]="Your Password...";
void delayms(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void delay() //短延時,兩個機器周期,做總線的延時用
void beep()
uchar i;
for(i=0;i<100;i++)
BEEP=~ BEEP;
BEEP=0;
void write_com(uchar com)
rs=0;
rd=0;
lcden=0;
P0=com;
delayms(3);
lcden=1;
delayms(3);
lcden=0;
void write_date(uchar date)
rs=1;
rd=0;
lcden=0;
P0=date;
delayms(3);
lcden=1;
delayms(3);
lcden=0;
void Display_String(uchar *p,uchar com)
{ uchar i;
write_com(com);
for(i=0;i<16;i++)
write_date(p[i]);
void init_lcd()
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
Display_String(table,0x80);
Display_String("Lock OK! ",0xc0);
void start()
sda=1;
scl=1;
delay4us();
sda=0;
delay4us();
scl=0;
void stop()
sda=0;
scl=1;
delay4us();
sda=1;
delay4us();
scl=0;
void init() //初始化
sda=1;
delay();
scl=1;
delay();
void ack()
sda=0;
scl=1;
delay4us();
scl=0;
sda=1;
void noack()
sda=1;
scl=1;
delay4us();
scl=0;
sda=0;
uchar recbyte()
uchar i,rd;
rd=0x00;
sda=1;
for(i=0;i<8;i++)
scl=1;
rd<<=1;
rd|=sda;
delay4us();
scl=0;
delay4us();
scl=0;
delay4us();
return rd;
uchar sendbyte(uchar wd)
uchar i;
bit ack0;
for(i=0;i<8;i++)
sda=(bit)(wd&0x80);
_nop_();
_nop_();
scl=1;
delay4us();
scl=0;
wd<<=1;
delay4us();
sda=1;
scl=1;
delay4us();
ack0=!sda;
scl=0;
delay4us();
return ack0;
uchar Recstring(uchar slave,uchar subaddr,uchar *buffer,uchar n)
uchar i;
start();
if(!sendbyte(slave)) return 0;
if(!sendbyte(subaddr)) return 0;
start();
if(!sendbyte(slave+1)) return 0;
for(i=0;i<n-1;i++)
buffer[i]=recbyte();
ack();
buffer[n-1]=recbyte();
noack();
stop();
return 1;
uchar Sendstring(uchar slave,uchar subaddr,uchar *buffer,uchar n)
uchar i;
start();
for(i=0;i<n;i++)
if(!sendbyte(buffer[i])) return 0;
stop();
return 1;
void clear_password( )
{ uchar i;
for(i=0;i<6;i++)
Userpassword[i]=' ';
for(i=0;i<16;i++)
DSY_BUFFER[i]=' ';
uchar Keys_Scan()
uchar temp,keynum;
P1=0x0F;
delayms(5);
temp=P1^0x0F;
switch(temp)
case 1:keynum=0;break;
case 2:keynum=1;break;
case 4:keynum=2;break;
case 8:keynum=3;break;
break;
P1=0xF0;
delayms(5);
temp=P1>>4^0x0F;
switch(temp)
case 1:keynum+=0;break;
case 2:keynum+=4;break;
case 4:keynum+=8;break;
case 8:keynum+=12;break;
break;
delayms(600);
return keynum;
{ uchar temp,i=0,j=0,k=0,n;
uchar IS_valid_user;
init();
init_lcd();
delayms(5);
aa=Sendstring(0xa0,1,table2,6);
delayms(5);
aa=Recstring(0xa0,1,buffer,6);
delayms(10);
P1=0x0f;
if(P1!=0x0f)
temp=Keys_Scan();
switch(temp)
case 0: case 1: case 2: case 3: case 4:
case 5: case 6: case 7: case 8: case 9:
if (i<=5) //密碼限制在6位以內(nèi)
Userpassword[i]=temp;
DSY_BUFFER[i]='*';
Display_String(DSY_BUFFER,0xc0);
i++;
break;
case 10: //按A鍵開鎖
for(k=0;k<6;k++)
if(buffer[k]==(Userpassword[k]+48))
flag=1;
flag=0;
if (flag==1)
{ flag=0;
i=0;
led=0; //點亮LED
clear_password();
Display_String("OPEN OK! ",0xc0);
IS_valid_user = 1;
j=0;
j++;
led=1; //關(guān)閉LED
clear_password();
Display_String("ERROR!Have try ",0xc0);
write_com(0xcf);
write_date(0x30+j);
IS_valid_user=0;
i=0;
break;
case 11: //按B鍵上鎖
led=1;
clear_password();
i=0;
IS_valid_user=0;
break;
case 12: //按C鍵設(shè)置新密碼
//如果是合法用戶則提示輸入新密碼
if ( !IS_valid_user)
i=0;
Display_String("No rights ! ",0xc0);
delayms(1000);
Display_String("Your Password...",0x80);
i=0;
Display_String("New Password: ",0x80);
Display_String(" ",0xc0);
break;
case 13: //按D鍵保存新密碼
{ i=0;
delayms(1000);
{i = 0;
init();
delayms(5);
for(k=0;k<6;k++)
Userpassword[k]=Userpassword[k]+48;
aa=Sendstring(0xa0,1,Userpassword,6);
delayms(5);
delayms(5);
clear_password();
Display_String(table,0x00);
Display_String("Password Saved! ",0xc0);
delayms(1000);
Display_String("Do lock agian ? ",0xc0);
break;
case 14: //按E鍵消除所有輸入
i=0;
clear_password();
break;
case 15: //清除一位
if(i!=0)i--;
for(n=0;n<i;n++)
DSY_BUFFER1[n]='*';
Display_String(DSY_BUFFER1,0xc0);
P1=0x0f;
if(j==3)
{ Display_String("THIEF!!!THIEF!!!",0xc0);
j=0;
beep();
