查看: 1741|回復: 0
sunplus屏文件
ID:259469 發表于 2017-12-9 16:11 | 顯示全部樓層 |閱讀模式
此是SUNPLUS屏文件
#include "user_init.h"
#include "config.h"
#include "global.h"
#include "vfdfunc.h"
//#include "vfd_7seg.h"
#include "stdlib.h"
#include "user_if.h"
#include "audif.h"
#include "kernel.h"
#include "auctrl.h"
extern UINT16 Is_MP3_STATE(void);
//#define CDROM_AUTO
//extern UINT16        coding_mode_now;
UINT8  spin_speed;
UINT8  color_timer=0;
#define OFFSET        20
#define MAX_POS        7
#define VFD_DISPLAY_SIZE 14
#define VFD_DISPLAY_MODE  3
#define DISC_SIZE 1
const UINT8 vfd_disc[DISC_SIZE] = {255};
#define TOTAL_SEG 4
BYTE vfd_adddress[7]=
     3,2,1,0,7,8,9,
BYTE vfd_grid_add[TOTAL_SEG]={0,22,32,48};
const UINT16 vfd_char[26]=
        VFD_7SEG_A,
        VFD_7SEG_B,
        VFD_7SEG_C,
        VFD_7SEG_D,
        VFD_7SEG_E,
        VFD_7SEG_F,
        VFD_7SEG_G,
        VFD_7SEG_H,
        VFD_7SEG_I,
        VFD_7SEG_J,
        VFD_7SEG_K,
        VFD_7SEG_L,
        VFD_7SEG_M,
        VFD_7SEG_N,
        VFD_7SEG_O,
        VFD_7SEG_P,
        VFD_7SEG_P,//q
        VFD_7SEG_R,
        VFD_7SEG_S,
        VFD_7SEG_T,
        VFD_7SEG_U,
        VFD_7SEG_U,//v
        VFD_7SEG_W,
        VFD_7SEG_X,
        VFD_7SEG_Y,
        VFD_7SEG_Z //z
const  UINT16  vfd_digit[] =
        VFD_7SEG_0,
        VFD_7SEG_1,
        VFD_7SEG_2,
        VFD_7SEG_3,
        VFD_7SEG_4,
        VFD_7SEG_5,
        VFD_7SEG_6,
        VFD_7SEG_7,
        VFD_7SEG_8,
        VFD_7SEG_9
/*  cpy_src_len: bit 8 is 1 means that bit 8 means that only show partial string between 0 and cpy_src_len */
/*         bit 8 is 0: normal show string, that is copy total string                        */
/*         bit0~bit7 mean that copied source length                                        */
/*  start_p: start position of VFD for show string(position:0~9)                        */
void  vfd_set_str(UINT8 id, char *s)
        BYTE i,j;
        UINT16 c=0;
        BYTE    var_data;
        if(id) {//english id
                //s=(char *)_OsdMessegeFont1[id][0];
                s=(char *)&(_OsdMessegeFont1[0][id][0]);
        i=strlen(s);
        //linebuf[20]=0;
        for(j=TOTAL_SEG;j>0;j--)
                if(i>0)
                        i--;
                        if( (s[i]>='a')&&(s[i]<='z') )
                                c=vfd_char[s[i]-0x20-'A'];
                        else if( (s[i]>='A')&&(s[i]<='Z') )
                                c=vfd_char[s[i]-'A'];
                        else if( (s[i]>='0')&&(s[i]<='9') )
                                c=vfd_digit[s[i]-'0'];
                                if(s[i]==0x20)
                                        c=0;
                        //linebuf[2*j+OFFSET]=c>>8;
                        //linebuf[2*j-1+OFFSET]=c&0x00ff;
                        linebuf[j+OFFSET]=c&0xff;
                }else
                        //linebuf[2*j+OFFSET]=0x00;
                        //linebuf[2*j-1+OFFSET]=0x00;
                        linebuf[j+OFFSET]=0x00;
        }/*for loop*/
         for(i=TOTAL_SEG;i>0; i--){
          var_data=i;//vfd_7seg_p[i];
          for(j=0;j<7;j++){
            if((linebuf[var_data+OFFSET]>>j)&0x01)
              vfd_set_dot(vfd_adddress[j]+vfd_grid_add[i-1]);        //light coresponding dot
              vfd_reset_dot(vfd_adddress[j]+vfd_grid_add[i-1]);        //clear former data
void vfd_set_cd_type(void)
                #ifdef CDROM_AUTO
         AUTOS++;
         if(AUTOS==50) AUTOS=11;
         #endif
        switch(cd_type_loaded)
        case CDDVD:
                vfd_set_dot(VFD_DOT_DVD);
                if(get_angle_Ns()>1)
                        vfd_set_dot(VFD_DOT_ANGLE);
                        vfd_reset_dot(VFD_DOT_ANGLE);
                break;
        case CDROM:
                if( (Is_MP3_STATE())&&(Mp3ReadFinish)&&(IS_AUDIF_CODING_MODE_MP3))//nono 2-5-10 13:50
                        vfd_set_dot(VFD_DOT_MP3);
                        vfd_reset_dot(VFD_DOT_MP4);
                }else  if( GetCurrentFileType() == CDROM_MP4 )
                        vfd_reset_dot(VFD_DOT_MP3);
                        vfd_set_dot(VFD_DOT_MP4);
                }else{
                break;
        case CDDA:
                vfd_set_dot(VFD_DOT_CD);
                break;
        case CDUNKNOWN:
                break;
        case CDSVCD:
                vfd_set_dot(VFD_DOT_V);
                break;
        default://vcd
                                       #ifdef CDROM_AUTO
                       if (GetCurrentFileType() == CDROM_JPEG)
                                if((AUTOS==8)&&(disp_trk_now<=1)) ircmd_play();
                                        if((AUTOS==3)&&(disp_trk_now<=1)) ircmd_play();
                        #endif
                break;
void vfd_set_showtime(void)
        int track_num;
        BYTE show_mm_tmp;
        if(cd_type_loaded==CDDVD)
                if(play_state==VCD_STATE_STOP)
                        track_num=get_tt_info(DISP_TT_Ns);//DISP_CH);
                        track_num=get_tt_info(DISP_CH);//nono 1-12-12 21:15
                        track_num=disp_trk_now;
                show_mm_tmp=(show_time_hh*60+show_time_mm)%100;
                psprintf(linebuf,"%1d%02d%02d",track_num,show_mm_tmp,show_time_ss);
                vfd_set_str(0,linebuf);
                vfd_set_dot(VFD_DOT_MINSEC);
                vfd_set_dot(VFD_DOT_MIN);
                vfd_set_dot(VFD_DOT_MIN2);
void vfd_set_audio(void)
        vfd_reset_dot(VFD_DOT_DTS);
        vfd_reset_dot(VFD_DOT_DOBLY);
#ifdef DUMMY_DTS
                if(dummy_dts==1)
#else
                if( ( coding_mode_now&(AUDIF_CODING_MODE_DTS|AUDIF_CODING_MODE_DTSCD) )||(cd_subtype==CD_DTS) )//nono 2-7-25 16:13
#endif
#ifndef VFD_NO_DTS_LIGHT
                vfd_set_dot(VFD_DOT_DTS);
#endif
        else if(coding_mode_now==AUDIF_CODING_MODE_AC3)
                vfd_set_dot(VFD_DOT_DOBLY);
#if 0
#ifdef VFD_DOT_MIC1
        switch(audio_channel)
        case CH_LR:
        case CH_RR:
        case CH_LL:
                //         vfd_reset_dot(VFD_DOT_MIC1);
        //         vfd_reset_dot(VFD_DOT_MIC2);
                break;
        case CH_AUTO_L:
        case CH_AUTO_R:
                vfd_set_dot(VFD_DOT_MIC1);
        //        vfd_set_dot(VFD_DOT_MIC2);
                break;
#endif
#endif
#if 1          //liliuhai add
        case CH_LR:
                        vfd_set_dot(VFD_DOT_1L);
                        vfd_set_dot(VFD_DOT_2R);
                break;
        case CH_RR:
                        vfd_reset_dot(VFD_DOT_1L);
                break;
        case CH_LL:
                        vfd_reset_dot(VFD_DOT_2R);
                break;
#endif
#if 0
#ifdef VFD_DOT_1L
        switch(audio_effect)
        case SE_STEREO:
                break;
        case SE_HALL:
        case SE_LIVE:
        case SE_THEATER:
        case SE_ROOM:
                break;
#endif
#endif
void vfd_set_playback(void)
        if(play_state==VCD_STATE_PAUSE)
                //erase_vfd_mem();
                vfd_set_dot(100);
                vfd_set_dot(VFD_DOT_PAUSE);
                vfd_reset_dot(VFD_DOT_PLAY);
                //vfd_set_str(STR_OS_PAUSE,"");
        }else
                if((play_state!=VCD_STATE_STOP)&&(play_state!=VCD_STATE_MP3_FILELIST))
                        vfd_set_dot(VFD_DOT_PLAY);
                vfd_reset_dot(VFD_DOT_PAUSE);
        if(IsPBCOn())
                vfd_set_dot(VFD_DOT_PBC);
        vfd_reset_dot(VFD_DOT_PBC);
        vfd_set_cd_type();
        vfd_set_audio();
        //printf("V=%x\n",vfd_mem[3]);
        vfd_set_showtime();
UINT16        vfd_set_no_disc_state(UINT16 index)
        char light_str[]="Errd";
    erase_vfd_mem();
    if (bDiscType == CD_OKO)
                vfd_set_str(0,light_str);
    }else
        vfd_set_str(0,"NODI");
        return index;
UINT16        vfd_set_close_state(UINT16 index)
        //char light_str[]="CLOSE";
    erase_vfd_mem();
    if(is_test_unit()==TRUE||system_state==SYSTEM_READ_TITLE||system_state==SYSTEM_NODISC)
        //vfd_set_str(STR_OS_READ,"");
        vfd_set_str(0,"LOAD");
        //vfd_set_str(STR_OS_CLOSE,"");
          vfd_set_str(0,"CLOS");
    return index;
UINT16        vfd_set_toc_state(UINT16 index)
        //char light_str[]="READ";
    erase_vfd_mem();
    return index;
UINT16        vfd_set_open_state(UINT16 index)
        //char light_str[]="OPEN";
    erase_vfd_mem();
    //vfd_set_str(STR_OS_OPEN,"");
        vfd_set_str(0,"OPEN");
    return index;
UINT16        vfd_set_game_state(UINT16 index)
          return index;
UINT16        vfd_set_pause_state(UINT16 index)
        return index;
UINT16        vfd_set_mp3_state(UINT16 index)
        //if(play_state!=VCD_STATE_STOP)
        return index;
UINT16        vfd_set_stop_state(UINT16 index)
    int i;
    return index;
UINT16        vfd_set_normal_state(UINT16 index)
    index=vfd_set_disc_run(index);
    return index;
Desktop.7z
3.23 KB, 下載次數: 2, 下載積分: 黑幣 -5
