查看: 5207|回復: 4
基于STM32F103C8T6多路超聲波及ESP8266程序
ID:259212 發表于 2017-12-8 20:26 | 顯示全部樓層 |閱讀模式
主要用于停車場動態車位的檢測
支持三路超聲波一路ESP8266
ESP8266作為客戶端使用
  1. #include "stm32f10x.h"
  2. #include "stdio.h"
  3. #include "timer4_cap.h"
  4. #include "UltrasonicWave.h"
  5. #include "delay.h"
  6. #include "bsp_esp8266.h"
  7. #define CarRoom0 0
  8. #define CarRoom1 1
  9. #define CarRoom2 2
  10. void get_Diatance(u8 CarRoomx);
  11. void Car_Check(void);
  12. char j;
  13. u32 s[3];
  14. int main(void)
  15. {
  16.         u8 flag_t;
  17.         delay_init();
  18.                 /* USART1 配置模式為 115200 8-N-1,中斷接收 */
  19.         ESP8266_Init();
  20.
  21.         NVIC_Configuration();
  22.
  23.         TIM4_Cap_Init(0xffff,72-1); //以1Mhz的頻率計數
  24.   UltrasonicWave_Configuration();
  25.         GPIO_ResetBits(GPIOC,GPIO_Pin_13);
  26.         //printf("老子一切都OK是你下面的程序出問題了\r\n");
  27.         delay_ms(1000);
  28.         GPIO_SetBits(GPIOC,GPIO_Pin_13);
  29.         while(!ESP8266_JoinAP("GXM110","123456789"));
  30.         while(!ESP8266_Link_Server(enumTCP,"120.77.87.78","9876",Single_ID_0));//連接服務器
  31.         while(1)
  32.          {
  33.                 UltrasonicWave_StartMeasure();
  34.                 UltrasonicWave_StartMeasure2();
  35.                 UltrasonicWave_StartMeasure3();
  36.                         s[0] = tempup3;
  37.                         s[1] = tempup2;
  38.                         s[2] = tempup1;
  39.                         //printf("1:%d|2:%d|3:%d\r\n",s[2],s[1],s[0]);
  40.                 if(s[0]<=15||s[1]<=15||s[2]<=15)
  41.                 {
  42.                         Car_Check();
  43.                         flag_t = 0;
  44.                 }
  45.                 else if(s[0]>15&&s[1]>15&&s[2]>15)
  46.                 {
  47.                         if(!flag_t)
  48.                         {
  49.                         Car_Check();
  50.                         flag_t = 1;
  51.                         }
  52.                 }
  53.     delay_ms(500);
  54.
  55.    }
  56. }
  57. void Car_Check(void)
  58. {
  59.         if(s[0]<15)
  60.         {
  61.                 if(s[1]<15)
  62.                         if(s[2]<15)
  63.                                 ESP8266_SendString(DISABLE,"1234   000",10,Single_ID_0);
  64.                         else
  65.                                 ESP8266_SendString(DISABLE,"1234   001",10,Single_ID_0);
  66.                 else
  67.                         if(s[2]<15)
  68.                                 ESP8266_SendString(DISABLE,"1234   010",10,Single_ID_0);
  69.                         else
  70.                                 ESP8266_SendString(DISABLE,"1234   011",10,Single_ID_0);
  71.
  72.         }
  73.         else
  74.         {
  75.                 if(s[1]<15)
  76.                         if(s[2]<15)
  77.                                 ESP8266_SendString(DISABLE,"1234   100",10,Single_ID_0);
  78.                         else
  79.                                 ESP8266_SendString(DISABLE,"1234   101",10,Single_ID_0);
  80.                 else
  81.                         if(s[2]<15)
  82.                                 ESP8266_SendString(DISABLE,"1234   110",10,Single_ID_0);
  83.                         else
  84.                         {
  85.                                 ESP8266_SendString(DISABLE,"1234   111",10,Single_ID_0);
  86.
  87.                         }
  88.         }
  89. //        macESP8266_Usart("AT+CIPCLOSE\r\n");
  90. //        macESP8266_Usart("AT+ CWQAP\r\n");/* 斷開連接 */
  91. }
Avatar_UltrasonicWave.rar (328.49 KB, 下載次數: 143)
ID:234038 發表于 2018-1-29 10:47 | 顯示全部樓層
不知道能不能用呢 我先試試
ID:279966 發表于 2018-3-14 20:19 | 顯示全部樓層
學習學習
ID:117053 發表于 2018-4-23 19:05 | 顯示全部樓層
請問樓主有原理圖嗎?
ID:518121 發表于 2020-3-25 22:49 | 顯示全部樓層
想問問代碼里面的GPIOC13你接的是那個引腳
