查看: 3069|回復: 1
單片機紅外遙控系統代碼
ID:258681 發表于 2017-12-7 15:53 | 顯示全部樓層 |閱讀模式
紅外遙控系統代碼
  1. #include <reg52.h>    //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
  2. #include  "1602.h"
  3. #include  "delay.h"
  4. #include  "stdio.h"
  5. sbit IR=P3^2;  //紅外接口標志
  6. /*------------------------------------------------
  7.                 全局變量聲明
  8. ------------------------------------------------*/
  9. unsigned char  irtime;//紅外用全局變量
  10. bit irpro_ok,irok;
  11. unsigned char IRcord[4];
  12. unsigned char irdata[33];
  13. unsigned char TempData[16];
  14. char code Tab[16]="0123456789ABCDEF";
  15. //選定的紅外遙控器按鍵,鍵值為提前讀取的
  16. unsigned char code LED_data[16][4]={
  17. {0x00,0xff,0x16,0xe9},//0
  18. {0x00,0xff,0x0C,0xf3},//1
  19. {0x00,0xff,0x18,0xe7},//2
  20. {0x00,0xff,0x5e,0xa1},//3
  21. {0x00,0xff,0x08,0xf7},//4
  22. {0x00,0xff,0x1c,0xe3},//5
  23. {0x00,0xff,0x5a,0xa5},//6
  24. {0x00,0xff,0x42,0xbd},//7
  25. {0x00,0xff,0x52,0xad},//8
  26. {0x00,0xff,0x4a,0xb5},//9
  27. {0x00,0xff,0x45,0xba},//關閉
  28. {0x00,0xff,0x46,0xb9},//Mode
  29. {0x00,0xff,0x47,0xb8},//靜音
  30. {0x00,0xff,0x44,0xbb},//下一首
  31. {0x00,0xff,0x40,0xbf},//后退
  32. {0x00,0xff,0x43,0xbc} //前進
  33. };
  34. bit check_array(unsigned char *array1,unsigned char *array2,unsigned char len)
  35. {
  36.         int i;
  37.         for(i=0;i<len;i++)
  38.         {
  39.                 if(array1[i]!=array2[i])
  40.                 break;//如果不等,結束循環,此時i的值是小于5的
  41.         }
  42.         if(i==len) //相同返回1,不同返回0
  43.                 return 1;
  44.         else
  45.                 return 0;
  46. }
  47. unsigned char  KEY_SCANF()
  48. {
  49.         unsigned char KEY_i=0;
  50.         for(KEY_i=0;KEY_i<16;KEY_i++)
  51.         if(check_array(IRcord,LED_data[KEY_i],4))                //如果是選定的按鍵
  52.                 return KEY_i;
  53.         return 20;
  54. }
  55. /*------------------------------------------------
  56.                   定時器0中斷處理
  57. ------------------------------------------------*/
  58. void tim0_isr (void) interrupt 1
  59. {
  60.   irtime++;  //用于計數2個下降沿之間的時間
  61. }
  62. /*------------------------------------------------
  63.                   外部中斷0中斷處理
  64. ------------------------------------------------*/
  65. void EX0_ISR (void) interrupt 0 //外部中斷0服務函數
  66. {
  67.   static unsigned char  i;             //接收紅外信號處理
  68.   static bit startflag;                //是否開始處理標志位
  69. if(startflag)
  70.    {
  71.     if(irtime<63&&irtime>=33)//引導碼 TC9012的頭碼,9ms+4.5ms
  72.                         i=0;
  73.                     irdata[i]=irtime;//存儲每個電平的持續時間,用于以后判斷是0還是1
  74.                     irtime=0;
  75.                     i++;
  76.                             if(i==33)
  77.                               {
  78.                                    irok=1;
  79.                                  i=0;
  80.                                   }
  81.           }
  82.            else
  83.                 {
  84.                 irtime=0;
  85.                 startflag=1;
  86.                 }
  87. }
  88. /*------------------------------------------------
  89.                 定時器0初始化
  90. ------------------------------------------------*/
  91. void TIM0init(void)//定時器0初始化
  92. {
  93.   TMOD=0x02;//定時器0工作方式2,TH0是重裝值,TL0是初值
  94.   TH0=0x00; //重載值
  95.   TL0=0x00; //初始化值
  96.   ET0=1;    //開中斷
  97.   TR0=1;
  98. }
  99. /*------------------------------------------------
  100.                   外部中斷0初始化
  101. ------------------------------------------------*/
  102. void EX0init(void)
  103. {
  104. IT0 = 1;   //指定外部中斷0下降沿觸發,INT0 (P3.2)
  105. EX0 = 1;   //使能外部中斷
  106. EA = 1;    //開總中斷
  107. }
  108. /*------------------------------------------------
  109.                   鍵值處理
  110. ------------------------------------------------*/
  111. void Ir_work(void)
  112. {
  113.         unsigned char temp[16],yyy;
  114.      TempData[0] = Tab[IRcord[0]/16];   //處理客戶碼
  115.            TempData[1] = Tab[IRcord[0]%16];
  116.      TempData[2] = '-';
  117.            TempData[3] = Tab[IRcord[1]/16];   //處理客戶碼
  118.            TempData[4] = Tab[IRcord[1]%16];
  119.            TempData[5] = '-';
  120.            TempData[6] = Tab[IRcord[2]/16];   //處理數據碼
  121.            TempData[7] = Tab[IRcord[2]%16];
  122.            TempData[8] = '-';
  123.            TempData[9] = Tab[IRcord[3]/16];   //處理數據反碼
  124.            TempData[10] = Tab[IRcord[3]%16];
  125.      LCD_Write_String(5,0,TempData);
  126.                           yyy=KEY_SCANF();
  127.                 if(yyy!=20)
  128.                 {
  129.                  sprintf(temp,"%d      " ,(unsigned int)yyy);
  130.      LCD_Write_String(10,1,temp);
  131.                         switch(yyy)
  132.                         {
  133.                                 case 0: {P1=0X7F;P2=0XFF;};break;
  134.                                 case 1: {P1=0XBF;P2=0XFF;};break;
  135.                                 case 2: {P1=0XDF;P2=0XFF;};break;
  136.                                 case 3: {P1=0XEF;P2=0XFF;};break;
  137.                                 case 4: {P1=0XF7;P2=0XFF;};break;
  138.                                 case 5: {P1=0XFB;P2=0XFF;};break;
  139.                                 case 6: {P1=0XFD;P2=0XFF;};break;
  140.                                 case 7: {P1=0XFe;P2=0XFF;};break;
  141.
  142.                                 case 8: {P1=0XFF;P2=0XFE;};break;
  143.                                 case 9: {P1=0XFF;P2=0XFD;};break;
  144.                                 case 10: {P1=0XFF;P2=0XFB;};break;
  145.                                 case 11: {P1=0XFF;P2=0XF7;};break;
  146.                                 case 12: {P1=0XFF;P2=0XEF;};break;
  147.                                 case 13: {P1=0XFF;P2=0XDF;};break;
  148.                                 case 14: {P1=0XFF;P2=0XBF;};break;
  149.                                 case 15: {P1=0XFF;P2=0X7F;};break;
  150.                                 default: {P1=0XFF;P2=0XfF;};break;
  151.                         }
  152.                 }
  153.                 else
  154.                 {
  155.      LCD_Write_String(10,1,"Error!");
  156.                 }
  157.
  158.
  159.            irpro_ok=0;//處理完成標志
  160.   }
  161. /*------------------------------------------------
  162.                 紅外碼值處理
  163. ------------------------------------------------*/
  164. void Ircordpro(void)//紅外碼值處理函數
  165. {
  166.   unsigned char i, j, k;
  167.   unsigned char cord,value;
  168.   k=1;
  169.   for(i=0;i<4;i++)      //處理4個字節
  170.      {
  171.       for(j=1;j<=8;j++) //處理1個字節8位
  172.          {
  173.           cord=irdata[k];
  174.           if(cord>7)//大于某值為1,這個和晶振有絕對關系,這里使用12M計算,此值可以有一定誤差
  175.              value|=0x80;
  176.           if(j<8)
  177.                     {
  178.                          value>>=1;
  179.                         }
  180.            k++;
  181.          }
  182.      IRcord[i]=value;
  183.      value=0;
  184.      }
  185.          irpro_ok=1;//處理完畢標志位置1
  186. }
  187. /*------------------------------------------------
  188.                     主函數
  189. ------------------------------------------------*/
  190. void main(void)
  191. ……………………
  192. …………限于本文篇幅 余下代碼請從51黑下載附件…………
無線遙控系統代碼.rar (59.74 KB, 下載次數: 18)
ID:338855 發表于 2018-5-30 15:46 | 顯示全部樓層
有msp430f6638的有嗎?分享一下吧謝謝
