霍爾測速
- /************霍爾測速儀******************/
- /**編寫人:劉夢宇**/
- /**主控芯片:STC89C52RC**/
- /**晶振12MHZ**/
- #include<reg52.h>
- #include<intrins.h>
- #define uint8 unsigned char
- #define uint16 unsigned int
- #define CMD 0x00
- #define DAT 0x01
- #define DataPort P0//LCD數據口
- sbit RW=P2^6;
- sbit RS=P2^5;
- sbit E=P2^7;
- uint16 N=0;
- uint8 C_50ms;
- uint8 Z=0;
- uint8 count=0;
- bit flag_1s=0;
- /**ms級延時子程序**/
- void delay(uint16 t)
- uint16 a;
- for(;t>0;t--)
- for(a=123;a>0;a--);
- /**LCD時序**/
- void write_LCD(uint8 dat,bit rs)
- E=0;
- RW=0;
- RS=rs;//選擇指令or數據
- _nop_();
- _nop_();
- _nop_();
- E=1;
- _nop_();//delay(1);
- _nop_();
- _nop_();
- DataPort=dat;//將數據送到LCD數據口
- _nop_();
- _nop_();
- _nop_();
- E=0;
- delay(1);
- /**LCD選擇顯示位置子函數**/
- void SetXY(uint8 x,uint8 y)
- x=x&0x0f;//防止X、Y 超過量程
- y=y&0x01;
- if(y)
- write_LCD(0x80+x,CMD);
- else
- write_LCD(0xc0+x,CMD);
- /**轉速數值轉換子函數**/
- void disload(uint16 a)
- SetXY(4,0);
- write_LCD(a/1000+'0',DAT);
- write_LCD(a%1000/100+'0',DAT);
- write_LCD(a%100/10+'0',DAT);
- write_LCD(a%10+'0',DAT);
- write_LCD('r',DAT);
- write_LCD('/',DAT);
- write_LCD('m',DAT);
- write_LCD('i',DAT);
- write_LCD('n',DAT);
- /**LCD字符指針函數**/
- void LCD_wrstr(uint8*str)
- while(*str!='\0')
- write_LCD(*str,DAT);
- str++;
- /**初始化子程序**/
- void All_init()
- delay(500);
- write_LCD(0x38,CMD);
- write_LCD(0x0c,CMD);
- write_LCD(0x01,CMD);
- delay(10);
- SetXY(0,1);//設置標題顯示位置
- LCD_wrstr("Tachometer:");
- TMOD=0x01;//設置T0位工作方式1——作為16位定時器
- ET0=1;//打開定時器0的中斷
- TR0=1;//打開定時器0
- TH0=(65536-50000)/256;//裝入初值
- TL0=(65536-50000)%256;
- IT0=1;//外部中斷0為下降沿中斷
- EX0=1;//打開外部中斷
- EA=1;//打開總中斷
- void main()
- All_init();//先進行初始化
- while(1)
- if(flag_1s==1)
- flag_1s=0;//1s標志位清零
- disload(N);
- /**定時器0中斷服務子程序**/
- void timer0() interrupt 1
- if(++C_50ms>19)
- EX0=0;//關閉外部中斷0
- C_50ms=0;//定時1s之后C_50ms清零
- N=60*Z;//計算轉速
- Z=0;//初始化圈數
- flag_1s=1;//1s標志位置1
- TH0=0x3c;//重新賦值
- TL0=0xb0;
- EX0=1;//打開外部中斷0,開始計數。
- void wai0() interrupt 0
- count++;
- if(count==2) //兩次外部脈沖,電機轉一圈。
- Z++;//轉圈+1
- count=0;//初始計數值
霍爾測速.rar
(18.03 KB, 下載次數: 32)
2017-11-30 22:20 上傳
下載積分: 黑幣 -5
