查看: 4142|回復: 13
單片機倒計時程序,數碼管閃爍太快,該怎么解決啊?
ID:999060 發表于 2022-1-5 16:01 | 顯示全部樓層 |閱讀模式
數碼管在設置時狂閃,該怎樣解決啊,或者說調慢點
單片機源程序如下:
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint  unsigned int
#define duan P1
#define wei  P3
sbit key1 = P2^3;
sbit key2 = P2^4;
sbit key3 = P2^5;
sbit key4 = P2^6;
sbit key5 = P2^7;
sbit out  = P2^2;
sbit di   = P2^0;
bit flag=0,flag1=0,shan=0;
uchar knum,shan_cont,i;
uchar shi=0,fen=0,miao=0;
uint cont,cont1,cont2;
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}
uchar code weima[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar LedBuff[]={0,0,0,0,0,0,0,0};
void init()
        TMOD |= 0x01;
        TH0 = (65536-1000)/256;
        TL0 = (65536-1000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
void dis()
        LedBuff[0] = duanma[miao%10];
        LedBuff[1] = duanma[miao/10];
        LedBuff[2] = 0x40;
        LedBuff[3] = duanma[fen%10];
        LedBuff[4] = duanma[fen/10];
        LedBuff[5] = 0x40;
        LedBuff[6] = duanma[shi%10];
        LedBuff[7] = duanma[shi/10];
void keysan()
        static bit  kf1=0,kf2=0,kf3=0;
        static uint i=0,j=0,k=0,l=0,m=0        if(knum==0)
            if(key4 == 1)
                m=0;
                kf2=0;
            else if(kf2 == 0
                ++m;
                if( (m>20) && ((miao != 0) || (fen != 0) || (shi != 0)) )
                m=0;
                kf2=1;
                flag = !flag;
                out  = !out;
        if(out==1)
            if(key1==1)
                i=0;
                kf1=0;
            else if(kf1 == 0)
                ++i;
                if(i>12)
                    i=0;
                    kf1=1;
                    knum++;
                    if(knum==4) knum = 0;
        if(key2==0)
                j++;
                if(j >= 3000)
                                        if(knum==1)
                            miao++;
                            if(miao==60) miao = 0;
                        if(knum==2)
                        fen++;
                        if(fen==60) fen=0;
                        if(knum==3)
                        shi++;
                        if(shi==24) shi=0;
                        j=100;
        else
                        if(knum==1)
                            miao++;
                        if(knum==2)
                        fen++;
                        if(fen==60) fen=0;
                        if(knum==3)
                        shi++;
                        if(shi==24) shi=0;
                        j=0;
        if(key3==0)
        k++;
        if(k >= 3000)
            if(knum==1)
                miao--;
                if(miao==255) miao = 59;
            if(knum==2)
                fen--;
                if(fen==255) fen=59;
            if(knum==3)
                    shi--;
                    if(shi==255) shi=23;
            k=100;
        else
        if(k>500 && k<3000)
            if(knum==1)
                miao--;
            if(knum==2)
                fen--;
            if(knum==3)
                    shi--;
                k=0;
void main()
        init();
        out = 1;
        while(1)
            keysan();
            dis();
            if(shi==0 && fen==0 && miao==0 && flag == 1 )
                flag=0;
                flag1=1;
                out=1;
void timer() interrupt 1
        if(flag)
                cont++;
                if(cont == 1000)
                    cont = 0;
                    miao--;
                    if(miao==255)
                            miao=59;
                            fen--;
                            if(fen==255)
                            fen=59;
                            shi--;
                            if(shi==255) shi=0;
                            if(shi==0) fen=59;
                            if(fen==0 && shi==0) fen=0;
        if(flag1)
            cont1++;
            if(cont1==500)
                cont1=0;
                di=!di;
                cont2++;
                if(cont2==20)
                        cont2=0;
                        flag1=0;
        if(knum != 0)
            shan_cont++;
            if(shan_cont==100)
                shan_cont=0;
                shan = !shan;
        i++;
        if(i>=8) i=0;
        duan = 0x00;
        switch(i)
            case 0:
                    if(knum==1)
                                         if(shan==1) {wei = 0x00; duan = LedBuff[0];}
                     else {wei = weima[0]; duan = LedBuff[0];}
                    else{wei = weima[0]; duan = LedBuff[0];}        break;
            case 1:
                    if(knum==1)
                                         if(shan==1){wei = 0x00; duan = LedBuff[1];}
                     else{wei = weima[1]; duan = LedBuff[1];}
                    else{wei = weima[1]; duan = LedBuff[1];}  break;
            case 2:  wei = weima[2]; duan = LedBuff[2];        break;
            case 3:
                    if(knum==2)
                                         if(shan==1){wei = 0x00; duan = LedBuff[3];}
                     else{wei = weima[3]; duan = LedBuff[3];}
                    else{wei = weima[3]; duan = LedBuff[3];}    break;
            case 4:
                    if(knum==2)
                                         if(shan==1){wei = 0x00; duan = LedBuff[4];}
                     else{wei = weima[4]; duan = LedBuff[4];}
                    else{wei = weima[4]; duan = LedBuff[4];}        break;
            case 5:  wei = weima[5]; duan = LedBuff[5];        break;
            case 6:
                    if(knum==3)
                                         if(shan==1){wei = 0x00; duan = LedBuff[6];}
                     else{wei = weima[6]; duan = LedBuff[6];}
                    else{wei = weima[6]; duan = LedBuff[6];}        break;
            case 7:
                    if(knum==3)
                                         if(shan==1){wei = 0x00; duan = LedBuff[7];}
                     else{wei = weima[7]; duan = LedBuff[7];}
                    else{wei = weima[7]; duan = LedBuff[7];}        break;
            default: break;
ID:161164 發表于 2022-1-5 16:51 | 顯示全部樓層
uint shan_cont;//<<<<<<<<<<<<<<<<<<<<<<<
    if(knum != 0)
        shan_cont++;
        if(shan_cont == 10000)//<<<<<<<<<<<<<<<<<<<<<<<<
            shan_cont = 0;
            shan = !shan;
ID:999060 發表于 2022-1-5 19:48 | 顯示全部樓層
修改之后還是一樣的呀,是不是我程序寫的有問題啊?孩子蒙了求指教
ID:161164 發表于 2022-1-6 00:09 | 顯示全部樓層
uhl0 發表于 2022-1-5 19:48
以為你是說閃的太快
上Proteus一看
原來是亂閃
if(key2==0)的else里缺了短按判斷if(j>500 && j<3000)
ID:999060 發表于 2022-1-6 08:41 | 顯示全部樓層
lkc8210 發表于 2022-1-6 00:09
以為你是說閃的太快
上Proteus一看
原來是亂閃
建議以采納,謝謝大佬
ID:213173 發表于 2022-1-6 10:20 | 顯示全部樓層
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint  unsigned int
  5. #define duan P1
  6. #define wei  P3
  7. sbit key1 = P2^3;
  8. sbit key2 = P2^4;
  9. sbit key3 = P2^5;
  10. sbit key4 = P2^6;
  11. sbit key5 = P2^7;
  12. sbit out  = P2^2;
  13. //sbit di   = P2^0;
  14. bit count_down=0;//倒計時標志
  15. bit flag=0;//啟動標志
  16. char shi=12,fen=0,sec=0;
  17. uchar KeySec=0;//鍵值
  18. uint cont,cont1;
  19. uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  20. uchar code weima[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  21. uchar LedBuff[8];
  22. void init()
  23. {
  24.         TMOD |= 0x01;
  25.         TH0 = (65536-1000)/256;
  26.         TL0 = (65536-1000)%256;
  27.         EA = 1;
  28.         ET0 = 1;
  29.         TR0 = 1;
  30. }
  31. void dis()
  32. {
  33.         if(KeySec==3)LedBuff[0] = duanma[sec%10]|0x80;//加提示點
  34.         else LedBuff[0] = duanma[sec%10];
  35.         LedBuff[1] = duanma[sec/10];
  36.         if(KeySec==2)LedBuff[3] = duanma[fen%10]|0x80;//加提示點
  37.         else LedBuff[3] = duanma[fen%10];
  38.         LedBuff[4] = duanma[fen/10];
  39.         if(KeySec==1)LedBuff[6] = duanma[shi%10]|0x80;//加提示點
  40.         else LedBuff[6] = duanma[shi%10];
  41.         LedBuff[7] = duanma[shi/10];
  42. }
  43. void keysan()
  44. {
  45.         static bit  sign=0;
  46.         static uint count=0;
  47.         if(!key1||!key2||!key3||!key4||!key5)
  48.         {
  49.                 if(++count>=250 && sign==0)  //消抖與鎖定
  50.                 {
  51.                         sign=1;
  52.                         if(!key1)//設置
  53.                         {
  54.                                 if(++KeySec>=4)
  55.                                 {
  56.                                         KeySec=0;
  57.                                         cont=0;
  58.                                 }
  59.                                 flag=0;//停止計時
  60.                         }
  61.                         if(!key2 && KeySec>0)//++
  62.                         {
  63.                                 switch(KeySec)
  64.                                 {
  65.                                         case 1: shi++;if(shi>23)shi=0; break;
  66.                                         case 2: fen++;if(fen>59)fen=0; break;
  67.                                         case 3: sec++;if(sec>59)sec=0; break;
  68.                                 }
  69.                         }
  70.                         if(!key3 && KeySec>0)//--
  71.                         {
  72.                                 switch(KeySec)
  73.                                 {
  74.                                         case 1: shi--;if(shi<0)shi=23; break;
  75.                                         case 2: fen--;if(fen<0)fen=59; break;
  76.                                         case 3: sec--;if(sec<0)sec=59; break;
  77.                                 }
  78.                         }
  79.                         if(!key4 && KeySec==0)//正/倒計時
  80.                                 count_down=~count_down;
  81.                         if(!key5)//啟動/停止
  82.                         {
  83.                                 flag=~flag;
  84.                                 KeySec=0;
  85.                         }
  86.                 }
  87.         }
  88.         else
  89.         {
  90.                 sign=0;
  91.                 count=0;
  92.         }
  93. }
  94. void main()
  95. {
  96.         init();
  97.         out = 1;
  98.         LedBuff[2] = 0x40;
  99.         LedBuff[5] = 0x40;
  100.         while(1)
  101.         {
  102.                 keysan();
  103.                 dis();
  104.                 if(shi==0 && fen==0 && sec==0 && KeySec==0 )
  105.                 {
  106.                         flag=0;
  107.                         out=0;
  108.                 }
  109.         }
  110. }
  111. void timer() interrupt 1
  112. {
  113.         TH0 = (65536-1000)/256;
  114.         TL0 = (65536-1000)%256;
  115.         if(flag)
  116.         {
  117.                 cont++;
  118.                 if(cont >= 1000)
  119.                 {
  120.                         cont = 0;
  121.                         if(count_down)//正計時
  122.                         {
  123.                                 if(++sec>=60)
  124.                                 {
  125.                                         sec=0;
  126.                                         if(++fen>=60)
  127.                                         {
  128.                                                 fen=0;
  129.                                                 if(++shi>=24)shi=0;
  130.                                         }
  131.                                 }
  132.                         }
  133.                         else                        //倒計時
  134.                         {
  135.                                 if(--sec<0)
  136.                                 {
  137.                                         sec=59;
  138.                                         if(--fen<0)
  139.                                         {
  140.                                                 fen=59;
  141.                                                 if(--shi<0)shi=23;
  142.                                         }
  143.                                 }
  144.                         }
  145.                 }
  146.         }
  147.         duan=0x00;//段消隱
  148.         wei=0x01<<cont1;//位碼
  149.         duan=LedBuff[cont1];//段碼
  150.         cont1=++cont1%8;//循環計數
  151. }
ID:999060 發表于 2022-1-6 11:08 | 顯示全部樓層
謝謝大佬,剛好用上
ID:999060 發表于 2022-1-7 09:40 | 顯示全部樓層
以為你是說閃的太快
上Proteus一看
原來是亂閃
大佬我現在秒表數碼管顯示正常了,但分鐘和小時那里又亂閃了,是我后面的短按判斷錯了嗎?求指點
ID:161164 發表于 2022-1-7 10:19 | 顯示全部樓層
uhl0 發表于 2022-1-7 09:40
你是怎么改的?
上代碼啊~
ID:999060 發表于 2022-1-7 13:01 | 顯示全部樓層
lkc8210 發表于 2022-1-7 10:19
你是怎么改的?
上代碼啊~
#include<reg52.h>
#include<intrins.h>
#define duan P1                //段選
#define wei  P3                //位選
sbit key1 = P2^3;   //設置
sbit key2 = P2^4;   //加
sbit key3 = P2^5;   //減
sbit key4 = P2^6;   //啟動
sbit key5 = P2^7;   //手動
sbit out  = P2^2;   //輸出控制 ,低電平有效
sbit di   = P2^0;   //蜂鳴器
void Delay100ms()                //@11.0592MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 5;
        j = 52;
        k = 195;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
uchar shi=0,fen=0,miao=0;  //時分秒
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰段碼表
                   //  0          1         2          3           5        6         7          8          9
uchar code weima[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};           //位碼        加反相器用
                                   //  1   2    3    4   5     6    7    8
uchar LedBuff[]={0,0,0,0,0,0,0,0};                                      //數碼管顯示緩沖區
void init()                        //定時器初始化
        TMOD |= 0x01;             //設置定時器0為工作方式1(M1M0為01)
        TH0 = (65536-1000)/256;   //1ms初值 @12MHz
        EA = 1;                                          //開總中斷
        ET0 = 1;                                  //開定時器0中斷
        TR0 = 1;                          //啟動定時器0
void dis()          //顯示函數
        LedBuff[2] = 0x40;
        LedBuff[5] = 0x40;
void keysan()                //按鍵掃描函數
        static bit  kf1=0,kf2=0,kf3=0;   //自鎖標志,這里一定要加static(或者用全局變量),否則按鍵不靈
        static uint i=0,j=0,k=0,l=0,m=0; //消抖延時變量
//////////////////////////////////////啟動/暫停鍵//////////////////////////////////////
        if(knum==0)                           //只要時分秒都不等于0
            if(key4 == 1)           //啟動 暫停鍵
                m=0;                   //按鍵消抖計時變量清零
                kf2=0;                   //按鍵自鎖標志清零
            else if(kf2 == 0 ) //有按鍵按下,且是第一次被按下
                                        ++m;  //消抖
                           //時分秒都為0時,不能啟動輸出,只要其中之一不為0,就能啟動輸出
                m=0;                   //按鍵消抖計時變量清零
                kf2=1;                   //自鎖按鍵置位,避免一直觸發
                flag = !flag;  //啟動、暫停計時標志
                out  = !out;   //LED狀態取反
        if(out==1)            //加這句,只有在輸出關閉的時候,才能設置計時時間,在倒計時的過程中是不能設置的
            if(key1==1)   //設置   //IO是高電平,說明按鍵沒有被按下,這時要及時清零一些標志位
                i=0;           //按鍵消抖計時變量清零
                kf1=0;         //按鍵自鎖標志清零
            else if(kf1 == 0)  //有按鍵按下,且是第一次被按下
                ++i;                   //消抖
                if(i>12)
                    i=0;                   //按鍵消抖計時變量清零
                    kf1=1;         //自鎖按鍵置位,避免一直觸發
                    knum++;                   //調節時分秒--->123
                    if(knum==4) knum = 0;  //按第四次關閉設置
//////////////////////////////////////加1按鍵//////////////////////////////////////
        if(key2==0)                     //加1按鍵        快速加數
                j++;
                if(j >= 3000)           //長按,數碼管掃描放中斷里面,這里的值就要取得大才行
                {                       //因為沒用delay延時,CPU跑的很快
                        if(knum==1)
                            miao++;                                        //秒鐘加1
                            if(miao==60) miao = 0;        //超過60s變成0
                        if(knum==2)
                        fen++;                                        //分鐘加1
                        if(fen==60) fen=0;                //超過60變0
                        if(knum==3)
                        shi++;                                        //小時加1
                        if(shi==24) shi=0;                //超過24變0
                        j=1000;           //這里j的值可以設置連加的快慢,j的值越大就越快
                }                         //因為初值越大,加到3000的時間就越短
        else        //慢速加數
if(j>500 && j<3000)
        if(knum==1)
                            miao++;                                        //秒鐘加1
                        if(knum==2)
                        fen++;                                        //分鐘加1
                        if(knum==3)
                        shi++;                                        //小時加1
                        j=0;
//////////////////////////////////////減1按鍵//////////////////////////////////////
        if(key3==0)                 //減1按鍵        快速減數
        k++;
        if(k >= 3000)           //長按,數碼管掃描放中斷里面,這里的值就要取得大才行
            if(knum==1)
                miao--;                                         //秒鐘減1
                if(miao==255) miao = 59; //小于0就等于59
            if(knum==2)
                fen--;                                         //分鐘減1
                if(fen==255) fen=59;         //小于0就等于59
            if(knum==3)
                    shi--;                                 //時鐘減1
                    if(shi==255) shi=23; //小于0就等于23
            k=1000;
        else
        if(j>500 && j<3000)
            if(knum==1)
                miao--;                                         //秒鐘減1
            if(knum==2)
                fen--;                                         //分鐘減1
            if(knum==3)
                    shi--;                                 //時鐘減1
                k=0;        //消抖變量清零,為下次按鍵做準備
void main()
        init();                        //定時器初始化
        out = 1;
        while(1)
            keysan();        //按鍵掃描函數
            dis();                //顯示函數
            if(shi==0 && fen==0 && miao==0 && flag == 1 )  //倒計時時間到
                flag=0;   //停止計時
                flag1=1;  //啟動蜂鳴器標志置1
                out=1;    //關閉輸出
        TH0 = (65536-1000)/256;          //1毫秒初值
//////////////////////////////////////1s計時//////////////////////////////////////
        if(flag)
                cont++;
                if(cont == 1000)                   //1s到
                    cont = 0;                                 //清0
                    miao--;                                         //秒數減1
                    if(miao==255)                         //如果小于0,就是59
                            miao=59;
                            fen--;                                 //分鐘數減1
                            if(fen==255)                 //如果小于0,就是59
                            fen=59;
                            shi--;                         //小時減1
                            if(shi==255) shi=0;                   //時鐘小于0,就是0
                            if(shi==0) fen=59;                   //時鐘小于0,就是255
                            if(fen==0 && shi==0) fen=0;//時鐘分鐘都為0,就是0
//////////////////////////////////////蜂鳴器控制//////////////////////////////////////
        if(flag1)              //倒計時時間到,啟動蜂鳴器
            cont1++;
            if(cont1==500) //500ms蜂鳴器響一次
                cont1=0;
                di=!di;
                cont2++;
                if(cont2==20)//500*20=10000ms=10s,蜂鳴器響10s后停止
                        cont2=0;
                        flag1=0;
        if(knum != 0)
            shan_cont++;
            if(shan_cont==100)  //設置時,100ms閃爍時間 可根據實際效果調整
                shan_cont=0;
                shan = !shan;
/**********************************數碼管掃描函數**********************************/
        i++;                          //挨個顯示
        if(i>=8) i=0;          //清0
        duan = 0x00;
        switch(i)
            case 0:
                    if(knum==1) //如果設置鍵第一次按下
                                         if(shan==1) {wei = 0x00; duan = LedBuff[0];}  //設置秒位閃爍
                    else{wei = weima[0]; duan = LedBuff[0];}        break;        //否則正常顯示
            case 1:
                                         if(shan==1){wei = 0x00; duan = LedBuff[1];}   //設置秒位閃爍
                    else{wei = weima[1]; duan = LedBuff[1];}  break;        //否則正常顯示
            case 2:  wei = weima[2]; duan = LedBuff[2];        break;        //顯示-
            case 3:
                    if(knum==2) //如果設置鍵第二次按下
                                         if(shan==1){wei = 0x00; duan = LedBuff[3];}   //設置分位閃爍
                    else{wei = weima[3]; duan = LedBuff[3];}    break;//否則正常顯示
            case 4:
                                         if(shan==1){wei = 0x00; duan = LedBuff[4];}  //設置分位閃爍
                    else{wei = weima[4]; duan = LedBuff[4];}        break;        //否則正常顯示
            case 5:  wei = weima[5]; duan = LedBuff[5];        break;                //顯示-
            case 6:
                    if(knum==3) //如果設置鍵第三次按下
                                         if(shan==1){wei = 0x00; duan = LedBuff[6];} //設置時位閃爍
                    else{wei = weima[6]; duan = LedBuff[6];}        break;//否則正常顯示
            case 7:
                                         if(shan==1){wei = 0x00; duan = LedBuff[7];}    //設置時位閃爍
                    else{wei = weima[7]; duan = LedBuff[7];}        break;//否則正常顯示
            default: break;
感謝大佬回信,我聽你的建議加了在if(key2==0)的else里加了短按判斷if(j>500 && j<3000),秒表問題解決,但我時分顯示也有這個問題,我改了幾次發現不行不知道怎么改了
ID:213173 發表于 2022-1-7 20:21 | 顯示全部樓層
本帖最后由 wulin 于 2022-1-7 20:23 編輯
數碼管閃爍提示的實際視覺效果不如閃點好。給你改成數碼管閃爍提示供參考 測試程序 仿真.rar (96.63 KB, 下載次數: 8)
ID:161164 發表于 2022-1-7 22:08 | 顯示全部樓層
uhl0 發表于 2022-1-7 13:01
#include
#include
if(key2==0)的else里缺了一對{}
這里應該是k
ID:999060 發表于 2022-1-7 23:09 | 顯示全部樓層
lkc8210 發表于 2022-1-7 22:08
問題已解決,感謝
ID:999060 發表于 2022-1-7 23:10 | 顯示全部樓層
wulin 發表于 2022-1-7 20:21
問題已解決,感謝您的寶貴建議
