數碼管前三位顯示一個跑表,從000到999之間以1%秒速度運行
查看數: 11131 | 評論數: 4 | 收藏 0
發布時間: 2017-5-3 16:46
學習單片機的作業題源碼+PROTEUS仿真,歡迎下載。   數碼管前三位顯示一個跑表,從000到999之間以1%秒速度運行,     當按下一個獨立鍵盤時跑表停止,松開手后跑表繼續運行。     ...
ID:399179 發表于 2018-11-4 18:20
怎么做一個可預置計數器?
ID:420518 發表于 2018-11-4 15:12
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula = P2^6;
sbit wela = P2^7;
sbit key1 = P3^0;
sbit key2 = P3^1;
sbit key3 = P3^2;
sbit key4 = P3^3;
uchar tt,num,bai,shi,ge;
uchar code table[] = {
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71
void init();
void keys();
void delay(uint z);
void display(uchar bai,uchar shi,uchar ge);
void main(){
        init();
        while(1);
void init(){
        TMOD = 0x01;
        TH0 = (65536 - 1000)/256;
        TL0 = (65536 - 1000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        num = 0;
        tt = 0;
        bai = 0;
        shi = 0;
        ge = 0;
        wela = 1;
        P0 = 0xf8;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = 0x3f;
        dula = 0;
        delay(5);
void time0() interrupt 1 {
        tt++;
        if(tt == 1) {
                num++;
                if(num == 99)
                        bai++;
                if(bai == 10){bai = 0;}
                if(num == 100){
                        num = 0;
                tt = 0;
            shi = num/10;
            ge = num%10;
                display(bai,shi,ge);
                keys();
void keys(){
   if(key1 == 0){
                delay(5);
                if(key1 == 0){
                        TR0 = 0;
                        while(!key1)
                        delay(5);
                        if(key1 == 1){TR0 = 1;}
        if(key2 == 0){
                delay(5);
                if(key2 == 0){
                        TR0 = 0;
                        while(!key2)
                        delay(5);
                        while(!key2);
                                //display(bai,shi,ge);
                        while(key2!=0&&key3!=0)
        if(key3 == 0){
                delay(5);
                if(key3 == 0){
                        num = shi * 10 + ge;
                        TR0 = 1;
                        while(!key3)
                        delay(5);
                        while(!key3);
        if(key4 == 0){
                delay(5);
                if(key4 == 0){
                wela = 1;
                P0 = 0xf8;
                wela = 0;
                P0 = 0xff;
                dula = 1;
                P0 = 0x3f;
                dula = 0;
                delay(5);
                num = -1;
                bai = 0;
                while(!key4);
                delay(5);
                while(!key4);
void display(uchar bai,uchar shi,uchar ge){
        dula = 1;
        P0 = table[bai];
        dula = 0;
        P0 = 0xff;
        wela = 1;
        P0 = 0xfe;
        wela = 0;
        delay(5);
        dula = 1;
        P0 = table[shi];
        dula = 0;
        P0 = 0xff;
        wela = 1;
        P0 = 0xfd;
        wela = 0;
        delay(5);
        dula = 1;
        P0 = table[ge];
        dula = 0;
        P0 = 0xff;
        wela = 1;
        P0 = 0xfb;
        wela = 0;
        delay(5);
void delay(uint z){
        uint x,y;
        for(x = z;x > 0;x--)
                for(y = 110; y > 0;y--);
ID:296837 發表于 2018-6-4 16:51
可以啊,這個思路是不是可以做一些其他的改進,可以回去試試。
ID:340061 發表于 2018-5-28 19:54
謝謝樓主
